Question about Dryers
Maytag mgd9806 burner only lights once
Burner only lights once, then rattles without flame
  • 6,784 Answers
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
Posted on Jul 20, 2009
I have a maytag super capacity plus stove and need to adjust the air mix for the burners. How to do it? Please help thanks
Open the top of the range. I believe there are a couple of spring clips in the front between the range top and the top of the door. Not sure on the Maytag. However, when you get the lid up, (it should be hinged at the back), set the burner pieces back on. (These burner pieces HAVE to be there or you'll just have a blowtorch pointing up!) You'll see that going to every burner there is a tube to carry the gas. on the side of every tube there will be an adjustable, sliding air vent. They are usually held in position by a set screw. Loosen the set screw. Light the burner and carefully slide the vent closed or open to adjust how much air is being brought into the mix. If the flame is way too high and or orange in color....you have too much air. You want as much flame as possible on high without the flame being orange or white-ish. Once you get the flame the way you like it, tighten the set screw back. Hope this helps.
May 15, 2011 | Microwave Ovens
Large flames licking the sides of our oven from under the flame spreader. We adjusted the burner as close to mostly blue flames as possible but there still is a lot of white flame. It seems extreme. How do...
Something spilled and got into the burner assembly. You will have to remove the assembly and clean it. It's not a difficult job and most burners can be removed in just a few minutes without any tools.
Your manual should tell you how to remove it ... if not then go on line to your manufactures web site.
Feb 15, 2011 | Maytag 30" Self-Cleaning Freestanding Gas...
Gibson Furnace, Model #7106250 can not get a flame going. The furnace runs fine but is pumping out cold air without a flame. Any ideas?
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose, Dirty Air Filter), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Mar 04, 2010 | Heating & Cooling
HEATER IS NOT HEATING. WE REPLACE THE THERMOSTAT AND THE PILOT IS ON FAN WORK. ITS JUST NOT HEATING!
Not much to go on without a make and model number but:
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Jan 16, 2010 | Heating & Cooling
Gas furnace, main burner ignites the other 2 don't. then shutdn.
Between the burners is a small rail in the pressed steel where the flame runs across to light the other burners and it sounds like there is dirt or debris in the step over rails causing the problem. You will need to use some compressed air on those rails to clear them out. Once the rails are clear the other two burners should ignite right away.
Dec 21, 2009 | Heating & Cooling
WILL NOT LIGHT ALL 5 BURNNERS WILL ONLY LIGHT 2 THEN SHUTS OFF GOES TO LOCKDOWN
Nov 23, 2009 | Coffee Makers & Espresso Machines
Gas neptune dryer fires up for 45 sec. to 1 min, then goes out
Could be a couple different things,Possibly a thermostat or high limit that is kicking out too soon,also has a flame sensor next to the burner that can come and go.if you have a toggle switch or pushbutton switch you can unplug the unit take the two wires off the flame sensor (black box about the size of a cigarette pack on the left of the burner)plug them into the switch start the dryer Turn the switch on till the igniter glows bright,turn the switch off and the burner will light if it stays lit at least till it gets to temp replace the flame sensor.(It won't cycle with out flipping the switch each time)
Sep 03, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer is gas model dg212 flame come on but will not stay on long enough to dry clothes
if burner lights but fails to relight after several shut offs suspect burners solenoids change both they come in a kit ..once the solenoids get hot they will sometimes open electrically and fail to reenergize after cool down they will open gas valve and alow burner to reignite..also be sure vent to outside to clean and vent behind dryer is not flattened or kinked has know flame to not be properly burning due to exhaust problems and flame sensor would shut burner down
Sep 16, 2008 | Maytag Dryers
Swooshing sound in oven when burner ignites
the valve your talking about with the two wires on it is the safety valve and should not let gas in without the ignightor being on sounds like its leaking i recommend shutting the gas off till the valve is replaced there is no piolet light on theese ranges
Jan 18, 2008 | GE JGBS23 Gas Kitchen Range
Dryers Logo
63 people viewed this question
Top Dryers Experts
