Question about Home Security
How to set a if86-244 white Rogers thermostat
2 Suggested Answers
  • 134 Answers
SOURCE: I need instructions to set
The Operating Manuals for many White-Rodgers thermostats can be found in PDF form HERE, however they are not indexed by model number so you will have to download each file in turn until you find the one you want. All of the file names beginning with "0037-" seem to be W-R products. *Disclaimer: I am not a lawyer, despite the handle. Words to live by: "Every creative act results from a sudden cessation of stupidity." -Edwin H. Land, inventor of the Polaroid Land Camera "The problem can always be solved with the materials in the room." -My college Physics Lab Professor
Posted on Feb 03, 2011
Does white Rogers thermostat 1f56n-444 have a reset button
White Rodgers 1F56N-444 User's Manual - ManualAgent > White Rodgers Manuals > 1F56N-444
White Rodgers 1F56N-444 PDF User's Manual Download & Online Preview. ... Download Air Conditioners User's Manual of White Rodgers 1F56N-444 for free. .....Set anticipator to match the setting of your old thermostat you noted in Step 3, ..
Aug 04, 2015 | Home Security
My thermostat show 74 degrees as a current room temp...but we have it set at 70 and it's probably 65 in the house. ..the only way it will turn on is if I put it 74 or 75????
The old white-rogers thermostats with a mercury switch are adjustable. snap the face off. In the center you will find a plastic slot screw. set the indicator to the actual room temp.
Other type ? Replace the thermostat
Mar 01, 2015 | Heating & Cooling
Connecting 2 wire thermostats to white-rogers type 1311 3 wire zone valves
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. Make sure to connect a thermostat that will power open and powered closed the zone valve. I pretty sure that the two wire thermostat that your going to connect will not be compatible. To better assist you with this further contact us directly at 18002842925.
Oct 15, 2012 | Heating & Cooling
White Rogers digital thermostat displayed "lo".
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. After replacing the battery you need to do the reset operation. If you need further assistance please contact us at 1800-284-2925.
Sep 24, 2012 | Heating & Cooling
My white rogers 1f78-151 programmable thermostat is set at 76deg. but will only cool to 79deg.
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. Reset the unit by pressing UP, DOWN and TIME buttons all at the same time. The unit will go blank for a couple of second then operate the unit. If this did not resolved the problem contact us directly at 18002842925.
Sep 11, 2012 | Heating & Cooling
White rogers manual
Hello my name is Heath it will be my pleasure to assist you. There are many models of white rogers thermostats I would need t know the model to get the correct manual.
Oct 08, 2010 | Heating & Cooling
Auxiliary light was lite on my white-rodgers 1f82-51 thermostate and i have no heat?
follow this guide:
Diagnostic: Set SYSTEM Switch to HEAT and raise
the setpoint above room temperature. Within a few
seconds the thermostat should make a soft click
sound. This sound usually indicates the thermostat
is operating properly. If the thermostat does not
click, try the reset operation. If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the furnace manufacturer or a service person to verify the heating is operating correctly.
Mar 01, 2010 | White Rodgers White-Rodgers 1F85RF-275...
My white-rogers 1F81-261 model thermostat keeps rgoing back to a 62 degree setting after the furnace kicks on at a setting of 72 degrees. I have reset the program, but that doesen't seem to help. What can...
• HOLD TEMPERATURE — With the SYSTEM switch set to
HEAT or COOL, momentarily press HOLD button. HOLD
will be displayed. Use UP or DOWN to adjust the temperature.
The thermostat will hold the room temperature at the
selected setting until you press RUN button to return to
program operation.
This is on page 6 of the manual
Link: Installation Instruction
Feb 06, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Home Security Logo
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
