Question about Optics
Value of zd839 model 21sa3rl - Optics
What year was my .38 CTG 5shot revolver SN# r428xx? Value?
make model calibre serials
that will give you the year
then Google
make model calibre value
and you will see sale and auction price plus the Blue Book Guns Value.
May 22, 2017 | Optics
Hello everyone. I need a little help. Regarding my LG 21sa3rl-l4 it has a B+ but there is no oscillation. And no heater at all. I had already checked the fly back and it's good condition.
The most common reason this happens is the horizontal output transistor fails. This takes out the on board fuse that can either be at the power section of the main board or it is at the horizontal section. B+ is divided into several voltages.
Oct 29, 2016 | LG Televison & Video
Serial #3506979
any one of these sites will help you find the serial number and date of manufacturer. The forums will help with values, or the Blue Book of Gun Values.
  • Model 1894 (Mod 94 ) - Winchester Dates of Manufacture Winchester Model 1894 (Mod 94): Covering numbers: 1 - 5103249. Please enter a serial number and click the submit button.
  • Winchester Model 1894/94 Dates of Manufacture Dates of Manufacture* for: Winchester Model 1894/94. Winchester Lever Action Repeating Firearms, Vol. 3, The Models of 1894 and 1895 by Arthur Pirkle.
  • Winchester Model 94 Serial Numbers - Gun Collections Online 41 rows · Gun Collections Online. Specialists in Marketing Your Gun Collections ...
  • Related searches for winchester model 94 serial numbers
  • Serial Number info for Winchester Model 94 - The Firing ...
    • 109 POSTS
    • FIRST POST: 2008-11-27
    2012-08-04 · I have a Winchester model 94 serial # 2775xx3. The chart in this thread for serial # id show a lapse between 64 and 65 models. The 65 models all start with ...
  • How can you find the age of a Winchester Model 94 - Answers > ... > Firearms > Winchester Firearms What is the age and value of a Winchester Model 94 serial number 3910875? ... What is the age of a Winchester model 94 serial no 1929746?
  • Winchester Model 94 Identification - 8's Garage 94 Identification... · PDF file Winchester Model 94 Identification PRE-64: The Winchester model 1894 was introduced in October of 1894 apparently starting at serial number 1.
  • What Is The Year And Value Of My Winchester Model 94 ... What is the year and value of my Winchester model 94 serial number 5271797?
  • Value Of A Model 94 Winchester Rifle 30-30 Serial Number ... also have 3 winchester model 94 32 specials all are in fair condition stocks are worn and bluing has light scratches serial numbers are 3133157...2822367...2889678 ...
  • Model 1894 ' Winchester Collector ... the Model 1894 became the first Winchester ... The 1,000,000th Model 94 was presented ... from serial number 1 thru 353999. The Winchester Model ...
  • Jul 19, 2016 | Winchester Model 94 Short Rifle .30-30 20...
    Resistor value of R704 of Sharp tv model 21v-fk200m
    How do i unlock sharp crt tv model 21v-fk200m? i forgot the ...
    Feb 17, 2015 - Question about Sharp Standard (CRT) Televisions .... What is the valueof resistor R704 in SHARP TV model 21V-FK200M circuit diagram.
    Sharp value 2 watt resistor Standard (CRT) Televisions ... > ... > value 2 watt resistor > Standard (CRT) Televisions
    value of r707 sharp model #27c241 R707 is 27 ohm 1/2 watt carbon resistor,if you ... What is the value of resistor R704 in SHARP TV model 21V-FK200M circuit ..
    Dec 28, 2015 | Sharp Televison & Video
    Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
    Type in this key phrase " my service table today " in the search box at the top right of the display window, to get gathered some pages which has the details of practical experiences to the author of that site.
    Sep 27, 2015 | Televison & Video
    How to fix a tv lg 21sa3rl-l4 not on but have stanby?
    Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
    Sep 13, 2015 | LG 32LG30 32 in. LCD HDTV
    Lg tv diagram model number 21SA3RL-L4
    Number of play back of LG tv
    Jun 29, 2013 | Televison & Video
    LG 21SA3RL-L4 is the model of my tv. the problem is it has no sound at all? what should be the remedy for the problem
    LG 21SA3RL-L4 is the model of my tv. the problem is it has no POWER at all? what should be the remedy for the problem
    Sep 16, 2011 | LG Televison & Video
    I have an artic airconditioner model KF-51GW, I want to know the value of the compressor capacitor ( I lost the orinal value).
    The value is on the capacitor, but if you can't read it, you need the model number of the compressor and you can call a appliance parts store and they should be able to help you.
    Oct 17, 2010 | Heating & Cooling
    maybe your tv is set to PAL mode set it to NTSC, or else your tv is out of sync.check the jungle.
    Oct 08, 2008 | JVC AV-27530 27" TV
    Optics Logo
    27 people viewed this question
    Top Optics Experts
    Joe Lalumia aka...
    Joe Lalumia aka...
    Mark Campeau
    Level 1 Expert
    Are you an Optic Expert? Answer questions, earn points and help others
