Question about Technics Audio Players & Recorders
Cant find place to order a needle for a technicue turntable.
A site or store branch would be fabbbbb!
Its a SL-BD26 older turntable individual piece not a system or block system as i call them.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 108 Answers
You can order a stylus 'needle" at the following link.
http://www.lptunes.com/Technics-turntable-stylus-s/321.htm
Posted on Jul 20, 2009
Need needle for SL-D1 turntable
You may want to try here: http://www.needledoctor.com/Online-Store/Panasonic-Technics
Mar 02, 2015 | Panasonic Turntable Dust Cover Technics Sl...
Cannot connect ground wire on SL BD26
Usually, on Technics turntables, the ground wire is attached to a ground lug on the receiver.
Dec 30, 2013 | Technics SL-BD22 Turntable
Needle sliding
Going on what little you have written, the most likely cause is a worn or bent needle. http://www.turntableneedles.com/search.asp?keyword=793-d&search=GO is the needle type that should be correct for your Teac SL-A100 Turntable.
Feb 16, 2013 | Teac SL-A100 Turntable
I've just set up my Technics SL D212 turntable after moving house. It keeps skidding across records. I've tried the usual adjustments and leveled the turntable. Any clues?
Please make 100% certain the needle is still in place... To test this *GENTLY* rub your fingertip over it and you should hear noise from the speakers when you do. If there is NO noise then there is likely no needle.
Did you put the protective device on the needle/arm for the move? Is it still on there?
Sorry Mate, that the only thing I've got to help....
Feb 20, 2012 | Technics Audio Players & Recorders
SL-1200 Turntable: I own two Technics SL-1200mk5 turntables. My probl...
Hi, could just be platter not fitted hard down on spindle. I suggest you remove the platter and place it upon a dead flat surface to check to see that the platter is flat. If it is flat refit to turntable ensuring it is hard down on the spindle. If bent discard and replace with new platter.Platters can be ordered for all model 1200/1210 from styluscity@gmail.com
May 16, 2010 | Technics SL-1200 Turntable
One of of my technic 1210's keeps picking up dust and the sound quality is poor regardless of the needle. It has ruined 2 needles now and and im not sure the problem is. The weights are not too heavy so it...
Are u sure it's not the needle? What brand needles are you using and I usually recommend people have small fans by turntables to have airflow so dust doesnt become a problem, expecially for DJ's
Nov 25, 2009 | Technics SL-1210 Turntable
NEED A BELT FOR MY DC SERVO AUTOMATIC TURNTABLE SYSTEMS SL-B210
You have to check an electronic store. If it does not have old one get a piece of string and measure around where the belt goes so you can know how big it is. Or you would have to order online, russell electronics sells all type of electronic belts you would have to search for a radioshack or another electronic store in your area.
Aug 20, 2009 | Technics SL-1210 Turntable
I've knocked the start button off my 1210's..brass shaft has dropped..HELP !
No easy way to fix this. You can do this one of two ways:
1) The correct way
You'll have to open up your turntable, and this means going in from the bottom. Instructions for opening your turntable are located HERE. Once your inside, you'll see the area where you need to be working. You'll need to order a new On/Off switch, which can be found HERE. Just put back on the way you took off the old one, and that's pretty much it. There is a small spring and a small metal ball bearing you have to be careful you don't lose when removing the old power knob shaft. This is held down by a cir-clip on a white plastic piece. You have to remove this piece in order to swap out the old brass shaft with the new shaft/knob.
2) The incorrect way - but easy to do.
Try and grab the brass shaft with a pair of needle nose pliers or similar. Grab your broken On/Off knob and put some crazy glue on the inside where the shaft aligns. Carefully place the knob on the shaft, and hold in place. This will be somewhat tricky, but you'll figure out a way. You might have to flip your turntable upside down in order to get the shaft to stick out. Just make sure if you do flip the turntable upside down, that you don't rest your turntable on your tonearm - otherwise you'll have an even bigger issue.
Good Luck!
- DJ PRO LAB
www.djprolab.com
Apr 23, 2008 | Technics SL-1200MK2 Turntable
83 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
