Question about Vacuums
Just bought the V8. Which cleaner head is for carpets?
Roller brush working but can't push cleaner forward on carpet. Front digs into carpet
Had the very same problem when I installed new carpet in my home. It was essentially "unpushable". Called Dyson and they said to remove all gaskets from the cleaning head. I was skeptical, but it worked.
Nov 29, 2015 | Dyson DC14 All Floors Upright Vacuum...
I can't push my Dyson Dc33 on my new carpet..it works backwards ok but not pushing forward?
Hi Fran, it's Jack at Dyson.
DC33 is engineered to work effectively on both hard and carpeted flooring. The cleaner head is engineered to adjust automatically for different floor types and carpet piles. You can also turn off the brush bar for hard floors and delicate rugs, using the brush control on the cleaner head.
I'm sorry to hear you're having difficulty pushing your machine forward on this particular type of new carpeting. If your DC33 worked effectively before the new carpeting was fitted, it doesn't sound like there's an issue with the vacuum itself. However, we'd appreciate the opportunity to take some further details about the issue, and may be able to suggest a resolution. You may also want to consider contacting the carpeting manufacturer directly, as they should be able to recommend the best way of caring for this specific carpeting.
When you have your DC33 easily to hand, please give the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Feb 13, 2015 | Dyson DC33 Multi-Floor Upright Bagless...
How does the carpet cleaner work
Resolve carpet cleaner is a cleaner specifically designed to work on carpets. Resolve comes as a steam concentrate, a powder, a foam spray, or liquid spray. Before using the carpet cleaner you should vacuum the carpet. Resolve carpet cleaner works by being applied to the carpet then worked in with a soft bristled brush. Depending on the cleaner, it will be sprinkled or sprayed onto the carpet. Use the brush to work the cleaner down into carpet fibers. There is a waiting period for the cleaner to work, then you vacuum the cleaner out of the carpet.
Apr 25, 2014 | Electrolux Sanitaire SC688A Upright...
Kirby ultimate g vacuum cleaner (not the shampooer) leaving white marks/trails all over brown carpet
This is not a normal occurence...maybe something the previous owner did or used the vacuum on?? A KIRBY will not normally leave any marks on Your carpet..
Lee in Australia
Oct 14, 2012 | Kirby Ultimate G Bagged Upright Vacuum
I have a 5 year old Dyson DC07 animal vacuum cleaner. I'm having problems with the vacuum strength when cleaning the carpet but not when using an acessory to clean the stairway carpet. Any possible
Hi Ronald,
I'm sorry to hear you're having difficulties with your DC07. If your machine picks up well through the hose, but not through the cleaner head, it's likely that you have a blockage in the cleaner head.
The easiest way to locate and remove any obstructions is to follow the steps shown in our online support guide:
http://www.dyson.com/support/help.asp?article=4&product=DC07-ANIMAL_US
It's also a good idea to give the filter a wash - in normal use, this should be done at least once every 3-6 months, as shown in the video below. Use cold water without detergent, and allow at least 12 hours for it to dry completely before replacing it.
This should resolve your issue, but if you have any further questions, please get in touch with us directly on 0800 298 0298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Online Customer Support
Nov 28, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Where is the belt located on my hoover steam shampoer
There is probably not a belt. The brushes on the carpet cleaner head and attachments work from air and there is a roller bearing deep inside that will wear out and the brushes won't turn. I've found no way to fix this. I consider it a design defect.
Apr 20, 2011 | Hoover SteamVac Carpet/Upholstery Deep...
Why wont my kirby carpet cleaner pick the foam and water off the carpet leaving my carpet soaking wet?
Is the carpet washer attached to unit is the belt hooked up? don't use the vacum head you well get shocked.be careful
Jul 26, 2010 | Kirby G6 Bagged Upright Vacuum
How to change the belt on a bissell powerbrush deep carpet cleaner.model 1694
Turn the machine OFF (O) and unplug from
the outlet. To check if the brush belt or
pump belt has broken, you will need a flat
head screwdriver. Insert the blade end into
the lower slot of the belt access door to
release the lower snap. If necessary, insert
the blade end into the upper slot to release
the upper snap.
Hope this helps.
Richard
Mar 10, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Carpet cleaner will not suction up solution
Check for any cloggs in the hose lines. And make sure the recovery tank is not filled. Close to %95 of carpet cleaners have a shut off float of some sort which will close off the suction to the head of the machine if the water lever gets too high. Also check the shut off float to make sure it is clear of any build up. If the float is clogged, it will keep the suction closed off from the head. If this is the case, clean the float off and it should open the suction path.
Jun 17, 2008 | Hoover Vacuums
Vacuums Logo
27 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
