Question about Elna Sewing Machines
If I buy an Elna Lotus SP sewing machine from the UK, will the voltages/plugs be a problem, i.e. will it suit our 240v power supply?
If it won't fit get it replaced by someone that can make it fit.
Posted on Dec 10, 2016
  • 1,879 Answers
You don't say where you live, but a UK machine will be OK on a 240V 50 Hz supply, as in Australia for instance. However the plugs are probably different so you would need an adapter.
http://www.worldstandards.eu/electricity/plugs-and-sockets/
  • Elna Master
  • 16,199 Answers
If it is a US 110 volt machine it will go bang and set the motor on fire.
However, the supply in the UK is 220 volts, so if yours is 240, it will be fine. The label on the machine will probably say 210 to 240 volts anyway.
I have an old elna lotus sp sewing machine and need to reduce the speed on the foot control is this possible
The Lotus should have the integrated foot controller and power cord in one. Some of these had a switch on the foot controller which reduced the power to half speed. That's the only way to adjust the speed other than the foot on the pedal. The later models Air Electronic have a slide speed control on the front face of the machine which made life easier.
May 06, 2017 | Elna Sewing Machines
How do you adjust the tension control on an Elna lotus SP
The tension dial is on the front of the machine right above the needle. The higher the number, the tighter the tension is applied to the top thread. HINT: When threading the top thread, ALWAYS RAISE the presser foot throughout the entire threading process. This allows the thread to seat completely in the tension disk. Tension is correct when the top and bobbin threads meet in the middle of the fabric.
Elna Lotus Instruction Booklet
Elna Lotus SP bobbin case repair Removing cotton jam from Elna Sewing...
Elna SP ST SU sewing machine repair tips (I use liquid Tri-Flow Synthetic Lube or silicone spray to loosen parts seized from old oil. Do NOT use WD-40, cooking oil, motor oil...)
Apr 29, 2017 | Elna Sewing Machines
Having trouble replacing the bobbin case
Elna SP ST SU sewing machine repair tips - YouTube
? 2:25
https://www.youtube.com/watch?v=TqrbimZyP1U
Oct 24, 2011 - Uploaded by Absolute Sewing
More Photos on replacing gears and some repair ti... ... I amhaving trouble with my Elna SU 62 skipping stitches when I sew on knits. ... Elna Lotus SP bobbin case repair - Removing a cotton jam from a Elna Sewing machine ...
Amazon.com: Bobbin Case 627569106 - Elna, Janome ...
Jan 12, 2016 | Elna Sewing Machines
Manual for elna lotus sp
follow this link for free download
http://www.scribd.com/doc/25386753/Elna-Lotus-Sewing-Instruction-Manual Elna Lotus Sewing Instruction Manual
May 06, 2014 | Elna 2007 Mechanical Sewing Machine
I need a new foot for my old elna, where can I purchase one. Elna SP purchased around 1971 --1972 from White Sewing Center , Cocoa Fla I live in Mount Holly N.C. 28120
you can buy Elna parts from www.whitesewingcenter.com, he specialises in the Swiss Elnas and carries range of stock. Or www.sewingpartsonline.com or www.sewusa.com stock Elna parts for both early Swiss as well as the latet ones. not sure if you meant a pressure foot or the foot control. If its pressure feet the generic low shank feet may well fit your mschine too once you buy the pressure foot adaptor for the newer clip on feet. There was a Lotus Sp and a star SP but the pressure feet were the same with the built in shank you attached with a thumb screw. the air electronics had the adaptor and clip on feet but they have same height and needle position so can use on earlier ones too.
Oct 01, 2010 | Elna 2007 Mechanical Sewing Machine
Manual for Elna lotus sp model 35 m703163
Nov 06, 2009 | Elna Sewing Machines
Part for sewing machine
Raceway drive gear and I think you can only get them from an Elna dealer.
What bobbins will work with a vintage Elna Lotus SP sewing machine?
I did a search and found this post for you. I hope it will help.
The best-known Elna guru is Ray White, aka "Elnaman". He teaches classes on sewing machine repair but his speciality is Elnas. You can order parts or contact him at his website:
http://www.whitesewingcenter.com/index.p…
or you can contact him directly at:
Ray White
White Sewing Machine Center
PO Box 73
Bellview, MO 63623
Phone: 573-697-5841
elnaman@whitesewingcenter.com
You can also join the yahoo group "elnaheirloomsewingmachines" where very knowledgeable Elna owners/collectors share information and answer questions. Enjoy your Lotus!
Sep 02, 2009 | Elna Sewing Machines
Power range / watts for Elna 6005 sewing machine
There will be a sticker or engraved fine print next to the power socket or on the bottom of your Elna that will say what voltages it is compatible with. If it says 110v/220v you can use a plug adapter.Note well that the adapter doesn't change the voltage in anyway it just makes the plug fit. If it only says 110v which is most likely get an AC to AC adapter, **** Smith Electronics or Tandy will be able to help. If you're unsure don't take the risk it will take a second to destroy the electronics if you use the wrong voltage!
Jan 08, 2009 | Elna Heirloom Edition 6005
Sewing Machines Logo
41 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
