Question about Freezers
Is there a difference between the fibreglass insulation used in the lid of a chest freezer and the fibreglass insulation used in the walls of a home?
    Top Expert:
  • Freezers Master
  • 49,241 Answers
Of course there is . much denser and air tight
Posted on Dec 10, 2016
Ice on the inside walls of chest freezer
Check the seal around the lid sits firmly on the rim, give it a good defrost before restocking. Make sure all else is working and clean, particularly any condenser grilles / fans.
Mar 23, 2014 | Kenmore 14.8 cu. ft. / 419 liter Chest...
I have a woods chest style deep freeze and the lid is very cold on the outside, but the sides are room temperature and the freezer works fine. Why is the lid cold and how can I fix it
Yes, the freezer temperature means the lid gets very cold. Every time you open it some moisture condenses in the lid and the outside ambient also affects it. The insulation may be beginning to break down and the ice is forming inside. It is not a major problem however and many freezers go on for years with freezing lids!
Apr 18, 2012 | Woods Chest Freezer C1501W3
Lid of my chest deep freeze is cold on the outside
Normal phenomenon due to inside temperature and insulation properties of lid. Nothing to worry about unless you start getting bad condensation on the lid, when it's time for a new freezer!
Apr 18, 2012 | Woods Freezers
you can put insulation over the wires no problem at all, the insulation it would have been is prob styrean. you can buy it in different thickness sheets
Nov 13, 2008 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Kenmore 12 Chest Freezer - Needs New Lid
All you need is the model number
It gives you a list of all parts you can buy to replace what's broken, as for the frost try placing a sheet of plastic over the insulation, under the the plastic cover to keep moisture and humidity out of the insulation.
Apr 25, 2008 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Door liner on chest freezer broke due to ice build-up
if you can't find a replacement, use a piece of flat vinyl siding that goes on houses. You can heat it and bend it as needed, or cut it and screw the pieces to a balsa wood frame for lightweight support. Glue or epoxy probably won't work as the cold temps make them brittle but external caulking may be ok to hold the pieces together. Be sure to sand all edges and corners as the cut plastic can be sharp. If you can disassemble the unit and place the door face down, you can fill the cavity with insulating foam to help stabilize it.
Nov 27, 2007 | GE 25.1 cu. ft. / 711 liter Chest Freezer...
Freezers Logo
135 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
