My dvd player in my 2007 gmc acadia when i put in a disc it says optical error, what do I need to do to fix it?
SOURCE: GPX Portable D.V.D Player : No Disc/ DIsc Error
I check the motor. for sping its good. clean the liner eye it's good also check for bad hardness connection it,s with um meter. ok what can it be
Posted on Nov 18, 2008
  • 14 Answers
SOURCE: how to change the headlight on gmc acadia 2007 (driver's seat)
the low beam bulb?? it's not that hard turn the wheels to gain access to the wheel well and loosen the inner fenderliner (plastic) to gain access to the back of the headlamp assy
Posted on Jun 23, 2009
SOURCE: my vrvd640g car stereo/dvd/cd player
my vrvd640g is is stuck on a loading screen i try everything for this item i have press the reset button.... what can i do for this item....
Posted on Jul 13, 2009
SOURCE: Disc error
when i press play on my dvd/cd player it says error
Posted on Feb 01, 2010
  • 401 Answers
SOURCE: how to replace headlight on 2007 gmc acadia
first if you are changing the bulb only and it is a HALOGEN
there is a round acess hole in the inner fender remove it and change the bulb
if you have HID lights or are changing the head light assembly then you have to remove the front bumper facia
hope this helps
hope you have HALOGEN lights
Posted on Feb 12, 2010
My DVD player and navigation won't work. I put the desk in the correct ports and the screen says DVD read error. What a blown fuse cause this not to work. 2007 GMC Acadia.
Most likely something is wrong with your DVD/NAV unit. It shouldn't be a blown fuse as the screen and unit would not power up if the fuse was blown.
Hope I helped,
Luke
Sep 04, 2015 | GMC Cars & Trucks
Where are the fuses located on a 2007 GMC Acadia
On this website (link below) you find fuse box diagram and description for GMC Acadia First Generation
GMC Acadia mk1 First Generation 2007 2008 fuse box diagram Auto Genius
Jun 24, 2014 | 2007 GMC Acadia SLE
GPS indicating check map dsc error
This is a common navigation radio issue on this vehicle. The message "Map DVD read error" comes on randomly.... sometimes it works, sometimes it doesn't. Make sure your Map DVD is clean and without fingerprints or scratches first. If it the disc is okay, the issue, unfortunately, is within the radio itself. The only correction I've seen for this problem is to replace the radio itself. Also note, that if the radio is replaced, it will have to be reprogrammed by a GM dealer to correctly set up your vehicle's options and learn the vehicle's VIN so the radio will unlock.
Mar 19, 2013 | 2007 GMC Acadia SLE
I have a Cyberhome 300 DVD player and whenever I put in a disc it will say loading for 2 seconds then gives me the message of no disc. I took the outer casing off of the player to reveal the drive itself...
Good day!!!
That problem is cause of dusty or defective optical cd lens..
please try to clean it the lens or replace it to fix your problem..
if you need specific solution and more help...Please try to click this "
Fix No-disc error on DVDs" and try to purchse my service..
Thank you for using fixya..
Oct 06, 2011 | Cyberhome CH-DVD 300 DVD Player
When i insert disc ERROR is displayed,tried 3 discs same display there is nothing in the manual that discribes this error,i put the first disc in and it started playing then suddenly stopped and error was...
The Disc Players optics are either dirty and need cleaned, or the optics are out of align and need replaced/repaired, depending on the make and model. If you have a DVD Player cleaner, one that uses fluid, run it thru a few times and try again. If you do not have one, most convenience stores carry them now and will clean all CD/DVD/Home/Auto models, and is a good investment! Just make sure you get a cleaner that uses fluid. Hope this helps!
Jun 01, 2011 | Audio Players & Recorders
The cd player on my 2002 gmc envoy reads 'player error'. How can it be fixed?
purchase an optical disc cleaner disc and put it in your cd player and let it play through and then try a cd. make sure your cds are clean, smudge and not deep scratches. toothpaste makes a good cd cleaner for scratched discs. make sure to use soft cloth
Jul 14, 2010 | 2002 GMC Envoy
I get a no disc error and so far blowing air in it has not helped
It sounds optical laser lens is dirty and need cleaning.
Put lens cleaning disc in player and press play, disc will spin and might clean lens to solve the issue.
If that does not fix the problem, unplug player from wall socket, take off top cover and clean lens with good quality cotton bud gently and then check does it play disc. If problem still exist then optical lens got defective and need to be replaced. Local tv repair shop will replace it but replacement would cost you much.
Hope these info will help you.
Thanks.
Jun 09, 2010 | Philips DVP642 DVD Player
I am getting same Incorrect Disc error on any dvd.
plz check your optical lence (laser assembly) when it become weak then it shows like that.
solution:- remove the optical head of the dvd player & replace same one.
thanks
Sep 12, 2009 | Toshiba D-VR4 DVD Recorder/VCR
2007 gmc acadia headlight
Yes, sir. That is quite correct. Part of the standard guidelines in servicing headlights. : )
Aug 03, 2009 | 2007 GMC Acadia SLE
Disc error
HI. if this error is coming up on every disc you insert, this will be a sign of a serious malfunction that is localized in the optical lens assembly. It could eb that the tracking rail motor is damaged or, the entire assembly is not functioning. replacing this failed assembly will fix this issue.
May 29, 2009 | Toshiba SD-2700 DVD Player
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
