I have a Martin SCF36M/SCF36MB fireplace with 1 blower that blows toward the inside. Something wrong here? I would love to have a 2 blower setup,FA2 in the manual, but will the same thing happen?
  • Heating & Co... Master
  • 3,087 Answers
If it blows back to the fire then does it not blow hot air out of the vent at the top of the fireplace?
Posted on Dec 10, 2016
Testimonial: "Nope, I get no air blowing out of the top or bottom. The fab just goes on and blows back toward the rear of the fireplace."
  • Paul Carew Dec 10, 2016
    odd sounds like its in the wrong way round
When I turn my electric fireplace on, the fan blows for about 30 seconds and then quits blowing.
How to revive/lubricate your fireplace blower fan or any ...
? 26:34
www.youtube.com/watch?v=JbX_XtKS1p0
Jan 30, 2013 - Uploaded by varietytubechan My fireplace blower fan had stopped working. ... This is demonstrated on a FK4, GFK4, R7-RB74K (Electric Motor Warehouse), HB-RB74K ...
5 Electric Portable Fireplace Repair Tips ' DoItYourself.com
www.doityourself.com/stry/5-electric-portable-fireplace-repair-tips
Electric portable fireplaces are a convenient way to warm a room, barn, patio, ... If the light or coloring of the fireplace is not working, you may need to replace the ... is not working as well as it should, you may need to inspect and clean the fan.
Oct 26, 2015 | Dryers
Elco fireplace blower wont work
If your blower/fan blows air into a "box" with tubes that conduct heated air out through the screen, that assembly may have failed. I had one that burned out and had to be replaced.
Dec 03, 2013 | Leisure HOMEPRIDE Electric Fireplace...
Select Style fireplace blower 293810
The maker of the blower is procom. Their email is customerservice@usaprocom.com. 1-866-573-0674
Feb 04, 2010 | Grilling
I am looking for an installation manual for Model FUBSK blower motor kit. We bought a new home and the Lennox Superior wood burning fireplace Model BC-36 has a switch that should force heat out into the...
The fan should be installed behind the bottom grill, and then it should blow air around the firebox which then exits out the top grill. Now saying that, let me explain the actual problem you will face. Because you have a open faced wood fireplace, you will not get the heat your looking for, the fire needs 400 cubic feet of air per hour and that air is taken from your opening. Also the inner box doesn't heat up enuff to produce alot of heat on the skin so if you have the fan blowing full blast, it will only cycle the air and not allow it time to heat up as it cycles around the box. I suggest turning the fan speed down so its 1/2 way on or lower, this allows the air time to heat while cycling around the box, but in the end you still won't have a good heater as the fireplace itself isn't one, you should look at having it converted to direct vent gas or ripping it out and replacing it with a airtight wood.
Jan 03, 2010 | Superior Lennox Blower Thermal Sensor -...
Best by Broan model IS102 is blowing the air out toward the stove
The blower (motor)has been installed backwards it is impossible for that motor to run backwards sounds like it was manufactured or installed wrong. How old? Has it ever worked right?
Jan 26, 2009 | Broan-NuTone Best by Broan 36quot; U102...
Gas fireplace question
Simulated gas log fireplaces usually don't have a blower of any type. They depend on the radiant and conducted heat much like there was a real wood fire in the firebox. Look in the manual to determine if a blower was included, but I doubt it because of risk that CO would be propelled into the living space.
Jan 15, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Glow warm gas heater does not light
Spiders love gas lines that are not used on a regular basis usually air will not clean them out .try running a stiff wire thru
Jun 30, 2017 | Desa International Blower Glow Warm Wall...
GAS FIREPLACE
Yes, hopefully changing the thermocouple (skinny sensor) or thermopile(fat sensor) would do the trick.
Start with these fairly inexpensive repairs first.
Unfortunately if the honeywell valve is bad a new one can be expensive.
Also it is hard to order parts from Majestic, they just went bankrupt, not to long ago and Martin is taking them over. You might look for your valves model# and check online for other suppliers of that model# or ask for a compatible Direct Vent gas valve that's not as problematic. (eBay and HVAC dealers, etc.)
FYI:
You said it's been about 5 years, you might decide it's less of a hassle to have new gas fireplace installed. Martin and Empire are probably two of the best, with 5 year parts and labor warrantys.
Hope you find some success in your endeavor.
Dec 10, 2008 | Honeywell Electronic Programmable...
Chicagao electric fireplace heater doesn't work
MY HEATER NOT WORKING,BLOWER AND LIGHT COME ON NO HEAT
Oct 25, 2008 | Heating & Cooling
Heating & Cooling Logo
82 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
