Question about Crafts & Hobbies
I have a post war 1945 Z-type transformer American Flyer train set I have never hooked One up before need help
SOURCE: Need help setting up Lionel North Pole Central
I had the same dilema and trains are not new to me. Look under the piece of straight track that has a notch in it for the wiring. There will be a clip to hold the wire and a piece of plactic that looks like a block. One either side of that is a metal tab that one end of the wiring slides over. Actually each piece of the Fastrack has one of these. Only one has a notch but you can notch any one.
MHC
Posted on Dec 04, 2009
SOURCE: Need Z4000 transformer (trains) manual
We were able to locate a Z4000 transformer manual. Found out our problem was a connection problem with the track and not a problem with the transformer. Thanks anyway.
Posted on Jan 01, 2010
GodBlessU
  • 3513 Answers
SOURCE: I have two 380 Holiday
Sorry to say but New Bright does have these replacement parts hence you need to try hardware stores to see whether you can get a similar adapter . Check the V and the power it should not be an issue.
Thanks
Posted on Dec 24, 2010
  • 2418 Answers
SOURCE: The Cw 80 watt transformer
If you have a volt meter you can check the rails for power, Check the transformer wiring to the first rail connection and then along the rails for loss loose connection(s). If you have power to the rails it is an issue with the Engine, Check any brush or rail riders (connections) for a bent or broken tab. If for a temp fix in a broken connection tab or brush you can use Tin foil. Hope this helps.
Posted on Dec 25, 2010
ftw1952
  • 10319 Answers
SOURCE: how do I replace the
These transformers are fusioned together which takes a skilled hand with a hot blade to separate the bottom from the top shell. Hot blades are commonly used by glass repair techs that replace windsheild on vehicles
Posted on Aug 26, 2011
Seating plan for a boeing 777 in the economy section
Seat map Boeing 777 200 American Airlines Best seats in the plane
Qantas never crash @2:30
Rain Man Airport Scene
well there was one flight that did crash and burn in 1945 in queensland australia flight out of archerfield qld... it was the war .
Mar 21, 2017 | Cars & Trucks
When my soon put his pennsylvania flyer train set he unhook the wiring to the fasttrack itself. How to we put in back on the fasttrack?
turn the terminal track(where the wires were connected) over,
you should see 2 screws where the wires were attached.
loosen the center rail screw, strip the wire with the red end back - 1/2 inch on the end that was attached to the screw, place wire around the screw & tighten. repeat with the other wire attaching it
to the screw on the outside rail where it was previously attached.
reconnect the terminal track to the rest,connect to your transformer
and play with your train.
Dec 11, 2014 | Crafts & Hobbies
Lionel f7 only runs in reverse
Have you checked to see if the direction switch is on? Most Lionel locomotives can be set to run in one direction by turning the direction sequencing off. This is true for the newer electronic direction circuits and the older electromechanical E-units. Sometimes the direction units fail and the locomotive will only go in one direction or sits in neutral. If that is the case, the direction unit will need to be serviced (mechanical type) or replaced (electronic type). Go to Lionel.com for additional information and help.
Mar 03, 2014 | Lionel Trains Santa Fe Flyer Freight Train...
OVERLOAD LIGHT ON TRANSFORMER IS ON
FIND OUT HOW MANY AMPS MAX YOUR TRANSFORMER IS RATED FOR, FIND A AMP GAUGE 'SAY ON EBAY, THATS ABOUT 5 AMPS MORE THAN YOUR TRANSFORMER IS RATED FOR, HOOK IT IN LINE AND YOU WILL BE BETTER ABLE TO MONITOR LOADS THAT ARE PUT ON YOUR TRANSFORMER. AND IT WILL SAVE YOUR TRANSFORMER FROM COOKING . TRY TO FIND LED BULBS FOR YOUR STREET LAMPS AND OTHER LIGHTS, THIS WILL DROP THE LOAD ON THE TRANSFORMER.. HOPE THAT HELPS YOU .. JAY FLORIDA
Feb 02, 2012 | Athearn Ho Rtr Union Pacific Train Set
Can I use the cw-80 transformer on any Lionel train set from year 1948 to the preasant , thanks George
You should be able to. The Lionel transformers all put out AC power, not DC and many Marx and American Flyer transformers will work too. The real question is total amount of power being drawn and whether or not you have the wattage to match your engine and accessories. With the CW-80 though, it should put out plenty. I run my pre-war 1666E engine pulling a full compliment of metal cars with no problems using a CW-80.
Feb 05, 2011 | Lionel Cw 80 Transformer
I bought the 6-30089 Pennsylvania Flyer Train Set last year. It's been in storage in the original box in a cool, dry place since last Christmas. I put it together, but it will not run. There is power to...
Hope you got the set working. If not, look underneath the locomotive near the rear (under the "cabin"). There are two switches, one on either side. One says "Smoke", the other says "Reverse". If the "Reverse" switch was set to "Off" when the locomotive was in Neutral, it will stay in neutral even when the power is cycled or the "Direction" button is pressed on the power supply. Even in Neutral, all the lights will work and I believe the smoke element will heat up but won't puff. Whatever setting the "Reverse" switch is on, try changing it to se if that works. Hope this helps...
Dec 04, 2010 | Lionel Pennsylvania Flyer Train Set
The green light on the transformer isn't going on
The Green light on, But flashing and the train don't move
Nov 15, 2010 | Lionel Cw 80 Transformer
Ι've just joined 2 ovals 40x60 lionel fastrack, used some other items 2 Lionel 6-12018 FasTrack O-36 MANUAL SWITCH RH, 2 Lionel 6-12017 FasTrack O-36 Manual Switch LH, A few 6-12014...
It sounds as though you may have two defective transformers. Lionel has reported problems with some of their smaller transformers. I would have the transformers and the engines checked by a Lionel service station or contact their customer service department for help.
Nov 12, 2010 | Lionel 40 Watt Transformer Train Set Track...
Runs only in reverse i have other pre war 1681e does the same
Have you changed transformers? You can also make a Lionel run in opposite direction by using the throttle control...just go to stop and then to power and then back to no stop and right to power. That often works.
Apr 30, 2010 | Lionel Trains 51009 Prewar No 246e O Gauge...
Crafts & Hobbies Logo
93 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
