Question about Uniden Lands Phones
What is the default Set Line Mode for a Uniden 6.0 cordless phone
Larine.
press at the same time off and * keys during a few seconds, you will see on the handset screen the menu to do this
Posted on Jan 03, 2017
  • 218 Answers
SOURCE: Need an owner's manual for Uniden EZ1996 Cordless Phone
Here it is.
http://www.uniden.com/pdf/EZI996om.pdf
Posted on Dec 28, 2008
SOURCE: How to set up Speed Dial on a Uniden phone?
My Mom had this same problem.   I found these instructions on Uniden's website (uniden.com) under the "Owner Manuel" section.
Here you go - good luck!
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers (up to 20 digits each) in the speed dial
memory. To store number in memory:
1) When the phone is in standby, press [memory]. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number.
 (To enter a 2-second pause between numbers, press [redial/
pause]. Each pause counts as a digit. )
3) Press [memory] again.
4) Select the speed dial location where you would like to store the
number ( [0] to [9] ). You will hear a confirmation tone indicating
that the number has been stored.
NOTE:
• Storing a number to a speed dial location will
overwrite the any previously stored number without
warning.
• When storing numbers into memory and the handset is idle (i.e., no key is
pressed) for more than 0 seconds, it will beep rapidly, and then the phone
will return to standby.
Dialing a Stored Number
1) When the phone is in standby, press [talk], and listen for a dial tone.
2) Press [memory] and enter the speed dial entry ([0] – [9]) that has the stored number
you want to dial. (If you enter a digit that does not contain a stored number, the
handset will beep rapidly, and the phone will not dial.)
Chain Dialing
The speed dial memory is not limited to phone numbers. You can store any number (up
to 20 digits) that you need to enter once your call connects. This is referred to as Chain
Dialing. An example is a frequently refilled prescription number. Store your pharmacy
phone number in one speed dial and your most frequently refilled prescription number
as another speed dial. To use, once you ring your pharmacy's automated prescription
line, simply press [memory] and the speed dial number where you stored your account
number.
Erasing a Stored Number from Memory
1) With the phone in standby, press [memory] twice.
2) Press the number of the speed dial entry. A tone indicates that the stored number is
erased from memory.
Posted on Feb 05, 2009
SOURCE: how to take silent mode
To turn off silent mode, press the "#" and hold down until it changes. :)
Posted on May 15, 2011
  • 5102 Answers
SOURCE: how do you trn a uniden D1660 cordless phone off
To exit the silent mode, press and hold # on the handset for about 5 seconds. In the future, when you set the silent mode with this press and hold routine, you can follow it by a number (1-9) to set a specific length of time for the handset to be silent. Otherwise it will stay on until you manually turn it off.
The manual for the D1660 is available from http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1660-2om.pdf .
I hope this helps.
Posted on Jul 01, 2011
SOURCE: how do you turn off silent mode on Uniden DECT 6.0
In standby mode pressing and holding # brings up the "Silent Mode" special feature .. unfortunately the only options are to set the time for the device to be in silent mode and no way to turn if off. The solution is supposedly to press the # key again and hold it down, but this does not work either. The only way I can manually return to not be in "Silent Mode" is to reset the base unit!!
Posted on Mar 07, 2012
Answering machine is in announce only, how do I get it to answer mode
Press MENU/SELECT, select "Answering Setup," then select "Ans. On/Off." See the instructions beginning on page 9 of the manual: Owners Manual User Guide for Uniden D1483 Dect 6 0 Cordless Phone With...
Dec 31, 2014 | Uniden D1483 Dect 6.0 Cordless Phone With...
Uniden cordless dct646-4 phone
Check the ring volume and settings? There not much else I can think of.
May 28, 2008 | Uniden Cordless Phone
How to change silent mode from on to off?
you have to go to settings., and from there, profiles section to change the mode silent to general model.
Nov 18, 2014 | Uniden DECT1560 DECT 6.0 Single-Line...
Set line mode
Since you didn't specify the model of your Uniden DECT 6.0 phone, please select it from the list beginning at http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl
Oct 29, 2013 | Uniden DECT 6.0 Cordless Phone ID
Set line mode tone
Since you didn't give the model of your Uniden DECT 6.0 phone, please select it from the list beginning at http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl
How do you trn a uniden D1660 cordless phone off of silent mode
I hope this helps.
Jul 01, 2011 | Uniden D1660 Cordless Phone
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
My phone is stuck on rotary dialing. My handset had all the options but the dial mode. After caller id setup it went straight to languages and then started back over with ringer volume.
1) When the phone is in the standby mode, press menu/mute.
2) Press - to move the pointer to “Dial Mode”.
3) Press select/ch and the display will show the current setting.
(The initial setting is Tone.)
4) Press + or - to change the selection.
5) Press select/ch and a confirmation tone will sound.
6) Press end to exit.
Customer Help line for UNIDEN 1-800-297-1023
May 30, 2009 | Uniden TRU 448-2 Cordless Phone
My uniden 5.8 ghz will only ring 2 times. I have
Reset the base by unplugging power from back of base, press and hold the delete key while reconnecting power
Mar 04, 2009 | Uniden DXAI8580-3 5.8 GHz Trio 1-Line...
Lands Phones Logo
75 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
