Question about Vacuums
My rug doctor (wide track) started making a,loud noice. I thought it was a belt broke. I can't find that they sell belts. Wondering is it the motor? Or something else?
    Top Expert:
  • Vacuums Master
  • 48,294 Answers
Best take it to a vacuum machine repair shop and have a proper diagnosis of the problem done
save a lot of guess work and money
Posted on Dec 10, 2016
How can I stop the squealing noise in the motor on my Sanitaire wide track commercial vacuum? It's making a squealing the minute I turn it on
Is it the motor or the brush roll? Remove the brush roll and belt and see if it still squeals. If not clean or replace the brush roll and get a new belt. Inspect the fan to insure there is not something stuck in it. If it's the motor you can try to clean it, make sure there is not something stuck in the motor causing the noise.
Jan 23, 2017 | Vacuums
Red button activates the pump, brushes and suction is my guess and pumps can be noisy. You could phone the rental place and ask. As long as it cleans your carpets, all is good.
Feb 17, 2016 | Rug Doctor Wide Track Carpet Cleaning...
Bissell model 1694 rug scrubber works for a while then makes a loud noise when you pull it toward you like it is. Umping over something, roller is very easy to pull on, is it loose or a belt?
Dear Sir:
Possible the motor can be faulty, or test the belt if is crack and replace. However you must see if there are some debris inside. Please see the section troubleshooting in your user manual. Download or or www. or
God bless you
May 26, 2012 | Vacuums
Dyson makes loud noise
Could be damage to Fan within motor or shaft on motor..Remove brush roll and run with nothing connected to motor ,if noise still appparent then sounds like one or the other if ok then check for damage to the brush roller.../Housing..good luck
Mar 31, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Bottom roller bush does not spin
Sounds as if the v-belt came off the idler arm or you broke the v-belt. Either way, take the 4 screws out of the plate around the roller brush and make certain the belt is there and that it sits on the idler wheel. If you remove the roller brush you'll see the wheel. Pay attention to how the ends of the roller brush go back into the vacuum when inserting it and put the plate back on. Also check the thicker main belt is in place as well, it's to the left of the v-belt.
Also, the roller brush should stop when you put it in the upright position. Next time just stand it upright so the throw rug doesn't get drawn quite so far into the vacuum.
Dec 19, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
My Rainbow SE vacuum was working fine until I ran over the edge of a rug and it went in to the nozzle. I immediately switched the vacuum off and proceeded to move the rug. When I tried to turn the Rainbow...
hello lilbutmunch1,
The brush is motor/belt driven so you probably either broke the belt or it shifted off the motor or brush shaft. I suggest you unplug it,flip it over and look for screws that hold the baseplate together.. remove those screws and seperate the baseplate to gain access to the brush and motor head. Once open, it should be fairly obvious what the problem is.. a broken belt, a belt that has shifted or the brush won't spin freely due to an obstruction. Hope this helps..
Rick ( bigbutmunch..LOL)
Dec 04, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Loud noise
I think you damaged the belt. I ran over a sock once and it made a grinding noise but still worked for several months after the incident. Finally, the belt broke off. I had it replaced and now it doesn't make that sound.
Sep 26, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Burning smell
Hi. What does the burning smell of? Is it 'rubbery', or is it acrid and 'chemically'?! The most common item to 'burn' is the belt which drives the rotating brush at the front. Does your cleaner have a belt? This would give a burning rubber smell. The instructions should explain how to change the belt - have a close look and see if the belt has been slipping on the motor spindle. If it has, then it'll probably be worn at this point and should be replaced. A common cause of this happening is the brush bar getting caught in something - edge or rug, etc - and being forced to a standstill. If the smell is more 'acrid', it could be a problem with the motor. This is a repair service job.
Sep 22, 2007 | Eureka 2996AVZ Bagless Upright Vacuum
Hoover Vacuum
Our Hoover upright vacuum cleaner makes a very loud noise when it is running. What causes this?
Jun 28, 2006 | Hoover S3614 Vacuum
Vacuums Logo
44 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
