Question about Edge Computers & Internet
How to unlock diskgo edge model hd-d1-u2 files?
Hi,I have diskgo edge model hd-d1-u2, a while back I save some files to it. The files are now locked when I try to open them. Original saved on an XP OS now trying to use Win10 or Ubuntu. msg: can't get to file
SOURCE: Adobe Photo Deluxe 2.0
Go into the PhotoDeluxe2.0 CD ROM file list, right click on setup.exe and then go to the compatability tab. Select Win 98/ME. Hit OK. Then double-click on setup.exe. Program should install on Vista. Then find setup.exe on your hard drive, and set the compatability to Windows 98/ME. Program runs, but says something about not being able to load 16-bit driver. Just cancel out of that popup window. Program works fine...for far.
Posted on Mar 26, 2008
  • 10 Answers
SOURCE: Edit host file in MAC OS 10.4
You probably don't want to edit the hosts file on OS X 10.whatever. Take a look at my suggestion over here for what to do instead.
Posted on Sep 23, 2008
  • 326 Answers
SOURCE: Word cannot save file. File cannot be saved after pressing the save button/icon
Here you go. I found the Microsoft documented fix for this issue.
try this site:
Let us know if you are still having issues.
Posted on Apr 17, 2009
SOURCE: 'unable to save file. the system cannot find the path specified'
Had this same problem and just fixed it. You need to actually change the button settings in Navigator. Open MP navigator and choose One-Click, then click Button Settings. You can choose a new save destination from here. Even though you are using the software instead of the button on the device, it works.
Posted on May 17, 2009
  • 3153 Answers
SOURCE: I need a power supply for an Edge DiskGo! USB
Also ensure the current rating is the same or slightly higher
Eg 500 mA
Do not use one with a lower current rating as this can cause problems.
Posted on Sep 18, 2009
Yes..try and use a rear USB connection as these connect directly onto the motherboard...leave a USB cable in situ and plug to and from the may be the front end USB has loosened off the motherboard....becaware that repeated failed connections are logged on the machine in a system folder which sometimes disables the port....clear all the temp file....use device management ...and look to see if the drive shows up without a designated letter...if it does reassign it with a drive letter andyou will be able to use front end USB port again.
Feb 05, 2018 | Computers & Internet
When I plug my HD in, the blue light comes on, but the motor isnt running.
Have you plugged in the AC power adapter? The blue light means it is connected to the computer but USB power is not enough to operate this drive.
Mar 25, 2014 | EDGE Tech Corp DiskGO 80 GB USB 2.0 Hard...
Coolmax HD-360B-U2 USB 2.0 External hard drive shows up on computer but I can't see anything that is saved on it. computer shows that there is data being used on device but when I open it, it says the...
Click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system
Feb 16, 2014 | Coolmax HD-360B-U2 USB 2.0 External Drive...
Edge diskgo
Perhaps if the HDD has not been damaged. HDD's can be very delicate , external HDD's can get bumped about at times, rendering them useless. Remove the HDD from the case, using a USB to IDE/SATA Adapter ,or, a computer shop, try to test/read the disk. It can be read, but I'm not sure you want to pay the price it may cost. It can be quite expensive, and requires specialized equipment.
May 10, 2013 | Computers & Internet
Doesn't turn on
Some external harddisk contain switch in front of it. try switchin on
Feb 22, 2013 | EDGE Tech Corp 500GB DISKGO BY EDGE ULTRA...
I have a DiskGo! edge external model number HD-D2-U2 and i can't get my windows seven pc to see it. i am also unable to get it to format it so i can see it any ideas?
1. Check for possible damaged USB cable.
2. defective USB electronics
3. new USB case needed
4. can be purchased online
5.Check for Possible damage USB PORT. Try another port.
Jul 11, 2011 | Peripheral Enhancements DiskGO! Hard Drive
Pc cant see my disk go edge 80gb
Hi and welcome to Fixyah,
The problem that you having was the enclosure of your Hardisk and the need to exchange it. I suggest to you if ever that is under warranty sentit back to your reseller or take the disc out and buy another enclosure for you to be able to get all your files.
Aug 11, 2010 | EDGE Tech Corp DiskGO 80 GB USB 2.0 Hard...
Edge DiskGo HD-D2-U2 External Hardrive not recognized by Vista
I having samsung E-250. I want to load dictionary in my mobile .How can I do that
Apr 08, 2009 | Peripheral Enhancements DiskGO! Hard Drive
How to download
Just click on My Computer,select external drive and then select the file you want to send to your PC and right click on the File then left clisk on Send To, where you want to coose it to go onto your PC. I have an External HD and have done this 100s of times.
Mar 13, 2009 | Computers & Internet
Computers & Internet Logo
27 people viewed this question
Top Edge Computers & Internet Experts
Steven Conroy
Steven Conroy
Lee Durbin
Lee Durbin
Are you an Edge Computer and Internet Expert? Answer questions, earn points and help others
