Reebok RX 1000 trips breaker when drive motor is engaged. Breaker does not trip with motor disconnected. Same behavior after replacing motor. Do i need to replace control board or component?
  • Charles Sirera Dec 10, 2016
    Maybe I posted in wrong place..? The RX 1000 is a treadmill.
    Top Expert:
  • Heating & Co... Master
  • 51,307 Answers
You need to get in a technician to find the reason for the breaker tripping
it could be problem insulation or pest infestation causing ground leakage
otherwise you will be wasting money on the repair by replacement merry go round
Posted on Dec 10, 2016
Therinnaiguy
  • 1420 Answers
SOURCE: breaker keeps tripping
If the breaker itself is more than 15 years old, replace it. If it continues to switch off, check the amp draw of both the inside and outside unit.
Posted on Sep 12, 2007
TJBENGR
  • 121 Answers
SOURCE: my ac circuit breaker keep tripping
If your outside condenser has a locked rotor or short circuit, than the unit WILL trip the breaker - as it should. On the other hand if a breaker is tripped a few times it will have less of a capacity that the rating, (this is designed in it). You will need to determine if the unit is locked (and broken) or the breaker has become too sensitive.
Posted on Apr 22, 2008
  • 82 Answers
SOURCE: a/c is drawing 20 amps and keeps tripping breaker after running
If the fan is running and the compressor is getting hot and tripping off you may have a failed capacitor.
Posted on Jun 29, 2009
  • 14 Answers
SOURCE: AC Runs for about 10 minute then trips breaker
is your breaker is ok or lose concation is good.if this both is good than cheek his overload.
Posted on Jul 20, 2009
motor1258
  • 6674 Answers
SOURCE: Rooftop RV Air Conditioner: replaced capacitor on dometic 59516-531 steal trip...
You need to borrow a clamp on style amp gauge, and check amp draw on black wire in box where hydro wires connect. (PLEASE, be careful, and if not experienced in this type of test, don't try it, due to likelihood of getting a shock. ) If it's the compressor kicking in that's causing the breaker to trip, and capacitor is good, then it's usually a problem with either low incoming (supply) 110-120 AC voltage, which will cause high amperage draw, or compressor on it's way out causing high amp draw. If it's only drawing 15-18 amps, and your tripping a 20 amp breaker, then breaker is getting weak.
Posted on Jun 05, 2010
Can the motor control board cause the house circuit breaker to trip?
It's unlikely. An internal fuse would blow first, I'm assuming. If you've diagnosed this far you sound capable of continuing. Electricity is dangerous!!! I would remove all things from the board, 1 by 1 plug each component into board until the breaker trips. That should pinpoint what is tripping breaker. I would assume a motor.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Apr 04, 2017 | Heating & Cooling
I have a rodgerblack gold treadmill ag-10302 when i switch it on at wall it trips the circut in my fuse box help please
1) please use a table lamp in connect in wall circuit. if the c.breaker trip again, the problem is your outlet wall. Call electrician or test the wires for touch each other or ground improperly, and fix it.
If the circuit is NOT trip, test the power cord for defective 2) test the main switch for shot circuit 3) test the c. breaker for defective 4) test the motor see the if the motor if short circuit see my personal TIPS for help motor , see the diagram attached. 5) test the output board, the board can be short circuit and replaced. Happy NEW YEAR God bless you
Dec 31, 2012 | Reebok Exercise & Fitness
The fan will not engage when unit is turned on and after 5 or so minutes the circuit breaker trips.
since the fan doesn't run - the compressor heats up and pulls excessive amps and trips the breaker.
99 out of 100 times your fan motor will be bad.
You need to replace the motor.
Jun 07, 2011 | Kenmore 74123 Air Conditioner
Breaker trips on unit. Fuse in house is ok. As soon as AC unit turns on it trips the breaker outside next to unit.
you have a 'direct short' - most likely the compressor or fan motor.
you could isolate it to one or the other by (be sure all power is off) disconnecting one of them and turning the unit back on.
For example if the fan motor is shorted and you disconnect it - the breaker will hold and not trip and the compressor will come on - which will tell you that you need to replace the fan motor.
If you do this and it still trips the breaker then reconnect the fan motor and disconnect the compressor and try that.
If the breaker holds and the fan motor runs then you know the compressor is shorted.
Note: the fan motor can be replaced with not a lot of trouble depending on how mechanically inclined you are - but the compressor will take a qualified serviceperson.
Jun 06, 2011 | Heating & Cooling
Kenmore central air conditioning unit tripping breaker each time we turn it on.
The breaker tripping when you turn the unit on indicates a 'direct short' and 99 out of a 100 times the short will be either the outside fan motor or the compressor itself. Either way - you will need a qualified serviceperson to diagnose this problem correctly and make the needed repairs.
Best solution is to call AC person.
However, here's a good way you can get it down to either the fan motor or the compressor.
(1) With all power OFF - disconnect the wires to the fan motor
(2) turn on AC unit (a) if breaker trips it means the compressor is probably the shorted component. (b) if breaker DOES NOT trip and the compressor runs - it means the fan motor is shorted.
(3) If breaker tripped with the fan motor disconnected meaning the compressor is probably shorted you can then (with ALL POWER OFF) 'disconnect the wires going to the compressor' and re-connect the fan motor wires. Turn on power - and if fan motor runs (with compressor wires off) you know it's the compressor that is shorted.
