Question about PfaFF Sewing Machines
I have a pfaff 2030/2040 tiptronic. I have had the timing repaired 3times. Will this be a continuing problem. Is it time to replace my machine?
  • 42 Answers
Take it to a different technician. If it is irreparable a good tech will tell you. It is most likely the timing belt tension or a loose screw (or two) on the hook. Once set properly and secured it should hold. If you are attempting to sew too thick of a seam it could jar the needlebar out of position as well.
Posted on Dec 10, 2016
SOURCE: threading the machine
what is the setting to hem
Posted on May 12, 2008
SewExpress
  • 41 Answers
SOURCE: Frozen Sewing Machine Arm/Pfaff Tiptronic 6270
Good morning,
A question to help determine what's happening with your machine(s).
Open the bobbin case so you can see the bobbin area. Begin by trying to turn the handwheel towards you and watch as the needle attempts to go up/down. If you cannot turn the handwheel towards you, turn it slightly backwards then forwards. Does the needle hit the bobbin case as it comes down?
If yes, your machine is out of time and will require a professional technician to repair.
If the above is not the case, there may be thread jammed behind the bobbin case or wrapped around the inner parts of the take-up lever.
Either case - a Pfaff authorized technician would be your best bet for a proper repair.
Best of luck with your machines - it's just awful to not have the at the ready for all our projects!
Happy sewing,
Kim & Linnette
Posted on Jul 31, 2008
SewExpress
  • 41 Answers
SOURCE: 2020 rotary hook continuous one direction pfaff tiptronic 2020
You are absolutely correct - your machine doesn't come apart much because it is an electronic machine. There really are very few moving parts in modern sewing machines - and the electronics are better left to a technician who's been specifically trained.
It sounds as if your machine is no longer in time (needle rubbing the plate as it goes around if I'm understanding correctly). While not really a "major" repair, unfortunately with computerized/electronic machines, retiming your machine is something better left to an authorized Pfaff technician.
If the needle struck metal as you were stitching/basting, there may also be a rough spot/burr on the hook that your technician will be able to smooth off as well.
Hope this helps get you back up and running soon.
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
Posted on Dec 03, 2008
SOURCE: can't open Pfaff Select 3.0 Sewing Machine to fix timing
I found an electric drill with a hex bit and that did the trick!
Posted on Dec 31, 2008
SewTechWayne
  • 186 Answers
SOURCE: Pfaff Tiptronic 6270 just stopped working!
There is a fuse in the the base plate that has blown. It is soldered in and is special fuse you won't find at Radio Shack. Unfortunatly it needs to be fixed by a Pfaff dealer on someone with access to the fuse. If you have the work done, make sure they replace a certain reisitor on the base plate at the same time to prevent this from happening again (per Paff).
Sorry for the bad news and best of luck.
Posted on Jan 31, 2009
I am wondering if it is possible to find the plugin on the foot pedal of a Pfaff Tiptronic 2020
Probably so, however, if may be easier to find a replacement for the ailing part. You may need to search for a donor machine or a foot control that matches your machine. You can also try replacing the entire foot control with a new replacement item.
Pfaff Tiptronic 2020 Parts
If you can't find what you need, contact them directly.
Jul 03, 2017 | PfaFF Sewing Machines
I'd like to download repair manual for Pfaff tiptronic 2020.
If an internet search is unsuccessful, you can try joining the Yahoo Group: Pfaff_fixit
Most of the group members have been repairing Pfaff machines for a long time.
Sep 26, 2015 | PfaFF Sewing Machines
Pfaff 2030 skips stiches
Every time I've had a machine skip stitches it was because I had the wrong needle in the machine. (assuming the needle timing is set properly)
Feb 26, 2013 | PfaFF Sewing Machines
The memory board went out on my 2000 tiptronic 6270 a couple years ago. now the machine won't sew at all. the sewing light comes on, but not the lighted digital readout area. so , no sew. how do i...
that has probably blown. It is soldered in and needs to be fixed by a Pfaff dealer on someone with access to the fuse. If you have the work done, make sure they replace a certain reisitor on the base plate at the same time to prevent this from happening again (per Paff). Sorry for the inconvenience, hope you are back to enjoying your Pfaff machine real soon.
Aug 01, 2010 | PfaFF Tiptronic 2030
Pfaff Tiptronic model 2030 LCD display panel went dark, no display. Now lamp burns hot. Told by local service shop that panel needed to be replace to correct lamp issue. Need replacement lcd panel.
very common prob . with pfath . panel failure . display failure . no easy sol . but to repl pc control panel .. / how ever after repair ( and they never tell us .. use a surge power controler on the line . to your machine .. .. **** .. hope this ansewered your Q " mm feed back pls .. mm
Jan 15, 2010 | PfaFF Tiptronic 2030
HOW MUCH TO BUY A 2040 TIPTRONIC
I found three Pfaff Tiptronic machines on eBay, but not your exact model, but one of the models listed may be acceptable. When I searched, there was a 6720, 2030, and another 6720.
The 2030 was $299. When you click on the link, you may get a different selection because it will search for what is listed at the time you click on this link:
http://shop.ebay.com/i.html?_nkw=PfaFF++TIPTRONIC&_sacat=0&_trksid=p3286.m270.l1313&_dmpt=BI_Sewing_Machines&_odkw=PfaFF++TIPTRONIC&_osacat=0
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 18, 2009 | PfaFF Tiptronic 2040
Jan 15, 2009 | PfaFF Tiptronic 2040
Happy stitching,
Kim & Linnette
Nov 23, 2008 | PfaFF Tiptronic 2030
Good morning,
Happy sewing,
Kim & Linnette
Jul 30, 2008 | PfaFF Tiptronic 2040
Sewing Machines Logo
37 people viewed this question
Top PfaFF Sewing Machines Experts
SewTechWayne
SewTechWayne
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
