Question about Tablets & eReaders
Screen freezes on advertisements on my ipad - Tablets & eReaders
Why won't apple iPad mini play MP3 songs or video?
If it crashes like that, I would delete the app and re-download it. If not, I would restart the device by pushing both the home button and the power button.
Apr 14, 2016 | Apple iPad Mini
Tip
Resetting a Frozen iPad
If you encounter an iPad problem that causes it to freeze, or if it is sluggish when you tap on an app, try a hard reset.
  1. Press and hold down the sleep/wake button at the top of you iPhone or iPad while at the same time, pressing and holding down the Home button on the front of your iPhone or iPad.
  2. Keep holding both buttons held until the screen turns off. It will automatically turn back on again and display the Apple logo.
on Dec 08, 2014 | Apple iPad Tablets & eReaders
ALL ITEMS ARE ZOOMED IN THE TOUCH SCREEN AND COULD NOT GO BACK TO NORMAL VIEW. SCREEN IS HARD TO TOUCH, PICTURE FREEZES
Switch off the iPad and start again. (Press and hold the power off button (top edge right hand side) then swipe when the power off appears.
Mar 12, 2015 | Apple iPad Mini 16GB Wi-Fi White
After tapping the agree button the 8.1.03 update freezes. What can I do to get it to work properly?
  • First, manually backup your iPad by connecting it to your computer;
    • open iTunes and select your iPad from the icons below the menus
    • in the Summary screen, click the "Backup Now" button;
    • Quit and restart both your computer and your iPad.
    • with your iPad connected to your computer, click "Check for Updates" and follow the prompts.
Feb 15, 2015 | Apple iPad Tablets & eReaders
Since the new update, my iPad screen freezes and won't allow me to open the call. If I make the call, it won't allow me to end the call
If you updated to IOS8.1 then it's got a glitch in it.
You need to go back to your last restore (if you saved it) or update but to IOS8 (Not IOS8.01)
Sep 25, 2014 | Apple iPad (16 GB) WiFi Tablet PC
My ipad is stucked.
This tutorial will explain how to force your iPad to restart if it gets stuck or freezes up.
Forcing your iPad to restart will not cause any loss of data - with the possible exception of any work you were doing at the time the iPad and/or App froze, forcing you to restart it.
Click and hold down the Sleep/Wake button (located on the upper-right corner of your iPad). While you're holding down the Sleep/Wake button, hold down the Home button as well (located on the front of your iPad at the bottom). Hold down both buttons until your iPad powers off. It will reboot and start again with a small silver Apple image on the screen. It takes about 30 seconds for the iPad completely start up.
Feb 19, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Frozen screen with clicking sound
As with many electronic devices that sport an operating system, there might come a time when your apps start wonking out or your iPad simply freezes. In most cases, a "hard reset" fixes most issues.
To do a hard reset, just hold the "Sleep/Wake" button on the upper right of your iPad along with the circular "Home" button on the lower middle part of the device's bezel. After 10 seconds, you should see the Apple logo. That's the sign that you've successfully pulled off a hard reset with your iPad.
Jan 26, 2014 | Apple iPad 32 GB 3G Tablet PC
My ipad freezes when i use multitasking gestures
you should first bring up the ipads performance and then do the multitask thing and of the line goes flat to the top that means u need a new performance update.
Jan 20, 2014 | Apple iPad 32 GB 3G Tablet PC
IPad freezes
Try this link out Iphone repair, its for iphone but it solved my ipad freeze situation. Hope it helps you out
Dec 06, 2011 | Apple iPad (16 GB) WiFi Tablet PC
Tablets & eReaders Logo
32 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
