Question about Sylvania Televison & Video
I connected my sylvania 20 in tv to my cable box and i dont have a remote and i get sound but no picture
SOURCE: TV not working with remote from Cox cable/Scientific Atlanta
Try the code 052.
Posted on May 18, 2007
SOURCE: codes for sylvania tv
have a 2007 Sylvania 15" (LC155SC8). Misplaced my remote. Had to buy 'LOGITECH' by Harmony.
Cost ( $100.00) programs online to the device you have. BEST BUY ($99.00) RADIO SHACK has them, too.
Good luck
Posted on Mar 06, 2009
SOURCE: i have hd picture but no sound, tv says hdmi audio unavailable
I called Verizon and exchanged my STB from a QIP 6416 to a QIP 7216 and it solved the HDMI audio problem. This looks like the fix.
Posted on May 13, 2009
  • 1077 Answers
SOURCE: cant program direct tv remote with my new sylvania lc320slx
The remote is only programmed with only so many codes. Sadly, It doesn't hold all code for every TV made.
But you can try making the remote search every code stored inside to see if one of them will work.
Here are the instructions form the DIRECTV web site:
You may still find a setup code that works for your device by stepping through the library codes in your remote. The following instructions will help you do this.
  • Set the "Mode Switch" to the desired mode such as TV for a Television.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the code "991" followed by the "device number"
    1. for Televisions
    2. for "AUX 1" devices - VCRs or DVDs
    3. for "AUX 2" devices - Audio
  • You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
  • You can try out each code by pressing one or more function keys such as power, volume or digit keys.
  • When you've found the setup code that works for your device, press the "Select" key.
Posted on May 18, 2009
  • 52 Answers
SOURCE: Cox Cable Remote wont program to my Sylvania LC320ss8 tv.
there are different codes for the devices that you are using. When you want to insert the code for the tv. > Switch tv on and then switch all the other devices off. Insert code. For digi box > switch on and all other devices off. Insert code for digibox. You must then switch between tv and digi box using the buttons on the top of the remote. Toggle between tv/ digi box.
Have a go with the codes below with the tv and the digibox both on, you never know you might get lucky as these are new codes, if not revert back to 1st solution.
Universal Codes (both should work using these, i think!!!!! try 'em)
Here are the codes for the 1st solution.
Good Luck,
Digi Box.
Posted on Jun 18, 2009
I have started setup for hd cable. Am connected to hdmi and have picture and sound but am unable to change channels. What do I need to do.
With the HDTV set for an HDMI Input that matches the HDMI Jack that you've connected to the cable HD STB (set-top-box or "converter"), use the cable STB remote to change channels on the STB - not the TV.
You can not change channels of the STB with your TV remote. You may however, be able to program your STB remote to operate your TV. Most will allow you to power the TV on / off; volume up / down / mute; change input (HDMI1 / HDMI2 / ANT / Composite / etc.) and even some of the more complex functions as well. Contact your cable company for more details.
Feb 25, 2016 | Sylvania Televison & Video
Sound from anything but cable?
Is my TV Teac model LCDV 2010M suitable for connection to digital TV or do I need a "box" for it?
Jul 11, 2013 | Coby TVDVD2050 20 in. TV/DVD Combo
Sylvania 15 inch digital/analog LCD TV HDTV. Once
try doing the auto search method on the cable remote. sometimes this works when the codes do not. if it doesn't then it is what it is.
Jun 26, 2010 | Televison & Video
Our tv doesn't have sound or picture
You need a Digital to Analog converter box as your TV is analog, and all broadcasts, since Last June 12 are Digital.
Apr 16, 2010 | Sylvania 6520FDE 20 in. TV/DVD Combo
I have a sylvania tv, i dont have the remote, i connect a digital reception on it, tv only show one channel, i cant tell if the tv on cable or antena, the menu on the tv is no help, can u help
hmm could that be a "sylvania 6427 gff".. i have seen a suffix of FF, GFF and GFG ... but not TE ... at any rate those are actually CRT displays .. probably the last of their kind ... they produce a really good but standard defination picture ... when you first turn it on it should come up with a setup menu ... if the cable is connecgted at the time it should find at least a few digital channels ..probably no standard channels ...most of those models do have standard and digital tuners but not sure about your TE model might try unplugging your set for a few hours ... when you turn it back on it should come up with the menu system will likely need a cable box to get most of the cable channels... but you may be able to get some could try hookinng up rabbit ear antenna to see what local channels you can get ....
Apr 10, 2010 | Sylvania 6427TE 27" TV
Do I need converter box for my 6720FDE Sylvania?
Jan 06, 2009 | Sylvania 6720FDG 20" TV/VCR/DVD
Picture but no sound Samsung 42 inch
go to the sylvania website,and go to support,there should be a section for manuals there and you can either download it or just read it online,hope this helps.
Dec 07, 2008 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
Lost Remote
usually on some tv s you can get the channel 3 from the MENU of tv , what I can help you with now is the link so you can purchase the original remote , heres the link : , hope this helps AJ
May 14, 2008 | Sylvania 6520FDG 20" TV/DVD Combo
Sylvania 6620LCT
your t.v. defected have a tech repair your is having a problem in the IF circuit.good luck
May 05, 2007 | Sylvania 6620LE 20 in. HD-Ready LCD...
Televison & Video Logo
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
