Question about Nikon SB-910 AF Speedlight Flash IMPORTED
Nikon SB 910- not getting exposure from flash. every other flash no flash exposure.
  • Nikon Master
  • 5,412 Answers
Are you sure the flash is fully recharging in between shots ?
Posted on Dec 10, 2016
Testimonial: "No sure if my last comment went through... But yes I make sure that the flash is fully charged and recycled. I am an event photographer and I have been consistently getting the same results until now."
Can I use Nikon SB-22s speed light with my Nikon digital SLR D5000? Is that compatible? I bought SB-22s for my previous Nikon film camera. Thank you.
You should be able to use your SB-22 with your D5000, however you can only use it in the manual mode since it is not a TTL speed light. That means you will need to manually set both the camera and the flash unit. I have done that successfully with an SB-25 on both my D800 and D90 in a pinch, but you should consider investing in either an SB-700 or SB-910. They are allot more versatile.
Oct 26, 2013 | Nikon Speedlight SB-22S TTL Flash
My nikon d90 doesn't works when i put the flash sb-600
Could you provide some details? How does it not work? Does the D90 not turn on? Does it take a picture but the flash doesn't go off? What exposure mode(s) are you using?
Apr 02, 2013 | Nikon Speedlight SB-600 TTL Flash
Why does the flash on my Nikon Speedlight Sb-600 flash twice before it takes the actual picture?
It's called a pre-flash. It's so the camera can judge the settings needed for proper exposure.
Nov 21, 2010 | Nikon Speedlight SB-600 TTL Flash
Shooting with a Nikon zoom such as 18-200 with a Nikon SB800 flash on a Nikon D300 body. I make an exposure of a person and the result is exceptable and then I zoom to the whole group of five people and it...
Depends on the zoom length. If you check exposure at zoom 18 mm then zoom to (lets say) 100 for the final picture the flash will zoom concentrating the flash power as well; the flash gets stronger. This is all explained in the SB-800 manual. On a zoom such as the 18-200 the more you zoom the smaller the f/stop. You are better off with a zoom that maintains its f/stop through the entire zoom range. That way when you check exposure at 18 mm lets say f/2.8 then zoom in it will maintain the same f/stop. Myself I am not a big fan of zooms especially ones when zoomed change to a smaller f/stop.
Aug 05, 2010 | Nikon Speedlight SB-800 TTL Flash
What setting should the camera be on for an
That depends on the flash. If it's CLS-compatible (Nikon SB-400, SB-600, SB-800, and SB-900) you can use it in any exposure mode (except flash off, of course). The easiest flash mode is Auto-TTL, though some of the other modes will give you better control under certain situations.
If it's not CLS-compatible, then you'll have to take it off Auto-TTL. If the flash has a sensor, you can let the flash control itself (assuming it's at the same distance from the subject as the camera). Otherwise you'll have to go manual.
May 12, 2010 | Nikon D60 Digital Camera with 18-55mm lens
The flash is not in sync with my nikon d40 anymore. It fires first. Pictures come out dark. The camera itself takes great flash pictures
It sounds like you're trying to use the SB-600 off camera, as a slave flash. While the SB-600 does indeed have slave capability, the D40 does not have the ability to function as a commander. Thus, the SB-600 is being triggered by the D40's pre-flash.
As stated above, the D40 does not function in commander mode. You can mount an SB-800 or SB-900 flash unit, which will function as a commander as well as a flash. Or you can mount an SU-800 commander unit.
Alternatively, you can switch the D40 to manual flash mode so as to eliminiate the preflash. However, you will then have to calculate the proper exposure yourself.
Dec 31, 2009 | Nikon Speedlight SB-600 TTL Flash
Can I use the Canon Speelite 550EX TTL with a Nikon D3
No. the Nikon and Canon flahses and camera speak different "languages" in TTL. So while the flash may fire once in a while, the TTL (Through The Lens flash metering) will not be compatible and the exposures will almost never correspond and synch up. Get a Nikon SB-900 flash.
Nov 30, 2009 | Canon Speedlite 550EX TTL Flash
Problem with speedlight SB-800
Check the conatcts on the shoe area and also the exp comp is done in the flash or in the cmaera to a minus 7 and that should help the exposure.
Apr 09, 2009 | Nikon Speedlight SB-800 TTL Flash
Auto Function Failed
It could be a communication error between the flash and the camera. Check the shoe foot for any damage or stuck pins. All of them must make proper contact with the hot shoe on the camera to get full auto/TTL, same for the shoe of the camera, bent? dirty contacts?
Dec 31, 2007 | Nikon SB-28DX TTL Flash
Nikon SB-910 AF Speedlight Flash IMPORTED Logo
37 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
