Question about Watches
How do I remove back change back Vice Versa watch 1233 (VV. Men's Chrono JQT)
  • 2501 Answers
SOURCE: i need a maual for the Jacques Lemans Sports Dual
You can download a manual from their web site.
Go to "www.jacqueslemans.com/", on the left of the page is a menu. Select "instructions/catalogs".
Download the instructions for your watch.
Posted on Feb 15, 2010
  • 2501 Answers
SOURCE: I need a manual for a Festina, Chrono Bike, watch
Festina do not have much of a web site at present but if you go to "www.festinausa.com/", you will see a customer service address who may be able to help you.
Posted on Mar 12, 2010
  • 93 Answers
SOURCE: My swiss army victorinox chrono watch stops about
It sounds like the watch movement needs to be serviced. A qualified watchmaker can do this for you.
Hope this helps,
Ken
www.yellowstonewatch.com
Posted on Apr 16, 2010
escapement
  • 2334 Answers
SOURCE: I pulled off the back cover of my KC 1233 wrist
Usually you would need a watchmakers press for closing the watch back. Without proper tools it is quite difficult, but you can try the following. Take a leather belt and lay it flush on an even, solid surface (stable table will do). Undo the strap (both ends) from watch case by pushing spring bars inwards with pen knife. Lay the watch crystal face down on the leather belt. Belt must be wider than watch itself and the leather must be quite hard and even, not soft. Find the small groove on watch case back and align it very carefully to the watch's winding stem, so, the stem goes directly in the middle in protrusion. Slightly push the case back into the watch case at that groove point and gradually apply pressure with fingers going all way around the case back. Use your body weight if needed. You should hear "click" sound when the case back jumps in to place. If this does not work, there is no other way, but to go and see watchmaker. Hope it will work for you.
Posted on Nov 22, 2010
  • 125 Answers
SOURCE: My watch is stuck on
Welcome to Fixya,
The Armitron WR165 is a digital watch that includes a 24-hour alarm, hourly chime, stopwatch feature, countdown timer and is water resistant up to 165 feet. With a rubber wristband and rugged style, the watch is meant for outdoor enthusiasts and athletes. The WR165 can be found online, in some sporting supply stores and in certain department or general home stores. Setting the Armitron WR165 only takes a few steps to perform properly.
1 - Push the top button on the left-hand side of the watch until the seconds flash on the display.Press the top button on the right-hand side to zero the seconds.
2 - Push the bottom button on the left-hand side of the watch until the hours flash and then the top button on the right-hand side of the watch to increase the hour on the watch display. Note that "PM" will appear on the watch display for PM times, but there is no "AM" indicator on the display.
3 - Press the bottom button on the left-hand side of the watch until the minutes flash on the display.Press the top button on the right-hand side of the watch to increase the minutes on the display.
4 - Repeat to set the month, date and weekday on the watch. Press the top button on the left-hand side of the watch to return to time mode.
5 - Press the bottom button on the left-hand side of the watch to enter the stopwatch mode. Press the top button on the right-hand side of the watch to start the timer. Press one more time to stop timing. Press the top button on the left-hand side of the watch to reset the stopwatch to zero and the bottom button on the left-hand side of the watch to return to time mode.
6 - Press the bottom button on the left-hand side of the watch twice to set the alarm. Press the top button on the left-hand side of the watch until the hours flash on the display. Press the bottom button on the left-hand side of the watch until the alarm number flashes. Press the top button on the right-hand side of the watch to choose Alarm Time 1 or Alarm Time 2. Push the bottom button on the left-hand side of the watch again until the hours flash. Push the top button on the right-hand side of the watch to choose the alarm hour, followed by the bottom button on the left-hand side of the watch to change to minutes. Press the top button on the right-hand side of the watch to advance the alarm minutes. Press the top button on the left-hand side of the watch to set the alarm time and the bottom button on the left-hand side of the watch to return to time mode.
I hope this will help you.
Thank you for usinf Fixya.
Posted on Feb 21, 2011
Chron startstop button stuck
put a spot of WD40 down the sides of the button then try pull and pushing with tweezers
Mar 27, 2015 | Swatch Irony Chrono #YOS414G Watch for Men
How to reset the chrono function of a Tag Heuer Aquaracer Calibre S CAF7113.FT8010 after a battery change
Pull the crown out to the first position, and then you may find that successive pushes of the upper pushbutton will move one of the chrono hands by one division, and the lower pushbutton will move a different chrono hand. Similarly if you pull the crown out to the second position, the pushbuttons will control the other chrono hands. In this way you can set each of the chrono hands to their zero positions. Hope this works..
Jan 17, 2014 | Tag Heuer Aquaracer Calibre S...
I need to reset the chrono to the center point.. how do i do that?
mcdevito75 here, generally you"d press the chrono button to start the chrono and press again to stop it, NOW! press the chrono button again to re-set it. Should work.
Feb 11, 2011 | Cerruti # CT61191X403011 Watch for Men
Need new screws for back plate of festina chrono warrior model F16272
Did you manage to find them? I have the same watch and the same problem! Cheers.
Sep 03, 2010 | Festina F16272/5 Warrior Chronograph Watch...
My swiss army victorinox chrono watch stops about once a week when the date changes, I just tap on it and it starts back up????
Hope this helps,
Ken
Apr 06, 2010 | Swiss Victorinox Army Classic Chrono...
I Have A Fossil CH2446 Chrongraph Avenger With No Manual
Just pull out the time setting knob to the position 2(ie between outermost & innermost position).Now press the chrono button A(the upper one)repeatedly till the chrono needle is on 12:00 poition.Now you can press back the time setting knob to initial position.
Hope that helps you!!
Mar 11, 2009 | Fossil Metal Chronograph Avenger CH2446...
Removing the pins in order to size a watch
push the pins in with a very small tools they should contract and teh piece will pop off
Dec 11, 2008 | Nautica Nst Chrono N19509g Watch for Men
Watches Logo
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
