Question about Home
Wuersch mantle clock is losing 5-10 minutes a day
  • 16,249 Answers
Take it to a watchmaker or jewellers for service. Generally a sign it needs cleaning.
Posted on Dec 10, 2016
Ethan Allen mantle clock chimes incorrectly on the hour how can I fix it. It is a wind clock
The next time it chimes multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it chimes signaling 15 minutes after. Now put the minute hand back on pointing to 3 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
Jan 08, 2017 | Home
How do you oil a Howard Miller mantle clock
If your mechanically inclined, and are feeling a bit adventurous you could purchase a bottle of Clock oil from either your local clock shop, or online. A small bottle will last a long time.
It's best to let the clock run completely down first. Set your time to 12:00, remove the hand nut that holds the minute hand on, and remove the minute hand. Remove the hour hand by pulling out away from the dial. Look inside the case, and remove the screws that hold the movement in the case. Remove the movement carefully making sure not to touch the escapement. Now you have access to all the bushings (small dots where the gear arbors show through the plates) front, and back. Clean off any buildup you see on the bushings with say a cotton swab, toothbrush, pipe cleaner, and a descent remover. I use Goof Off if I'm out in the field cleaning a floor clock. After your sure you've wiped off all residue you now put a very small drop of oil on each bushing. Now work the oil in by using a pair of tweezers to wiggle each gear back and forth between the plates. Do not get oil on the gears them selves just the bushings on the out side of the plates. Now put it back in the case with the screws you removed, put the hour hand back on positioned at the 12, put the hour hand back on also positioned at the 12 so it's showing 12:00, and tighten the nut finger tight. Don't over tighten.
Winder up, set the time, and see how it goes. Buzz has the better idea though, and your local clock shop could probably use the business. Good Luck
Dec 30, 2014 | Howard Miller Urban Mantle II Mantle Clock
How to set chimes on seth thomas mantle clock
The next time it gongs multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it strikes once. Now put the minute hand back on pointing to 6 o'clock and replace your dial nut and you are all set.
Aug 31, 2014 | Home
My Welby mantle chime clock loses time, how do I increase the time speed?
You can speed up or slow down the clock by adjusting the length of the pendulum. This link will walk you through the process.
http://usedclockparts.com/9-clock-case-repairs/31-how-to-speed-up-or-slow-down-your-clock-using-it-s-pendulum
Jul 07, 2012 | Seiko Mantel Clock
How to co-ordinate chimes on SWeiko QF141S mantle clock
May 19, 2012 | Seiko Mantel Clock
The chime of my Howard Miller mantle clock are not w/the actual hour set.How can I reset the chimes? Daylight Savings time has messed me up.
Nov 06, 2011 | Seiko Mantel Clock
I need a Howard Miller battery mantle clock
Try www.klockit.com. You can replace the entire movement for about $5 including new hands. You can select from an assortment of hands that will probably match the style of what you have and use those if the old hands don't fit the new movement. I've bought several movements from them over the years. For a few more dollars you can upgrade to an "atomic clock" movement which synchronizes with the US time signal and even sets DST automatically.
Apr 14, 2010 | Seiko Mantel Clock
Forrestville mantle clock
RECOMENDATION:
Seek professional help.
For this question it will be hard to evaluate it from here.
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Mar 22, 2010 | Watches
Home Logo
54 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
