My friend who lives in Philippines bought a centrix cxl2203 T V and I want to know if there is a energy saver mode in the picture settings mode
  • 2072 Answers
SOURCE: Sleep Mode
Yes there is.But let me give you an explaination of somethign in the scanner.Once you turn the power save mode off, If the copier has sat for a while and saws WARMING UP, It is not the power save setting. The scan lamp also has to reach operating temperature for the machine to run. So even after Power Save is off, you may get an occcasional Please wait Warming up before a copy. There is no settings or changes for the scanner lamp warming. I throw that in so you don't suspect you did something wrong in changing settings.
Press the [Machine Status] button on the Control Panel. 'Machine Setup' will be displayed on the Display Screen.
  1. Press the [Enter] button. 'Machine Setup Tray 1 Size' will be displayed.
  2. Press the [Left] or [Right] arrow button until 'Power Save' is displayed, and then press the [Enter] button.
  3. Press the [Left] or [Right] arrow button to select 'On' or 'Off' to enable or disable the Power Save mode.
  4. Press the [Enter] button to save the setting.
  5. If Off is selected, skip to step 9.
  6. If On is selected, press the [Left] or [Right] arrow button to select the required time interval.
  7. Press [Enter] to save the setting.
  8. Press the [Stop] button to return to the Standby mode.
Posted on Jan 11, 2008
  • 21 Answers
SOURCE: Wake up from energy saver mode
the menu where you set the time once you've scrolled though all the time options will give the option of disabling it.
Posted on Sep 16, 2008
  • 653 Answers
SOURCE: Do not know how to use the energy saver feature
When u press the Energy Saver button, The machine will enter Energy Saver mode where all the display lamps are light off. Just leave Energy Saver mode, just press again the Energy Saver button.
Posted on Feb 22, 2009
SOURCE: Child Lock on or Flashing Energy Saver Dry
I suspect that the cycle "button" on the control panel is intermittent.  Try using a different cycle - If you always use "short wash", try the "normal" cycle.
This worked for me.  It will be too expensive to repair, so I am dishwasher shopping.
Posted on Mar 01, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: Rinnai Energy Saver 1001F
Try this link http://www.rinnai.us/documentation/downloads/Owners_Manual_1001-551.pdf
Posted on Sep 09, 2009
How do you turn off power saver on frigidaire air conditioner
Good Afternoon Friend,
I understand you want to know how to turn off the power save mode for your Frigidaire air conditioner, model# FFRE12L3Q1. Your appliance will run in energy saver(econ) mode when used for the first time. In this mode, the fan will continue to run for 1 minute after the compressor shuts off. The fan then cycles on for 20 seconds at 10 minute intervals until the room temperature is above the set temperature, at which time the compressor turns back on. You will be able to turn the energy save mode off by selecting your temperature as well as your fan speed. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 30, 2014 | Frigidaire Heating & Cooling
My Canon image class MF5350d won't go into energy saver mode anymore
Odds are that some one did some panic button pushing at one time. You need to look in your owners manual or down load one from the web. Or you can go into the user settings and scroll down to were you see a setting for energy save. Good Luck
May 20, 2013 | Office Equipment & Supplies
How to disable energy saving on KitchenAid Range
The Energy Saver Mode deactivates the display to reduce energy
consumption.
To Activate the Energy Saver Mode:
1. Press and hold OPTIONS for 3 seconds. "Energy saver on."
will appear in the upper text area.
2. The setting will be activated after 5 minutes.
Any cooking function may be used with the range in Energy
Saver Mode by simply selecting the desired function.
To Deactivate the Energy Saver Mode:
1. Press and hold OPTIONS for 3 seconds. "Energy saver off."
2. The clock will reappear in the display, and the range can be
operated as usua
Oct 10, 2012 | KitchenAid Ovens
How do i turn off energy saver toshiba e studio 203d
May 18, 2012 | Toshiba e-studio 203sd
Remove screensaver from TV
Hello
You are refering about energy saving function I thinks. To energise this function, surf through its menu and come towards energy saver.
This power saving feature reduces the backlight
brightness level. The options are:
OFF-the feature is off and the power consumption
is normal.
LOW-power saving level is low and the backlight
brightness level is lower than normal.
HIGH-power saving level is high and the backlight
brightness is set to the lowest level.
1 Use the CURSOR Up or Down keys to highlight
Energy Saver. Press ENTER.
2 Use the CURSOR Up or Down keys to select Off, Low,
or High.
NOTE:The Energy Saver settings level varies with
the Picture / Sound mode.
OK.
Feb 20, 2011 | Sanyo 42 in. LCD TV
Model number HBLG 12303r how does the energy saver setting work bought this model used.
The energy saver setting will turn the blower fan off when the thermostat reaches the desired room temperature (with the compressor). Other non energy savers only cycle the compressor to regulate the room temp. so their fans will operate continusously using more electricity.
Aug 04, 2009 | Heating & Cooling
i have a problem for minolta di351 by code c009 pls help me
Feb 21, 2009 | Toshiba e-Studio 350 Copier
Jul 10, 2008 | IBM 6400 Matrix Printer
Energy saver mode
Yes you can change the power save mode. I don’t remember from where you can change it. but its easy for you if you get the all operation manual list form the printer, get the setting page from printer by pressing the menu from your printer then you will get all commands so then you can change all settings of your printer.
Nov 30, 2007 | Konica Minolta PP9100 N Economical...
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
