Question about Pelonis Heating & Cooling
Heater wont put out heat
My pelonis heater is new light is on at 2 1 but no heat5 is coming out
SOURCE: caution light comes on,rarely used heater. any thoughts?
Try calling 1-866-876-4332 ext 224 for tech help, it worked for me.  I only needed a temp
setting/off switch to fix mine.
Posted on Oct 23, 2008
  • 3 Answers
SOURCE: I need a new thermostst and on off switch for a pelonis wm-ho202C
Posted on Feb 23, 2009
  • 11896 Answers
You can find your manual here:
And for electric type you can get it here:
Posted on May 15, 2009
  • 1515 Answers
SOURCE: Pelonis heater does not heat
Hi, Have you checked to make sure that there is power at the outlet you are plugged into? I have looked up some information on this heater and it is in the top 5 oil filled heaters. I do know this, they are maintainence free. They are sealed and no place to fill will oil as the oil is heated to a certain temperature and not enough to burn the oil, so they never have to be filled. Anyway, check for power, and if you have power, check the cord over for any damage. If you can't find anything, you have a internal problem with the control on this heater. This is something you may want to take in to a appliance repair store and have checked out. There is no fuse to replace, so I would say a problem in the circuitry. There is not much for me to walk you through other then what I have mentioned, that it is getting power and cord is good. Please keep me posted.
Posted on Feb 02, 2010
Testimonial: "They got back to me fairly quickly and although the problem was not solved. He did answer my questions. I believe it is a problem for a service repair"
  • 20 Answers
SOURCE: I have a pelonis fan forced heater model hf0020t
Check for the wires..r dey loose or not??
Posted on Nov 25, 2014
My utility heater by Pelonis model hb301 serial no. 3011137160 will not heat up anymore .
the over temp safety switch has failed. It is replaceable but is a pain to change as they are usually attached with special high heat crimp terminals. there should have been a a warning light on the front that is supposed to warn you when the high temp switch has been activated.
Feb 15, 2015 | Pelonis Heating & Cooling
Radiator lights up but will not produce heat.
burnt thermo fuse or element. be sure to connect any wires tightly if you replace thermo fuse. test it with a mulimeter should show less than 1 ohm.
Mar 24, 2014 | Pelonis WM-HO202C Oil Filled Radiator...
Pelonis oiled filled heater ho-0218 won't heat up
burnt thermo fuse or element. be sure to connect any wires tightly if you replace thermo fuse. test it with a mulimeter should show less than 1 ohm. no you do not need to add oil, if the unit leaks throw it out.
Mar 24, 2014 | Pelonis Heating & Cooling
Only warm air
If its' tank is full of water then empty it. If it is not full of water then the switch underneath the tank may be faulty
Apr 19, 2010 | Pelonis KCD-25YI Air Conditioner
The oil does not circulate or lubricat anything. It just holds heat. No harm done.
Dec 01, 2009 | Pelonis WM-HO202C Oil Filled Radiator...
When temperature is placed on HI, very little heater comes from heater
if the fan is blowing air normally, but the heat is less! than you need to replace the heating coil of the heater. i'm sure your problem will solved................have a nice day:-)
May 13, 2009 | Pelonis WM-HO202C Oil Filled Radiator...
Pelonis HO-0128 makes strange noise
Nothing wrong with it. This is a normal sound made as the oil heats. As the heater heats up, the sounds should subside.
Nov 19, 2008 | Pelonis WM-HO202C Oil Filled Radiator...
Won't heat
Is there a thermostat? where are you from and do you understand electrics? do you have a volt meter?
Dec 22, 2007 | Pelonis WM-HO202C Oil Filled Radiator...
Heating & Cooling Logo
43 people viewed this question
Top Pelonis Heating & Cooling Experts
Paul Carew
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Pelonis Heating and Cooling Expert? Answer questions, earn points and help others
