Question about Refrigerators
Freezer side is cooling properly, refrigerator side not able to get down to 42 or 40 degrees
    Champion:
  • 363 Answers
First try to clean all seals around doors and all contact points
Posted on Jul 22, 2009
Model ZFSB26DNA SS Side by side / refrigerator and freezoe not able to get cool enough. Refrigerator side temp 49 freezer temp 7
refrigerators run from 5 to 10 degrees C so your machine is on the upper limit of 9 degrees c
the freezer is at minus 13 degrees c and most work down to minus 20 degrees c so that is in limits
Get a technician in to check the thermostats and in the mean time check the condition of the door seals as they will loose the cold very easily is cracked or not sealing properly
Nov 04, 2015 | GE Refrigerators
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
Freezer get up about 27 degrees and then start going back down to 0 degrees. Does it everyday.
Sounds like the defrost timer/control is sticking...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 01, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer won't go below 32 degrees
Need condenser fan for unit to cool properly
Apr 27, 2010 | Amana SXD524VW Side by Side Refrigerator
Our side by side refrigerator/freezer is not cooling properly
first try to clean the condenser coil, it is under the bottom of the unit,blow out or vac out the coil.
check to see if fan in freezer is running or if there is ice on the evaporator coil inside freezer.
Sep 13, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Whirlpool 6 sense model WSC5513- A+ X side by side, without ice or water dispenser. Refrigerator part not cooling properly. Temperature setting is -18 degrees Celsius for the freezer and 2 degrees...
The temp for the fridge is about right and -18 for the freezer is ok so check to see if the water filter is plugged, at 8 degrees Celsius is about 18 degrees fht. Which is freezing so the numbers don't add up. 26 degrees below zero on the freezer side is what you want if it that cold it could have frozen the water line.
Aug 20, 2009 | Refrigerators
Model FRS26ZRF, the freezer side is cooling down
It could be the defrost system? When you allowed to thaw, did you check the evaporator? It could be frozen? It will take longer to thaw. Is the evaporator fan working? It and the compressor will not, when the box is in defrost. Is your defrost working? Are your door gaskets sealing properly? Are your doors aligned properly? Some things to check. Good luck.
Jul 13, 2009 | Refrigerators
Freezer is frosted in back Refrigerator is warm
The problem is the defrost system located behind the freezer back panel.
The defrost system (AKA evap. system) is composed by an heating coil, a fan , and a defrost thermostat, and its function is avoiding ice formation on coil.
When defrost system is defective the fridge wont cool down properly
In your fridge , either evaporator fan, thermostat or heating element is faulty, and the ice on coils is preventing the appliance from cooling down properly.
Mar 29, 2009 | Hotpoint HSS25GFP Side by Side...
Ge Side by Side not cooling
check the freezer panel in the back for frosty ice build-up. is the freezer evaporator fan running?
Aug 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
