Question about Pool & Spa
Looking for a manual for a Eco Chlor RJ30 Salt Water Chlorinator
SOURCE: I have an intex salt water chlorinator and I have
Here is the website for all manuals! http://www.intexstore.com/default.aspx
All are dowloadable. Good luck!
Posted on Jun 23, 2009
  • 297 Answers
SOURCE: i have a 18ft x 52 intex pool with salt water chlorinator.green
although you may or may not have enough chlorine in your pool you must also realize that a pool need turned over at least 3 times a day.
an example is if you have 7000gl of water and a 2000gph pump you need to filter at least 10 hours or so.
More important than chlorine is the actual circulation of the water you can have all the chlorine in the world but if you do not have the circulation the water will become cloudy or green this also happens when you have no swimmers for days at a time
the filtration time is over and above the chlorine generating time your 4 hours a night for generating chlorine sound like you are guessing sometimes it may be 4 and sometimes 2 or 6
it depends on # of swimmers a day sun and what was in the pool to start
It is important to have a test kit for ph and chlorine and keep chlorine at 1.0to 1.5 now set your ph
ph will rise and fall with your chlorine level one you have them set good at the first time then ph should stay safe enough and re level as chlorine is kept right
also remeber that the wrong ph causes more problems than wrong chlorine levels
Also make sure your salt is no more than 3000ppm and no higher like some people recommend and no lower than 2500 test kits are available for 10 dollars
all of this can be found on intex.com either in a video or pdf files for water capacity and approximate time for generating chlorine.
to be sure always use test kits
Posted on Jul 12, 2009
  • 297 Answers
SOURCE: CLOUDY SALT WATER POOL
salt does not solve your problem.
People do no realize that all the salt does for you is that it eliminates having to pour regular chlorine in.
Everything else stays the same as a normal pool with just plain ole h2o
The dilema is that intex filters are to small for the job that needs done especially in your case now that you have the dreaded green monster
your solution is to first get it cleared up
shock your pool with 2 gallons of liquid chlorine and then filter filter filter
You will need to brush the dead algea and vaccum once or twice a day for a couple of days and you must clean that cartridge 3-4 times a day with the garden hose
you will be surprised how much green it will trap
once pool starts to clear and the chlorine level starts to come back down from Mars you can start using your generator again.
you will need to find the amount of time thatorks for you but 3-4 hours will not cut it in the hot weeks
Chlorine consumption is due to #of bathers, heat ,sun, rain so any given day will dictate a different amount of generation needed keep it high so you do not get algea again about 3.0
you also got algea because you were not stiring up the pool enough you again need to filter filter filter every day
try to find some of my other postings with more specifics
Posted on Aug 13, 2009
  • 297 Answers
SOURCE: I have misplaced my manual for the intex 8110 salt
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?lst_docsea=2009&source=intexstore&gid=2&lid=9536
Posted on Jun 27, 2010
Testimonial: "a copy of the manual is just what I needed, I am back in business and the children are happy."
SOURCE: I have a Intex Pool that is 18 ft by 52 in. I have
I have a krystal Clear deluxe Satlwater system recently the water went green(lots of rain) I added more salt and have run the pump extra time. It is better but not back to normal. Do I have to shock it and how do I do that? What and how much do I put in for an soft set pool 18 x 48.
thank you
Posted on Jul 02, 2010
Tip
Solving Salt Water Pool Problems with The Chlorine Genie Chlorinator
Salt Water Pool Systems often are a consumer disappointment when users find out the problems, costs, and maintenance problems of this popular pool technology. Today's video covers some of the common drawbacks, dangers, and problems and offers resources for a solution.
on Nov 08, 2016 | Zodiac Lm3-40 Salt Water Chlorinator...
Why does my salt level get low
You can get a false low salt reading if your chlorinator cell is very dirty. Before adding more salt clean the chlorinator cell as per your maintenance manual.
Sep 01, 2012 | Intex Automatic Salt Water System for ...
We have a 18x48 ultra frame intex pool. It at first gave us a lot of problems saying low salt so we cleaned the cell with vinegar and it began working no probs for the past 3 weeks. On the weekend I went...
