Question about Refrigerators
Condensation on the gasket and side of brand new French Door bottom freezer Whirlpool refrigerator.
    Champion:
  • 363 Answers
Clean all of the contact surfaces of the gasket and also the contact point on the refrigerator
Posted on Jul 22, 2009
What causes ice build up in bottom of freezer with french doors and then leaks out
sounds to me like a bad door seals causing condensation and leakage
Aug 23, 2014 | Whirlpool Refrigerators
Why on a whirlpool gold double door refrigerator
That's an easy one, the draw is not in correctly, preventing the door to close properly. Clean up the mess then work with the draw until it seats properly, then double check that the door seals closes right.
Jul 23, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
Replace seal on Liebherr french door
Are you talking about the center door gaskets? If so, Purchase new gaskets Left and Right (2 different part numbers) from Adco Service of Scottsdale AZ. The gaskets pull out from the two grooves and put liquid soap in the new gasket channel that holds the heater wire. Observe the channel where the wire came from.. Insert the heater wire slowly until it is at the end. Starting at the top, insert the gasket tongue that is towards the inside if the refrigerator first all the way down, then insert the side at the edge of the door. Be sure to firmly seat the gasket
Dec 23, 2013 | Liebherr CS2062 Bottom Freezer French Door...
Water on floor - french door refrigerator with freezer below
Yes the bottom compartment does have a drain opening but to see it you will need to remove the rear panel covering the evaporator inside the back wall of the freezer compartment. See item location number 11 on page 3 of the parts list. That will need to be removed so you can reach the drain inside the freezer compartment. The fresh food section also has a drain. Here is a=> AFF2534FEB4 Parts List and AFF2534FEB4 User Manual I am here to answer any questions you may have, Thanks Sea Breeze
Leaking Refrigerators
Jul 23, 2013 | Whirlpool Amana Refrigerator Water Filter...
Samsung french door freezer gets lots of frost inside - we've replaced the gasket but still get frost
Could be the rail slides not closeing correctly keeping door open slightly. Also they have made a new stronger set of rails to be used. Try going to the Samsung web site for tech info our recalls for that unit
Aug 18, 2012 | Samsung RF265AA Bottom Freezer French Door...
My Whirlpool bottom-freezer, french-door refrigerator is 3 years old. All the lights work fine, as does the ice-maker, and the main compartment cools as it should. The problem is: the compressor motor...
Newer model refrigerators run a lot more than older ones but you could have leaks around gaskets, check freezer compartment and see if there ice buildup around door if so let this defrost by turning off if possible. The defrost circuit should take care of this but sometimes in very humid weather it does not.
Aug 02, 2017 | Whirlpool GI5FSAXV Bottom Freezer French...
Water on the floor from the defroster.
either the freezer drain is cloged or frozen or ther is condensation still inside the door witch will go away.asuming you got that new gasket to seal right.(the frezer drain is located behind the back wall of the freezer)
Jul 24, 2009 | Kenmore 53092 / 53094 Side by Side...
Condensation on the strip between the 2 french doors
these fridge have a heater in that black flaper to prevent condensation. It is probably not working or not even plugged...do they removed the doors when they delivered your fridge??? remove the uper left cap of the hinge, the connection is there...... the tech must check that piece if it is well plugged..
Jul 03, 2009 | Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ...
I have condensation dripping right behind where the french doors meet on the ceiling of fridge, how can i solve this problem?
Possible that your door gasket is not sealing very well and therefore condensation forms in this area?
Jul 02, 2009 | LG LFC20760ST Stainless Steel Bottom...
Ge armoire style condensation on freezer door
the condensation is due to a small amount of cold freezer air getting past the gasket. Warm the entire gasket up for a few minutes with a hair dryer and then close the door and keep it closed for 30 minutes. That will reshape your gasket and solve your problem.
please rate this answer as a fixya!
Mar 04, 2009 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
73 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