After all this you will now know which of the two (compressor or fan motor) is shorted.
If it's the fan motor you can with 'limited mechanical experience' change the motor yourself, but if it's the compressor you will need to call a serviceperson because of the expertise needed to replace the compressor.
Jun 05, 2011 | Kenmore Heating & Cooling
Trips breaker and will not cool or heat
Disconnect compressor leads and tape them up. Restore power, if the breaker does not trip, than you have a grounded compressor.
If breaker trips again, hook compressor up and disconnect blower, if breaker does not trip you have a
bad blower motor.
Jun 18, 2010 | Coleman Mach 15 Air Conditioner
Everytime my central air unit kicks on my circuit breaker trips. It didn't do this last year or even earlier this year
A circuit breaker 'tripping' everytime the AC unit kicks on 'most always' indicates a direct short (somewhere in the condensing unit), although it is possible that the breaker itself is bad - (but not likely).
Usually the cause of this 'short' will be - either the condenser motor in the condensing unit (outside unit) or the compressor - also in the condensing unit.
If you're mechanically inclined - and "very careful" around electricity - there is a fairly simple way to find out which component is causing the short.
Step 1 - Make sure the condensing unit (outside unit) is completely disconnected (electrically) , i.e. pull the fuses/turn off circuit breaker on outside unit and turn off thermostat.
Step 2 - disconnect the condenser motor (this is the outside fan motor). Note: when you disconnect the wires of the condenser motor "be sure" you mark/write their location, and wrap them in electric tape.
Step 3 - start the AC unit. If the breaker trips again you can pretty much rest assured it's the compressor that is shorted.
To prove it (without a doubt) - go to next step.
Step 4 - "be sure circuit breaker and thermostat is turned off" - and - 'reconnect' the condenser motor - and - then disconnect the compressor wires (mark wires and tape them).
Step 5 - Start AC.
If breaker doesn't trip - you know it's the compressor that is shorted.
If breaker 'does' trip again - then it's possible the breaker itself is bad (not likely) or there is a 'short' in the condensing unit's "wiring" somewhere (not likely).
My guess is that either the condenser motor or compressor is shorted.
Hope this helps.
Good Luck!
Jun 10, 2010 | Heating & Cooling
Spa keeps tripping breaker shows pr
two main reasons breaker trips is the pump motor jammed [not turning]or the heater shorted out --disconnect power open access panel disconnect the lines to the heater turn on power if breaker trips than motor /pump problem if doesnt trip than heater problem can order heater replacement online or pool spa store--if motor pump check pump for debris and motor for lube if u can turn shaft or impeller oil motor and work it into bearings if still not turning possible need to replace motor unit
Apr 26, 2010 | Heritage Pool & Spa
Gfci breaker keeps tripping
sometimes gfi outlets go bad and trip try testing with a heavy draw machine in it or just replace it and see if this fixes the problem
Jun 22, 2009 | Balboa Instruments Duplex Digital Panel 2...
Washer trips circuit breaker
Is washer relatively new? Check circuit breaker for proper size (20 AMPS). Washer must also be on its own circuit. It appears that when the motor starts up it is causing a spike in current (as with any motor), so the breaker is either undersized (Note that if breaker is undersized and you up it to the next size you would also need to replace the wire with the next size up which would be 12/2 with ground), or if you have had your washer a while which I believe is your case the circuit breaker is weakening and is tripping on the current spike. Try swapping out your circuit breaker with a new one and try running the washer again.
Sep 04, 2006 | Maytag LAT2600A Top Load Washer
Open Questions:
vulcan bonaire comfort control External natural gas electronic ignition 2004. ISSUE: Fan blowing only cool air continuously. Forced to kill power to stop it. model is one of the following. MB514E,20E or 30E. Going by mech drawing parts list. i can confirm what type of sensors i have cleaned with very fine sandpaper. flame sensor PN 5441603SP and IGNITER ELECTRODE PN 5441602SP The fault code i see is described as the following. There are x4 LED's. Sequence Left to Right. LEGEND: 1 Flame Sensor 2 Pressure switch 3 OverTemp 4 Diag. R Red G Green S Solid Colour B Blinking LED Behaviour. In order 2RS & 4GS Until i hear ignition. 2RS & 3RB Duration: split second 2RB,3RS & 4GB Duration: split second 3RS & 4GB Duration: Until it has completed blinking x4 times. 3RS Duration 4 seconds Repeat last two mentioned behaviour. in my own opinion, as a safety feature, the unit thinks that it has overheated or is about to. so kills the gas and force feeding cool air to heating components to save it from frying. Does this mean i have fault 04 if so does this mean i may have a faulty igniter or flame sensor or maybe a faulty as described in the mech drawing SWITCH OVER TEMPERATURE 120 degrees celsius. Am i correct here? Is this the over temperature cut out switch? if no one can really pinpoint which part requires replacement, can you at least, in sequence advise which parts to purchase? so then ill just try my luck. i wonder how to properly test if flame sensor, igniter, over temp etc is faulty with a multimeter. do i just perform a continuity test. I wonder what other parts can i test related to this fault im getting.
Jul 22, 2018 | Vulcan Heating & Cooling
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
