My dyson fan isnt heating like it was, is blowing slowly, so I cleaned it, not getting as warm as I need it to get. There are no error messages, and it runs great, but very little warmth
sandrew
  • 2961 Answers
SOURCE: cleaning the fan and heat sink
I would first check for any trojans, virus's and spyware, and any programmes running at start up you don't need, as that can cause overworking of the processor, then instead of stripping down the notebook, which i don't recommend,look around any vented area of your notebook and hoover out the vents gently, this will remove any dust blokages. Give your system a good clean out with this excellent free tool called ccleaner and you can also dissable any startup programmes you dont want with the programme also. Download it here, fre and free updates and spyware free, click link and then on the right of link click download latest version. http://www.filehippo.com/download_ccleaner/
Posted on Jun 22, 2007
SOURCE: GE Fridge...no longer freezing or cooling food!!
Had to call in the experts...needed a defrost heater and 2 sensors.Hope this is helpful to anyone w/ a similar problem.
Posted on Jul 26, 2008
redbeard00
  • 957 Answers
SOURCE: Heater blows cold air from top vents after running for 1.3 hours
Sounds like you may be able to fix it by flushing your antifreeze and back flushing the heater core. Some car owners cheep out and put stop leak into the antifreeze, others dont change there antifreeze at all. Both are mistakes.
Posted on Apr 25, 2009
SOURCE: I have a 1998 Dodge Durango SLT-V6 that has no heat.
The heater core might need back flushed, I just did mine this winter. Go to dakota-durango.com and introduce your self and your rare as ever truck, a v6 durango, and have fun.
Posted on Dec 27, 2009
SOURCE: 2005 Chrysler Pacific-no heat and no fan-display works
replace the complete heater control unit was my only fix! over $700 in Cnada for control.
Posted on Mar 05, 2010
My 1998 Ford Explorer Defrost Heater isn't blowing any air to the defrost Is this a fuse?
If your front blower motor isn't working on any setting, could be the blower motor itself, the blower resistor, or sometimes the wire pigtail to either one could be the problem.
Oct 23, 2017 | Ford Cars & Trucks
I have a neo plasma lg 7kw will not heat LG Air conditioner
Make sure the setting on the remote is correct . Sun symbol for heating. Make sure the filters are clean. On heating, the indoor unit will 1/2 open the flap but the fan shouldn't start. The outdoor unit should start and if working properly, will be blowing cold air. The indoor unit will open the flap fully and the indoor fan will start once it gets hot then you should feel warm air. If the outdoor unit is blowing warmish air, I would say the reversing valve coil has failed or one of the indoor temp or pipe sensors are faulty. If a sensor fails, a "CH" error should appear on the display.
Mar 30, 2016 | LG Heating & Cooling
<yn 81 monte carlo -
check the coolant. then outside under the hood near where the 2 hoses go into the heater core there is a heater coolant control valve. make sure the vac line is connected and not broke. feel the hoses there at the heater core after it warms up. are they hot? if not the valve isnt opening and letting coolant into the core
Jan 22, 2011 | Chevrolet Monte Carlo Cars & Trucks
My heater, when parked and idle, cools down. The heater will heat again once I begin driving, but this is freezing me as I sit and wait for my kids at school. It blows cool air while I am parked and will...
It could be the electric fan is going on too easily.
The radiator and hoses should be almost too hot to touch.
And when cold, the fan should not really do on at all.
But the thermostat could be opening too soon also.
There are two hoses to the radiator, and when you start a cold car, only one should slowly get hot.
The other should stay cold until the thermostat opens, after the engine is good and hot.
If both start slowly getting warm at the same time, then you need a new thermostat.
And also make sure you have enough coolant in the radiator.
