Question about Dayton Heating & Cooling
Dayton (3UG73) Electric Utility heater will not turn off. I see questions about not turning on but what are the causes if it won't turn off?
  • 8 Answers
SOURCE: Use Breaker for Switch?
Thats ok, but i would put a thermostat switch on it also !
Posted on Jan 07, 2009
  • 8 Answers
SOURCE: dayton electric garage heater
need to check you fan wires, some have differant colors on the moter for the differant speeds, you may need to change the fan speed by unplugging one of the wires and replacing it with another. hopefully you still have the manuel , check with it first!!!
Therinnaiguy
  • 1420 Answers
SOURCE: I've got a Dayton 3E369 Unit heater. The electric
Sounds like it has a bad fan switch wich is no more than a small circular bi-metal switch that expands when heated closing a switch. Get a parts breakdown off the net. I am sure you could find the switch in your area and replace it yourself.
Posted on Oct 21, 2009
koolbreezes
  • 540 Answers
SOURCE: Dayton G73 Utility Heater will not shut off until
Its probably trying to tell you something is wrong with me.. find the root cause!(like the fan motor is stopping and then the heat builds up and tripps the high limit switch!
Posted on Dec 22, 2009
SOURCE: Dayton 3VE59 Gas Utility/Portable Heater won't
Just repaired one of these, problem was that main gas valve was not opening, valve is controlled by a vacuum switch, vacuum is created as fan blows air down tube past bent up metal flap near front bottom of heater (slight low pressure zone created). If vacuum switch is miss adjusted it will not close when fan is running and no gas flows. this is easy to check as vacuum switch also has a pressure port on it. With gas disconnected, remove bottom cover, locate vacuum switch (it has a hose clear plastic hose connected to it, in opposite corner is another hose connection, attach a length of hose to it that you can blow lightly into. With heater plugged in and no gas connected (USE CAUTION OF WIRE!!!), turn heater on you should hear after a few seconds the ignition and then a loud click as the gas valve opens, if no click blow lightly into end of your added tube, if you now hear a click the gas valve just opened. if you stop blowing you might hear the gas valve click again as it re-closes. If this is the case the vacuum switch needs to be adjusted slightly. THIS switch is hear for your safety, Adjust at your own risk!!! This can be done with a screw drive in the top, rotate screw slightly while checking if the fan alone causes enough vacuum to make the switch work. DO NOT over adjust. check safety operation before hooking up gas by placing a piece of cardboard or wood over the air intake and the exhaust to block airflow, if the air flow is blocked you should hear the gas valve drop out and reconnect as air flow is reestablished. Hope this helps
Posted on Feb 13, 2011
Need fan motor for model 2E440
Try Grainger
dayton 2e440 heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
... a Dayton Model 2YU40 electric heater Need manual for Dayton. ... looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Dayton rheostat fan motor Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > rheostat fan motor > Heaters
Dayton heaters rheostat fan motor related questions and answers. ... UP BUT FAN WONT KICK ON Could be one of several problems dependant on the model you have.... The motors are noisy in 2 Dayton 2e440 heaters. I ... I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
DAYTON Electric Wall Heater, Recessed or Surface ...
www.grainger.com/.../DAYTON-Electric-Wall-Heater-3...
W. W. GraingerShop DAYTON Electric Wall Heater, Recessed or Surface, Voltage 208/240, Watts ...Item # 3UG56; Mfr. Model # 3UG56; UNSPSC # 40101814; Catalog Page # 4277; Shipping Weight 20.65 lbs. ... Additional features include a built-in thermal cutout andfan delay switch for added safety ... Need Help Finding Repair Parts?
Jan 09, 2016 | Dayton Electric Heater
My Dayton (3UG73) kicks on for 30 seconds then kicks off for a couple of minutes then back on again. how and what can i test.
Check out the snap discs sounds like its cutting off too soon jump them out 1 at a time , or check flame sencor is clean
Nov 16, 2012 | Dayton (3UG73) Electric Utility Heater
My incoming voltage is only reading 200v, will this stop the unit from running??
If it needs 208 or 220 then yes it will stop the unit from running.Check the voltage at the circut breaker to verify its not a wiring issue.
You may need to get a new circut breaker.Also check a 115 volt outlet if its is also reading low ,like 100 or 105 volts then the power ccompany is cutting power back and theres nothing you can do.
Jul 20, 2011 | Dayton (3UG73) Electric Utility Heater
I NEED TO REPLACE THE THERMOSTAT WHERE IS THE
Dayton is a product of Grainger Industrial Supply. Here is a link to their website. You can order parts online or search for the location nearest you.
http://www.grainger.com/Grainger/wwg/start.shtml
Mar 19, 2011 | Dayton (3UG73) Electric Utility Heater
Hi, I have a Dayton 3ug73 heater. The heater will not shut down after the initial heat requirement is met. I have the thermostat set on low but it continues to heat. I shut the power off to it to keep...
It sounds to me like your thermostat may be bad. I would check power incoming to t-stat then turn temp. setting up and down to see if it is switching on and off. If not then replace. If it does then I would check all wiring to gas valve and if power is shutting off to valve but burner continues then replace gas valve. Thank you.
Mar 07, 2011 | Dayton (3UG73) Electric Utility Heater
Where can i get a replacement heating element for my Dayton (3VU31) Oil Filled Electric Utility Heater
Most likely Grainger. You might want to call them as their website can be a little tricky to find parts.
Jan 31, 2011 | Dayton (3VU31) Oil Filled Electric Utility...
The heater operation is very noisy compared to new. Perhaps it's the fan? The heater is six years old and I'm concerned that it may cause a fire.
Its most likely the bearings in the fan motor failing causing vibration. One simple way would be too check and make sure all nuts and screws and bolts are tight around th e fan. If so is the fan blade dirty it doesnt take much dirt on a fan blade to get it out of balance and cause bearing failure.
Dec 13, 2010 | Dayton (3UG73) Electric Utility Heater
Need to know what size wire to use to wire up a DAYTON GARAGE HEATER model 3UG73 10/2 or 10/3NM to a 30AMPS circuit?
You want to use the 10/3 wire... the red and black are the hot, the white goes to the nuetral and the green/bare wire to the ground.
Use a 30 amp 2 pole breaker..
Heatman101
Feb 24, 2010 | Heating & Cooling
Dayton g73 electric heater less than two months old and thermostat goes out any ideas
I WOULD TRY TO BYPASS THE THERMOSTAT TO MAKE SURE THE UNIT WORKS AND REPLACE THE THERMOSTAT IF IT DOES , SEE IF IT IS UNDER WARRENTY, MY GUESS WOULD BE THAT IT IS JUST DEFFECTIVE, AND YOU ARE TRYING TO FIND A CAUSE, THIER IS NO REAL CAUSE THAT I CAN THINK OF THAT WOULD BURN UP THE THERMOSTAT IF IT WAS OR HAS BEEN WORKING, GOOD LUCK
Jan 26, 2010 | Dayton G73 Utility Heater
Nov 17, 2008 | Dayton Electric Heater
Heating & Cooling Logo
27 people viewed this question
Top Dayton Heating & Cooling Experts
paulcarew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
