Question about Refrigerators
I hava LAMAIR RD 320FF. It's leaking water inside from underside of freezer 2 fridge compartment but cannot wk out how 2 access back of fridge or inside freezer.Any suggestions/manual 4 this fridge?
  • 1073 Answers
SOURCE: Maytag side by side refridgerator
the drain tube is clogged or maybe frozen, remove the restriction and you will have no more problem
Posted on Apr 10, 2008
SOURCE: Water leaking from freezer down back wall inside fridge
I have a GE Profile Perfomance Model 22 ( TN22PRCBRBS)..I`ve had it for 11 years and I`ve noticed a leak developing from my ice maker onto the base of the freezer..I`ve had to chisel the ice that continously forms everyother day..I checked to see if I could investigate but I can`t get to the source ,which is the water line connecting to the ice maker itself..Any suggestions?
Posted on Jun 18, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: fridge is leaking from freezer to top shelf
This is the drain tube that runs in the back of the freezer on the bottom is pluged. Take a sprayer with some hot water in it and flush out the system. Remove the food so that you dont get any of the stuff on it.
Posted on May 21, 2009
  • 93 Answers
SOURCE: Water setteling on bottom of freezer side and
Clean out the defrost drain. There is a drain in the freezer that lets all the defrost water run under the fridge. If that gets clogged then all the water runs into the freezer and can even leak onto the floor
Posted on Sep 14, 2009
aasc
  • 1606 Answers
SOURCE: leaking inside regrigerator
This is a common problem with top mount freezers and an easy repair .Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Posted on Apr 11, 2010
Water from defrosting leaks into the bottom of the freezer and freezes into a solid sheet of ice, which I chip out every 1 to 2 weeks. Kenmore bottom freezer refrigerator Model 795.65002400.
If water leaks inside your refrigerator
(and it WILL, at some point) you can fix
it yourself.
In the good old models, one had to defrost the
fridge every few months manually.
In the recent models, the fridge defrosts automatically,
once or twice a day, and the water is supposed to drain
down a long drain tube into a pan located at the bottom of
the fridge. This collected water in the pan evaporates
by the heat under the fridge.
Now the drain tube can get clogged, by food debris and/or
ice. Thus when the water cannot drip through the drain tube
the water drips inside the fridge.
The drain tube is located behind the fridge, which is pretty
easy to take it out and clean. However usually the clog is
not in the long tube but in the connector assembly located
in the backside of the fridge that leads to the long drain tube.
To get to the connector assemble, you need to unscrew and
take out the back panel of the freezer compartment. You would
see the evaporator coil and a tray under the coil where the water
is supposed to drip through. If you find the tray completely frozen
with ice, let it melt off. To speed up melting, you may blow
hot air via a hair dryer. Once the ice is clear, you should see
a drain hole in the middle of the tray. This could be clogged,
which needs to be unclogged.
Next unscrew and open the thermostat control assembly located
in the inside of the back of the refrigerator compartment just above
the light bulb fixture. Once you take the take the cover off (you will
also have to take the knobs out) you will see a small tray cup about
2" x 2" x 1/2" into which water from the top freezer compartment
drain hole is supposed to drain. Pull out the tray cup, and if clogged,
unclog it, clean it and put it back.
To check if the drain works ok, pour some water on the tray
under the evaporator coil (top freezer compartment) and see if it
immediately drains into the tray located at the bottom of the fridge
at the floor level. If it does, you got it; and you can assemble things
back in the reverse order you took the pieces apart.
Needless to say, use a vacuum cleaner with a long suction tube to clean
out all the collected mess under the fridge. No matter how good
your housekeeping is, the bottom of the fridge will be full of dust.
Good luck and hope this helps
Aug 01, 2010 | Kenmore 65212 Bottom Freezer Refrigerator
Tip
Water Leaking Inside Refrigerator
it yourself. My 26 year old fridge was leaking
and I fixed it completely. It is a Kenmore
top freezer, bottom refrigerator model.