Dec 20, 2010 | 2007 Chevrolet Impala LS Sedan New Cars
Mt dimension 3000 gets very noisy when the weather
That's because it heats up more easily and faster, which usually makes the fans spin faster and results in being noisy. Have you ever cleaned out the interior of the computer? If not, or if it's been awhile since it's been done, then buy some canned air for dusting electronics, open the side of the computer case (while it's not powered ON), and blow out the fans and the heat sink. If you get alot of just clogging up the heat sink, then it will not dissipate heat correctly; which results in the fans running more often. It that doesn't help any, then I would try to figure out if one of the fans is making alot of noise because it's going bad. You can find replacement fans on ebay, or at local electronics\computer shops.
Apr 10, 2010 | Dell Dimension 3000 PC Desktop
Inspiron 1100--fan has recently started running often & long. Computer gets very warm to the touch & runs very slowly. Shuts down randomly--during virus scans, disk clean ups, etc
sounds like the heat exchanger is clogged. Try using canned air blowing in both the air intake and exhaust to unclog the heatsink and also make sure the system has the most current BIOS version.
Sep 26, 2009 | Dell Inspiron 1100 Notebook
Turns on but blows out warm air
Is the compressor on as well? or just the fan, if the compressor is on and fan is on and it is blowing warm air it could be a charge (refrigerant problem)
Jul 27, 2009 | Goldstar DH4010B Dehumidifier
Electric furness blows hot then warm
if this has happened since you got hte furnace it is normal
heres how a heter works
themostte tells heater to turn on
heating element turns on
followed in about a minute by the blower
during the peried before the blower kiks on the elements become supper heated
after the blower kicks on it slowly leves off the element temp and air temp coming out
Jan 23, 2009 | Hunter Fan Company 5/1/1 Programmable...
2000 Cherokee Heater only works once the vehicle is moving
this is normal, heat comes from your motor so it isnt hot enough until you start working the engine
Nov 20, 2008 | 2000 Jeep Cherokee
Edgestar 12,000 portale air conditioner and heater
There are 3 possibilities beginning with the most likely problem
1) If your heater heats up for a few minutes and then quits, chances are there is a blockage in the air flow, check for dust and grime blocking the air intake coarse filter , airgun blow to clear accumulated dust and otherwise clean the coarse filter .
2) If the heater fan blows but there is no warm air, the heating element needs renewal ( this happens very rarely)
3)If the fan stalls and the heater heats up and the thermostat kicks in, then this will be not be a DIY job. This is least likely as you said the air cooler works.
Apr 25, 2008 | EdgeStar Portable Air Conditioner Heater
Open Questions:
vulcan bonaire comfort control External natural gas electronic ignition 2004. ISSUE: Fan blowing only cool air continuously. Forced to kill power to stop it. model is one of the following. MB514E,20E or 30E. Going by mech drawing parts list. i can confirm what type of sensors i have cleaned with very fine sandpaper. flame sensor PN 5441603SP and IGNITER ELECTRODE PN 5441602SP The fault code i see is described as the following. There are x4 LED's. Sequence Left to Right. LEGEND: 1 Flame Sensor 2 Pressure switch 3 OverTemp 4 Diag. R Red G Green S Solid Colour B Blinking LED Behaviour. In order 2RS & 4GS Until i hear ignition. 2RS & 3RB Duration: split second 2RB,3RS & 4GB Duration: split second 3RS & 4GB Duration: Until it has completed blinking x4 times. 3RS Duration 4 seconds Repeat last two mentioned behaviour. in my own opinion, as a safety feature, the unit thinks that it has overheated or is about to. so kills the gas and force feeding cool air to heating components to save it from frying. Does this mean i have fault 04 if so does this mean i may have a faulty igniter or flame sensor or maybe a faulty as described in the mech drawing SWITCH OVER TEMPERATURE 120 degrees celsius. Am i correct here? Is this the over temperature cut out switch? if no one can really pinpoint which part requires replacement, can you at least, in sequence advise which parts to purchase? so then ill just try my luck. i wonder how to properly test if flame sensor, igniter, over temp etc is faulty with a multimeter. do i just perform a continuity test. I wonder what other parts can i test related to this fault im getting.
Jul 22, 2018 | Vulcan Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