I can't explain all of this but to get the rid of the green and reduce the salt level you need to drain half the water and refill. At this you need to shock it so the chlorine is up to about 10 ppm. You need some way of testing to tell this. If your chlorinator is ok then when you start the pump and chlorinator it should continue cleaning it out. The dead algae will be filtered out with the filter. If the flow slows down you will need to clean the filter with a water sprayer on a hose. I hope this helps.
Aug 09, 2011 | Intex Automatic Salt Water System for ...
Hi, last month we bought an intex round pool (18' x 54") with sand pump and salt sanitizer. Within the last 2 days the water started turning green. It turns out my husband accidently set the pump...
You don't want to swim in water that has algae... 1st ...Make sure you have the correct amount of salt. See you manual for amount needed. Must set you pump timer first and sync your chlorinator between that time, if pump turns off before chlorinator cycle ends, you will get an "Low flow" alarm. Set you pump timer to run 12 hours and the chlorinator for 10 to 11 of those hours and should see results within 3 days or so. After that, If you live in an area that is hot, 10 hours pump and 8 to 9 chlorinator... Hope this helps...
Jul 13, 2011 | Intex Automatic Salt Water System for ...
When i turn on the chlorinator its comes on and then turns the power off to the whole unit
Please dragon, Be careful. If the chlorinator is not wired to the unit correctly you could ven have a
flash!! 1. Shut off the circuit breaker located on the house. Ir's located in
metal rectangular panel. Probably next to the elect meter.
2 Now that the power is off check the wiring where the chlor attaches to the pump.
The wires should be color coded. Black & red are always the hot leads, white & green are
neutral leads, Let me know........dansky66
Mar 26, 2011 | Intex Automatic Salt Water System for ...
Intex 9 x 18 ultra pool with salt water system. Came home and low salt light on added up to 40lbs and continues to be on. Don't want to add anymore please advise.
IF YOUR CHLORINATOR IS DIRTY IT WILL GIVE YOU THIS READING. USE HOUSEHOLD VINEGAR TO CLEAN THE CHLORINATOR PLUG 1 END AND FILL ABOVE THE PLATES AND THE COPPER IONIZATION ELEMENT. LET SOAK I HOUR AND BACKFLUSH WITH POOL WATER . HOOK IT BACK IN THE SYSTEM AND THAT SHOULD FIX THE PROBLEM. IF NOT CHECK THE POOLS SALT CONTENT. IT SHOULD BE .003 PPM. IF NOT ADD SALT ACCORDING TO THE MANUAL ON YOUR SIZE POOL.
Jul 29, 2010 | Intex Pool & Spa
Intex salt water chlorinator I added a higher flow pump and chlorine levels seem low no matter how many hours I run the chlorinator
your pump has nothing to do with chlorine generation.
You need to get a salt test kit that reads in #'s not colors.
Now get your salt to 3000ppm or as close to it as you can.
The amount of salt reccomended in the manual is just a starting point
any lower than 2800 and you will not produce enough sanitizer and over 3600 and your pool can go cloudy, taste bad, and rust metal parts
Jun 28, 2010 | Intex Automatic Salt Water System for ...
Heat exchanger leaking after 4 months, this has happened 3 times in 2 years. possible electrolosis problem? the water is balanced no ph problem
I could be wrong, but you do have a chemical problem. Be it PH or chlor. After 35 years in the business I have seen one heat exchanger that came from the factory bad, and none that wore out with out chemical help. If you don't have a PH problem then you have a chlor problem. This is most often at an inline chlorinator that is mounted to close to the heater and lets chlor gas back up into the heater when off or in front of the heater so all the feed is going straight to the heater. This is the more lodgical of the two as fast as your wearing the exchangers out. Green plaster is a big simpton of this as the copper from the heater has to go somewhere. This can be fixed as easy as a chloriene floater or replumb to move chlorinator. Good luck
Nov 09, 2009 | Pool & Spa
Pool & Spa Logo
108 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