To get to the connector assembly, you need to unscrew and
the light bulb fixture. Once you take the cover off (you will
With lot of patience (I mean lots of it) you should be saving hundreds
of dollars. Attached are some pictures I took. Call me before you dig !
on Mar 01, 2010 | Refrigerators
How to resolve our "lack of water" issue..within the last few weeks, the water dispenser's water flow lessen with each day-now it does not just doesn't work
there may be a problem with the water lines or bottles in the fridge compartment is frozen raise the temp in the fridges to about 38 for a couple of days and this should unthaw the lines
Apr 13, 2010 | LG LFX25971ST Bottom Freezer French Door...
Kenmore Refridgerator leaking water into refridgerator compartment from freezer compartment
You most likely have a clogged drain. When you freezers goes into defrost every 8 to 10 hours. The frost that is melted during the defrost drains from the freezer either down through the fridge or out the back and down. Either way it drains into a pan under the fridge. This tube is either clogged or the drain it's self inside the freezer is. Most of the time I find peas stopping the water from draining from the freezer. When the water can't drain it leaks through the bottom of the freezer into the fresh food section of the fridge. You will need to fix this because it will cause other problems. The water that cant drain from the freezer refreezes and will end up destroying the foam in the bottom of the freezer. Water will also leak onto the controls located in the part between the freezer and fresh food section ruining you controls.
Please rate this solution
Sep 01, 2009 | Kenmore Refrigerators
Freezer leaking into refrig compartment how do i
need to know the brand or call me at 813-270-4029
Aug 22, 2009 | Refrigerators
LG model GR-620RW leaking water inside at back top
the drain hole (freezer) is blocked,
Apr 08, 2009 | LG Refrigerators
Whirlpool fridge getting water from upper freezer compartment
well if you hat the freezer on top normaly air leaks inside freezer through the drain tube, that air turns into condensation and creates a ice and cloges your drain. now water can drain down to pan everytime ref goes into defrost , and water leaks to bottom section to air ducts and air returns. there are several ways to solve this problem the cheapeste way is to unplug refrigerator for 2 days then plug back up and it should go back to normal another way is to install a heat probe on your drain attached to your defrost heater , and add a grommet on drain tube that will let water drain but it will keep air out and that will solve your problem.
Oct 12, 2008 | Whirlpool Refrigerators
Water and ice in fridge leaking on floor.
you have to defrost the freezer it will take almost a day byitself,but you can speed it up with a hair blower pointed inside the freezer toward the back at the bottom,unplug your fridge and hair blower on low you dont want to melt the styrofoam,put 2 bowls in you fridge top shelf towards the back to catch watr falling from the vents,when you see water come into the pan under the fridge your all set ,clean up water and plug fridge back in,its the drain hose is blocked with ice
Jul 08, 2008 | Refrigerators
Frigidaire refrigerator leaking water inside refrigerator
There is a plastic panel inside the frigidaire looking at the underside of the freezer inside the refrigerator compartment which holds the thermostate dial and the light fixture. remove the four 1/4 in hex head screws holding the assembly. pull the panel toward the front. you will expose the drain hose connection you can let it dangle from the plug wires or remove the panel completely, I worked with mine in place. look at the back funnel shape drain. just in front of that see a rectangular styroform collar which should be snug fit to match the underside. clean and dry all. there is a divider between the two funnel compartments, mine was separated between the plastic and the styroform. I used kitchen and bath tub caulking to seal the gap. and a little around the rectangle shape that fits to the underside. plug the wire back in if disconnected. reassemble the panel. that may fix it. good luck.
May 25, 2008 | Refrigerators
Water leaking inside refrigerator
With lot of patience (I mean lots of it) you should be saving hundreds of dollars.
If you still have problems e-mail me at walkhill@cox.net
May 31, 2007 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
