Furnace pilot won't stay lit when I release the button
  • Heating & Co... Master
  • 14,910 Answers
If it doesn't light after holding it 2 full minutes, you need a gas service engineer to install a new thermocouple. It is a safety device.
Posted on Dec 10, 2016
SOURCE: Unable To Keep Pilot Light Lit!
I have a Williams top vent gravity wall furnace (model 5009622) and I had the same problem. I had to take the cover off the furnace -- screw on top and two at the bottom (open the access door and there is one screw on each side) to get to the reset button for the vent safety shutoff system. On my furnace it's on the left side toward the top of the unit. I pressed the little red reset button and it's been working ever since. If your furnace is properly installed and doesn't have bird's nest in the chimney, it should work fine. Good luck!
Posted on Dec 06, 2007
arealplumber
  • 33 Answers
SOURCE: pilot lite will not stay lite
You need to change the thermocouple on the unit.
First check to see if the flame is hitting the thermocouple when the flame is on when you hold down the button. If it is then remove the the thermocouple and replace with the same size. You should be able to pick one up at your local hardware store.
If when you replace the thermocouple the flame does not stay lit still you may have a bad gas valve.
Hope this helps and please rate this!
Posted on Dec 08, 2008
  • 108 Answers
SOURCE: pilot light wont stay lit
You need to replace the pilot safety switch which is usually a Thermocouple. It is connected by a thin tube from the gas valve to a bulb near the pilot burner. It should be available at Home Depot or online.
Ray
Posted on Dec 17, 2008
tborn6
  • 700 Answers
SOURCE: Rheem furnace RGDG-100AUER - Pilot does not stay on
replacde the thermocouple and you should be all right.
Posted on Apr 05, 2009
billyvangogh
  • 108 Answers
SOURCE: pilot is lit but the furnace won't fire up
Hmm...well need more info...is the furnace switch on???? The breaker may have tripped...try the fan on Manual at the thermostat and verify the power is on....it really can be many things...need more info
Posted on Oct 26, 2009
Pilot light wont light
Rita, Check the attached links,instruction and guides to trouble shoot pilot light, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Gas Heater Pilot Light Troubleshooting
What to Do if Gas Furnace Pilot Light Won Stay Lit DoItYourself com
Furnace Won Ignite Why and What to Do
Aug 03, 2016 | Heating & Cooling
My heat won't come on.
Newer furnaces do not have a pilot light. If yours does, you will have to relight it. Find the gas valve inside the furnace and follow the lighting directions. Generally, you turn the valve to the pilot position, press a button and hold it while you light the pilot. Hold it for about a minute and then release. If the pilot stays lit, then you can go ahead and set the thermostat to call for heat. If it does not stay lit, or the furnace still will not light, I think you need to call a repairmen or someone with knowledge of how to troubleshoot the problem.
Mar 21, 2014 | Heating & Cooling
Furnace Pilot Light Won't Stay Lit
Here is something similar that happened to me. I went through the same steps you went through and upon closer inspection, I found a spider had made a web inside the supply line only letting a small trickle of gas through. Have you verified there is nothing blocking the line?
Oct 02, 2012 | Heating & Cooling
When I tried to light my furnace, the electrical wires from the thermostat don't spark all the time, therefore my furnace won't stay lighted. What can I do to fix this?
Is this an older furnace where you have a pilot light? Are you saying the pilot light will not stay lit? If thats the case then likely you need a new thermal couple. That is what the pilot light keeps hot while it stays lit. It is a safety device that is there so your furnace will not come on if there is no pilot light present. Very common. Hardware store item. Need Furnace's make and model #'s.
If this is an electronically controlled furnace, you will need a service call.
Jan 13, 2012 | Heating & Cooling
Pilot won't stay lit on furnace
Is that pilot automatic? If so then a quick easy fix for this is to located the sensor and replace it or clean it up with sand paper. After ignition the control is looking for verification of ignition from that sensor. How to videos
Sep 30, 2011 | Heating & Cooling
Pilot wont light
If the pilot light goes out when you release the primer,then the thermocouple is bad.You can try to adjust the thermocouple,if it can be.It needs to be in the pilot flame.If the thermocouple is not in the flame,it will not stay lit.If you can not get the pilot to light at all,with the primer pushed down,then replace the regulator.To light the pilot light,you need to turn the dial to pilot.Then press the primer button down and hold it.The primer is either built into the turn knob,or it is a res button.Hold the primer down,and light the pilot,continue holding the primer down for at least 40 seconds.Then release the primer slowly,and if the pilot light starts to get weak,and try to go out,then push back down,and hold 30 seconds more.After the pilot stays lit,turn the knob to furnace or low,or whatever the directions say.
Oct 19, 2009 | Heating & Cooling
Mar 04, 2007 | Williams 2509612 Ceramic Mid-Size Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
