Question about Dryers
Moved the bed and now when it turns on the timer goes to 0 and does nothing
I have a sunvision pro 28LE tanning bed. 2007 model. How do I check to see how many hours are on the bed?
Page 18 - http://tanning-bed-parts.com/documents/ETS%20Tan%20Documentation/Manuals/25108-01a.pdf
To determine how many hours the unit has been in service (since the last reset of the hour counter memory), first make sure the timer display shows "0". Then simply hold the stop button for three seconds. The display will show two pairs of numbers which indicate the number of hours of service, then return to "0". (example: Display shows 08 then 54. This equals 854 hours.) NOTE: If the unit is connected to a T-Max® remote device, it may briefly lose communication with the remote. This is normal.
Jan 06, 2018 | The Health & Beauty
Diagram of wires for a 30 minute timer on a tanning bed
http://waterheatertimer.org/How-to-wire-timers.html#spa
Identify timer on link above and follow wiring diagram.
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 25, 2014 | Hardware & Accessories
We moved the bed and now the lights dont come on and it makes a loud noise .
Having the same exact problem! Any luck fixing it? If so please send help my way!
Apr 10, 2014 | Wolff Sunvision Pro 24S Tanning Bed
My dryer model dv231aew/xaa Will not shut off unless you open the door....on/off & pause shows its working but its not
follow this steps and fix it. Merry Christmas
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is faulty replace it. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. Replace the heating elements.
Dec 17, 2013 | Samsung DV231AEW 7.3 Cu. Ft. White...
We just opened up a tanning salon. The beds are on individual timers and we were trying to hook up the timers to a main computer in order to be more efficicient. The timer locked up when we entered the...
is there a key lock? if so, locate the key lock at the front left of the timer and then insert the key, turn it clockwise and hold it for 5 seconds. other timers have a card to scan to unlock.
Mar 03, 2013 | Health & Beauty
Sunquest 24s wont do nothing
Have a trained technician to check for blown fuse on back of bed and then for burned out wiring in top and/or bottom of bed. Voltage going to bed may also be a cause. These beds are sensitive to wrong voltages.
Dec 21, 2012 | Wolff Sunvision Pro 24S Tanning Bed
2003 SUNQUEST PRO 24RS MANUAL TANNING BED
I Have a m2 24rs8 tanning bed. I loved it . I have moved it was in storage for 2 1/2 years. Moved to a new house. I hooked my bed up. the only thing it does kinda turn the fan on. what have I done wrong....It is on a 20amp bracker. Wire is 12 2 with ground. HELP PLEASE
Aug 25, 2012 | Wolff Sunquest Pro 24RS 220 Volts
Timer will not go back to 0 / Light below oven setting remains on
Try and get the timer to zero, as soon as the timer is on zero the light under the oven setting knob will turn off.
Jun 24, 2009 | Ovens
Question for Techman
Sorry DrMike, I thought you could set the timer to 0. You did state that the timer was set to off correct?Let me do a little asking my LCD buds in the repair field.
Jul 30, 2006 | LG 42LP1D 42 in. LCD HDTV
Dryers Logo
27 people viewed this question
Top Dryers Experts
