Where do you put the conditioner in model HWMSP60
Hello how do I put the battery back in my air conditioner remote
How to replace battery remote control air conditioner
If this generic response does not help, consider going to the air conditioner's brand site and looking into support for the particular model.
Oct 14, 2017 | Heating & Cooling
Conia Model - CPA12020 Air Conditioner; does anyone have the manual for this? or at least know how to fill it with water? or if it needs water?
as we have no make or model listed how could we possibly guess . I have seen and owned several tho and none even had to have water put in them .
Nov 20, 2015 | Heating & Cooling
Were we put the water
you do not put water in air conditioners , you put in coolant.
what is the make and model of your unit ...please add dettails and resubmit the query
Jul 08, 2015 | Heating & Cooling
Why won't my air conditioner model # aero5LQQ1 put out air?
change the fan run capacitor. what you are hearing is compressor running.
Jul 08, 2014 | GE Heating & Cooling
I have a 2010 30' cougar travel trailer, we have never used the air conditioner which is a coleman mach model, when I put it on auto and cool it blows cool air but never gets cold am I suposed to
Check the temperature of the air coming out the vent If it's more than 10 degrees below the air going in it's ok. If it's the same temperature, the condensing system may be not working. The compressor may just be a quiet one!
May 18, 2012 | Coleman Mach III Air Conditioner
Where do you put freon in the lg lw1800pr model
There are no user service ports on a window air conditioner you need to have an e.p.a. refrigerant recovery certificate to legally recover and replace refrigerant.
Jul 22, 2011 | LG LW1800PR Air Conditioner
Hurricane
Well goto the unit tag and look for the amperage that it draws when runing the generator will have to put that much current for output or more sample : air conditioner 22 amps
generator 30 amps
Sep 03, 2008 | Weather King 10AJA6001AH Air Conditioner
PUTTING THE WINDOW SIZER THING ON THE AIR CONDITIONERS
That is a good question...what to call them...perhaps adjustable baffles? Anyway...have you removed the air conditioner from its housing? Most window air conditioners can be removed from the housing through the front opening. With the air conditioner removed...it may be possible to apply the screws from the inside of the air conditioner housing to attach the baffles to the outside. I may be able to give better advice if you can tell me the manufacturer and model number of the air conditioner.
Good luck... and I hope this is helpful!!
Feb 01, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
