Question about Maytag Refrigerators
I took my fridge apart to clean it and now I can't recall the proper shelf positions. I have a Maytag RSW2400
    Top Expert:
  • Maytag Master
  • 42,218 Answers
The fridge has a number of positions for the shelves to suit different heights of the items you are putting in the fridge
set the shelves that best suit what you have
Posted on Dec 10, 2016
4 Suggested Answers
SOURCE: Maytag Elevator Shelf
Let me just say, your post helped me, because I realized that I was not going crazy.  But, I was able to find the manual on this frigerator, which was key.  There was one phrase in the manual that gave me help - "when the glass shelf is pushed to the rear, it will align the rear latches.
Manual from whirlpool website: http://shared.whirlpoolcorp.com/assets/pdfs/literature/MSB2154ARA.pdf
So, the rear latches must be installed in such a way that the sliding glass shelf not only touches them, but pushes them into the correct position.
This fact helped me to try different positions, each time testing to see if the glass shelf would do anything.  Finally, I realized that there is a triangular shaped part of the rear latch.  The hypotenuse of the triangle is what comes into contact with the little nub on the underside of the glass shelf.  The nub on the glass shelf pushes the rear latch along the hypotenuse of the right triangle, and into the correct position.
Here is a picture of it installed in my frigerator,which I am sure will tell it better than any words:
Posted on May 31, 2009
SOURCE: how to remove take glass shelf to clean trapped spills
lift the front nosing by prying with your fingernails up...it will roll in place allowing you to remove the glass
Posted on Dec 04, 2010
topmark14
  • 60 Answers
SOURCE: MAYTAG REFRIGERATOR/FREEZER Model#RSW2400 -ice builds
check the fan its not working to circulate air
Posted on Feb 26, 2011
Why is it leaking water onto top shelf
Most modern fridges have an automatic defrost that works by draining into a sort of funnel above the back of the top shelf.
The funnel is connected through the back of the fridge to a rubber drain tube that goes down the outside of the back to a heated evaporation tray under the fridge,
The hose and/or funnel can get clogged with disgusting yucky stuff, and the water spills over the top of the funnel onto the top shelf.
The fix is to clean all the bits. It's usually no big deal to take apart.
I have resorted to blowing through the tube from the bottom end and then cleaning up the mess, and brushing my teeth. Quite revolting but, that's the price I paid to become an expert.
Cheerfuls
Nov 20, 2015 | Refrigerators
I have a Dyson I took out the screws to clean it before I opened the canister now I can not get it together again
You're a bit unclear on what screws you took apart to 'clean it'. If you took the canister apart, then this Snapguide page
How to Clean Dyson DC07 Canister goes through taking the top section thoroughly apart, and has some notes about things needing to line back up properly, which might help in the event that you're not getting things to snap back together right. I took mine apart solo after picking it up cheap at a flea market, and also recall reassembling the top took a little patience.
Good Luck!
Oct 30, 2015 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Maytag upright freezer (MQU1556AEW L1)top shelf
my maytag freezer not wotking correctly, the top shelf not cold, I bought a meat and tryed to put it on the top shelf, unfortunately, my meat went to the garbage and just the botttom shelf takes time to freeze, better than the top shelf
any help ?
Jan 02, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
Water leaking from bottom of freezer door, and ice buildup on bottom of freezer
The defrost drain line in the freezer has frozen closed. Turn off the fridge. Remove the freezer bins. Use a hair dryer to thaw the drain hole on the bottom rear shelf of the freezer.
P.S. Your fridge is on recall from Maytag for a defective start relay.
Apr 19, 2009 | Maytag MZD2766GES Side by Side...
Top shelf not getting clean
It sounds like the hose at the rear of the top shelf has come unconnected. Pull the top shelf out when the washer is empty and take a look. If the hose has come apart you should be able to push it back together. Good luck with it.
Dec 27, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
How to remove take glass shelf to clean trapped spills
Dec 20, 2008 | Maytag MTB1895AE Top Freezer Refrigerator
Ice forming on the a shelf in my refrigerator
Hi .Thanks For The Question. You Probably Have A Drain Problem, From The Freezer TO The Back Of The Fridge. Pull Fridge Away From Wall ,Remove Back Panel Clean All Coils. Locate Drain Hose From Freezer. Clean Tube. And Fridge Is A Bit Too Cold
Aug 23, 2008 | Maytag MSD2656G Side by Side Refrigerator
Oct 08, 2007 | Maytag MSD2756G Side by Side Refrigerator
Refrigerators Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
