Question about Dell Inspiron 1501 Notebook
Boots to a grey screen
I have a Dell Inspiron 1545 that when booted goes to a grey screen and stops working, the mouse pointer moves but nothing elsea happens
    Master:
    Sergeant:
  • 226 Answers
Try to reinstall windows
Posted on Jul 20, 2009
  • marcinzajkow
    marcinzajkow Jan 08, 2012
    I can tell you I wrestled with this problem for ages. I had this start at some point without much warning and I thought I was losing my mind. I reinstalled XP, then I installed Vista, then I tried to run all sorts of driver, generic, nVidia, nothing helped. The computer would start, the screen would be grey or show vertical stripes along it. I knew it was not a screen issue because twisting the LCD did not appear to make any changes, I also knew it wasn't the initial wiring because I checked the connection about 50 times along the way.
    What I ended up doing is.
    1.) I took apart the laptop as per Dell's instructions online, there are several steps, about 20 screws, it's not difficult if you are brave enough to do it. It's very difficult to break anything in a laptop unless you are especially forceful and careful to unscrew everything before prying things open.
    2.) I took off the heating core for the Intel Processor and the nVidia chip as well.
    They are two long copper tubes leading to a very fine heating core which combines beside the fan. The whole thing needed a bit of dusting so I naturally did that.
    3.) I carefully cleaned the top of both processors, they have a very smooth surface which is supposed to flawlessly contact a heating distributor and carry the energy out into the fan, there was a grey insulating paste protecting the chips edges but it had gotten between the core and the copper, causing lack of transferrance. Do not leave any oil or residue on the chip unless you want your computer to turn into a bacon pan.
    4.) I replaced the heating core and placed a copper coin (penny or whatever) on top of both heating distributors where the chips would be, I put a tiny piece of hockey tape to keep it from wiggling, this is to create more pressure onto the chip as well as a little bit more room for the heat to distribute through the air. It worked perfectly, my chip slowly recovered and I am playing Starcraft 2 on it without a hitch.
    I'm glad I got through this, it's not the end of the world !
    5.) I said a little prayer.
Erratic pointer
The erratic pointer in the dell inspiron 1545, is a common fault. The usual cure, is to unistall the driver. Reboot install the driver again. Also check your graphics settings. If that doesnt cure the problem. You will need to overwrite/erase your hard drive do a fresh install.
Sep 05, 2014 | Dell Inspiron 1545 Notebook
My dell Inspiron 1545 laptop keeps going to a grey screen EVERYTIME I turn it on, is there anyway I can fix this?
Check the screen by trying an external monitor, I am assuming it boots OK. You don't say whether it does or not.
May 10, 2014 | Computers & Internet
Black screen during log in
Try booting in safe mode by hitting F8 every second after you turn it on until the boot screen comes up. Then select "safe mode" If it loads up in safe mode then delete the graphics driver from Device Manager.
If you were able to delete the driver in Device manager then reboot and get the driver from here:
http://www.dell.com/support/drivers/us/en/04
May 15, 2012 | Dell Obsidian Black 15.6" Inspiron N5050...
I cant move my cursor to my dell inspiron 1545. the touchpad wont work
Connect a USB mouse.
Then, in Control Panel, access the 'Mouse' panel, and "enable" the touchpad.
Nov 26, 2010 | Dell Inspiron 1545 Notebook
The pc starts and the Dell logo comes up but no windows boot
press the Fn Key and the power button see if the diags will run. You may have a hard drive problem or an issue with the operating system
Jul 09, 2010 | Dell Inspiron 1545 Notebook
USB mouse problems with Windows 7 Laptops
You MUST disable digital driver signing to install ANY driver.software on any 64 bit system. you MUST press F8 at boot up to install the driver, & then EVERY time you boot up you MUST press F8 to disable driver signing to USE it too, every time....
Mar 06, 2010 | Dell Inspiron 1545 Notebook
Black screen
That means the Windows "Shell" or Explorer.exe is failing to load. You will have to wipe and reinstall your windows. If you have important data, I suggest you take your machine to a pc shop and have them attempt data recovery.
Dec 13, 2009 | Dell Inspiron 6400 Notebook
No desktop display
Ok. Try pressing ctrl shift and esc at once. Then go to file- run (new task) and in the box type explorer.exe, then press OK. This should solve it.
May 02, 2009 | Dell Inspiron 531 Athlon 64 X2 4400+...
Dell Inspiron 1501 Notebook Logo
550 people viewed this question
Alun Cox
