Where is the firebox overtemp lockout - Computers & Internet
Firebox disinigration
if the paint is peeling off heater is overheating check gas pressure if too low heater will soot up and overheat
Jul 09, 2012 | Teledyne Laars Pool & Spa
Where does the FBK200 blower go in the Marco fireplace
As you are aware the Marco Fireplace Co is no longer in business. However, the blower model # you listed is a DESA/Vanguard part number. In any event, it may work.
The blower goes in the lower compartment (probably louvered) under the firebox. It is then attached to the rear wall of the compartment, with the blower output facing up the back wall of the firebox. There should be an arrow on the blower housing indicating which way it should point.
If your firebox is already wired for a blower and has a duplex receptacle in place (for the blower to plug into), you're in business. If it doesn't I highly recommend that you install one and not try to hard wire the blower.
The blower, if purchased new, should come will all the hardware to mount it. If it didn't you can use sheet metal screws to attach it to the rear wall of the firebox. However, make sure that you put a rubber flat washer behind the mounting frame and then screw thru it into the firebox wall. This will help eliminate vibration and noise.
Hope this helps to get you started.
Feb 25, 2011 | Heating & Cooling
How do I use this grill? Charcoal in the larger cavity and wood in the firebox???
I assume you have the model with the side firebox? If so, when smoking you have your charcoal and wood in the firebox and the meat to be cooked in the large cook chamber. This is indirect heat cooking. Your cooker is dual purpose. You can load the large chamber grates with charcoal and cook as would with a charcoal or gas grill (direct heat cooking), or you can cook low and slow using the smoker portion. The heat comes in from the firebox and into the cook area. Ideally the temp in the cook chamber should be around 225 while smoking meats in this manner.
Google "smoker forums" and you will find a group of guys will to help you learn to cook with a smoker and share cooking secrets.
I hope this helps.
Jun 21, 2010 | Char-Griller Wrangler Charcoal
Presonus Firebox doesn't sync up.
1. check the drivers update for you device
This is found at the manufacturers site.
2. See if your device is compatible with the OS (operating system) on your laptop.
3. Check the connecting cable to see if you have a broken wire inside the "strain relief".
The cord at this point will have a puffy part that indicate that there is a broken cable.
Apr 16, 2010 | PreSonus Firebox 6x10 External Sound...
Presonus firebox problem on XP
i have a new firebox presonus firewire..that we just instal evrythink seem al good..but my probleme ..on my playback my wave track aone the track popsup all...need help..thanks
Jan 10, 2010 | PreSonus Firebox 6x10 External Sound...
Fireplace will not stay lit and pilot light is on
This sounds like the high temperature switch has failed and is telling the unit to shut down after it gets started, the pilot has to be lit for the main gas valve to turn on when the thermostat calls for heat, The main burner comes on and stays on until the thermostat is satisfied and tells it to shut off, you dont say if there is a blower in this unit, if there is a blower after the main flame comes on the unit heats up it turns on the blower if equiped. If the blower fails to turn on the unit would be shut down on overtemp as the firebox would get to hot and be in danger of causeing a fire. if no blower there still is an overtemp switch that shuts the unit down if it gets to hot or the switch is bad, it could be a bad overtemp switch or if equiped a bad blower motor or even a plugged chimney as this would also cause a overheat ing condition. Hope This Helps Don
Dec 01, 2009 | Napoleon 36" Zero Clearance Top/Rear Vent...
Doesn´t work anymore
Hi. Forgive me for asking, but did you try unplugging everything, including the firewire, and plugging it in again?
If you try this and it doesn't work, try shutting your laptop down gracefully, then unplug all the Firebox connectors including the electricity. Wait about 10 seconds, then reboot your laptop. Don't open your recording software yet.
Connect the electricity and the firewire as described in the Firebox manual, and then open your recording software. If this doesn't work, something might be wrong with the Firebox.
The problem you have happens once in a while with mine--it seems to be connected with overheating or something. Anyone else have this problem?
Oct 01, 2008 | PreSonus Firebox 6x10 External Sound...
Error code E00003-0000
The film (plastic) film is probably torn from a piece of paper that got jammed between the upper and lower section causing an overtemp lockout condition.
1. Remove left paper door.
2. Remove conector rear plastic(black) and fuser shields(2) screws holding fuser cover shield and unplug (3)connectors,2on the rear and a small one on the front lower right of fuser unit
3. Remove (2) assemlbly mounting screws one at rear and one
on the front sides.
4. remove unit and purchase new complete unit from cannon
5.Installed new fuser by reversing above steps.
May 28, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Watchguard site to remote offices
What have you done to date, what is the Config on both sides.
Let me know
Aloha
Bob
Jan 19, 2008 | WatchGuard Technologies FireBox SOHO 6...
Computers & Internet Logo
128 people viewed this question
David Payne
David Payne
