Question about Food Mixers
Sunbeam. Mixmaster. The tilt Release. Will not release. Bowl and beaters are under the head how can I fix it
4 Suggested Answers
SOURCE: Sunbeam Mixmaster Heritage series
I hope this helps. I found on mine that the rear screw on the "neck" had become slighty loosecousing the release to not fully disingage. I had to remove the dome shaped cap in the middle of the speed control knob, pops off fairly easy, to gain access to the nut to tighten it. Hard part was trying to hold the screw head still while I used a small screw driver and small hammer to tap the nut tight, very limited space between the "neck" and motor body.
btsctn
Posted on Oct 22, 2008
SOURCE: Sunbeam Mixmaster Heritage model Tilt mechanism
Theory: Its a screw at the joint that is lose.
Problem: If I held mine upside down it released but wouldn't when right side up.
Partial solution (in progress): It took me an hour to disassemble the monster as I lost the "NUT" inside the motor - the nut is inside the motor case and attaches the lock-lever and a ground wire to the motor case. It makes some sense since it is a part that can strip out if it has to be tightened too many times by a gorilla - a nut is "easy" (relatively) to replace. Prevents you from having to buy a new one at least. Wish they would engineer this better.
Current status: I finally fished it out but have to put it back together now to prove my theory. You cant get into the motor case easily - but I found out that you don't have to get into the motor case if the screw is still semi-attached. I only had to undo the the base to get to the hinge. Then I could tighten the screw. I am an AMATURE - so at your won risk. They make these things so you need to send them in. This most likely seems to be what I have to do now.
Posted on Sep 25, 2011
dewwhachawan
SOURCE: Motor head will not tilt back
Push down slightly on the head and then the button will go in further and the top will release. ((this answer after I just bought it home and was about to take it back to the store!!))
Posted on Dec 15, 2012
How to remove beaters from Sunbeam Mixmaster. I see no release button.
On a Hand Mixer
Push the speed control wheel PAST Off. Push Forward
Release Beaters
Off
One a Stand Mixer, it is specific to the model. All the manuals are here
http://www.sunbeam.ca/en_CA/service-and-support/instruction-manuals/kitchen-appliances/mixers/kitchen-appliances-stand-mixers-manual.html
Button A on this one on the side of the head.
http://www.sunbeam.ca/on/demandware.static/-/Sites-sunbeam-ca-Library/default/dw20734b3d/documents/instruction-manuals/2379%20Stand%20Mixer%20IB.pdf
Apr 28, 2018 | Sunbeam Food Mixers
What is the difference between square beaters and round beaters for my sunbeam mixmaster
Different beater shapes were used over the years. Mostly they are optimized for the bowl shape and the power of the motor. Best results by staying with the original shape when replacing. Goodmans is a good source of beaters
Goodman Small Appliances Housewares and Parts Sunbeam Oster Braun etc at...
Feb 19, 2018 | Sunbeam Food Mixers
Why does my sunbean mixmaster bowl don't spin?
the spinning plate under the bowl does not have any power to spin the bowl; it only aks as a "lazy susan" carousel that allows the bowl to turn from the movement of the material being wipped in the bowl.
the beaters are purposely off-center of the bowl in ordwer to create a dragging motion of the material in the bowl, thus pulling (that is, spinning) the bowl slowly. If the beaters are not off to the side of the bowl, you will not get the pulling/spinning motion. Also, if the plate under the bowl does not move very easily, then the bowl will not spin. You may have to remove the spin plate and clean the center pivot for the plate to move freely. Good Luck, Macgivor.
Nov 27, 2010 | Sunbeam 2346 Heritage MixMaster Series...
The release button to raise the body to take off the beaters will not release. I can't get the bowl out or remove the beaters. Please help.
Put a few drops of cooking oil in the holes the the beaters are inserted inMake sure to unplug the unit. Pushing the button, work the beaters pulling lightly. Good Luck
Aug 11, 2010 | Sunbeam 2370 MixMaster Series Stand Mixer
I can't get the tilt release to release to raise the mixer . I have a batch of cookie dough in the bowl and I am unable to raise the mixer
Try running the mixer for a few seconds to clear anything out from under the beaters, like a chocolate chip. You can also try pushing down on the beater end of the mixer, press the button and lift.
Nov 01, 2009 | Sunbeam 2346 Heritage MixMaster Series...
Oct 11, 2009 | Sunbeam 2370 MixMaster Series Stand Mixer
Sunbeam Heritage Mixmaster Won't Tilt back
Hi
Most of them have a button to push that releases the mixer head to tip back. Sometimes the buttons stick and will not release. That picture looks like you are using the Heritage model.
You have to remove two parts in order to get access to the piece that was causing the problem:
1) The "torpedo" shaped knob that sticks out from the mixer speed dial;
2) The speed dial itself
Both of these pieces clip-in, and can be removed with a screwdriver by pressing in on one of the hooks that hold them in place.
After these two pieces are removed look for a small washer right below the motor (it is sitting on top of the upper portion of a screw) -- in my case this washer had come loose; tighten it with a 1/4 size wrench (you can also tighten it by hand to release the tilt, it will probably become loose in the future if you don't tighten it further, but if you don't have the necessary tools this will at least allow you to get your tilt unlocked).
On another note, after tightening this washer you may also notice that the tilt release had become easier to use -- previously you may have found that you have to press the tilt release button very hard to get the tilt to unlock.
Please do accept the solution and revert for further assistance.
Thanks
Rylee
Jun 12, 2009 | Sunbeam 2346 Heritage MixMaster Series...
Instructions for Sunbeam 2350 Heritage Series Mixmaster
Go to sunbeam.com, select "kitchen", then select "customer service", then "instruction manual", then "stand mixers", scroll down to model #
Nov 23, 2008 | Sunbeam 2350 Heritage Series Mixer
btsctn
Jun 14, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Food Mixers Logo
62 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
