Removing panel to see why oil heater wont come on model # H6010 /optimus
I have an optimus oil filled heater model 6013 cannot get it to come on
Most likely the heating element is burned out or the thermostat.
Jan 01, 2018 | Optimus Heating & Cooling
Optimus h-4501 keeps turning off. how can I stop that?
According to the user manual the unit will automatically turn off when it is within 2 degrees of the temperature it is set at.
It's internal timer settings range from 1/2 hour to 8 hours.
Optimus 4501 Instruction Manual And Owner Manual
There is no reason it should be turning off after 15 minutes if it is not within 2 degrees of the temperature of the room.
Contact Customer Service at OptimusEnt@aol.com
Oct 02, 2017 | Optimus Heating & Cooling
How to get optimus oil filled radiator with timer to turn on?
if you cant get it to work the way it should
and not on a thermostat cycle
faulty timer
Nov 26, 2016 | Optimus Heating & Cooling
Could I get a wiring diagram?
if on control panel its calling for heat sounds like bad heating element if not calling for heat bad temp sensor at about 75 degrees it should ohm out about 78 ohms
Aug 27, 2014 | Optimus Flow Thru Heater, 2 Psi Prs, for...
H-5300-bk
I have the Optimus quartz heater , model H-5300-BK . The top two elements are always on in the # 2 position , the thermostat only works on the bottom three elements. Question ; Can I removed the top two elements , so the thermostat controls the total heater. fredh@bresnan.net
Nov 30, 2012 | Optimus Heating & Cooling
I need a owner manual for a Optimus H1380 Electric Heater
There is not much details on these heaters as there is not much to be explained. The specification are available on this link:
http://www.heater-home.com/product/h-1321.aspx
Nov 21, 2011 | Optimus H1320 Electric Utility Heater
Optimus heater h-4438
Check on the heater coil using the multi-tester. Set it at Ohms 1 x 10 position.
1. Switch it off and disconnect it .
2. Disassemble the electric heater.
3. Put the multi-tester probe (red and black) at each
end of the heater coil.
4. If the reading is almost zero, then it is okey.
Otherwise, you have to replace it.
5. Then, reassemble the electric heater.
6. Plug it back to the electric outlet, and switch on.
Nov 03, 2009 | Optimus H-4436 Electric Heater
Problem w/ Optimus space heater model H-4438.
I have the same problem. I removed the center panel on the back of the dish and found a fuse inside a white insulating sleeve. The fuse is open, preventing the current from reaching the heating coils. On the fuse it says 121 C. and 15 A.; I assume that it is designed to blow if the temp. of the dish exceeds 121 centigrade or the current exceeds 15 Amps. I don't see any reason to believe that either has happened so I suspect that these fuses just spontaneously fail. Now I just need to find a source for new ones. I wouldn't recommend jumping the fuse as it could lead to a fire.
Jan 10, 2009 | Heating & Cooling
Optimus H-4438 Electric Heater
Optimus electric heater can be found on amazon, click here and take a look: Amazon com optimus electric heater. I hope this was helpful. Cheers
Jan 10, 2009 | Optimus H-4436 Electric Heater
Alarm light staying on.
Feb 22, 2008 | Heating & Cooling
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
