You Tube keeps stopping. - Washing Machines
    Top Expert:
  • Washing Mach... Master
  • 8,304 Answers
What is a you tube??.can you please put more info back on fixya.
Posted on Dec 09, 2016
The water level selector of my whirlpool white magic-splash washing machine is causing problem..it does not stop the water at the desired level..the water keeps on flowing into the tub and then overflows...
PRESSURE SWITCH
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to "make the switch" stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Water inlet valve
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Mar 09, 2011 | Whirlpool Washing Machines
FREQUENT START AND STOP DURING THE PLAY OF VIDEO
usually this happen when you have slow broadband connection and video is need more speed then your broadband connection speed if you have 512kbps internet speed you do not have to wait this long to watch video on you tube. check your internet connection speed for you tube video.
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
Mar 24, 2010 | YouTube Videos
The washer keeps on filling up until is begins leaking, it will not shut off when it has reached the load level by itself
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Jan 08, 2010 | Washing Machines
Top load washer won't stop filling with water
or
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tube. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Nov 08, 2009 | Amana NTW5100TQ Top Load Washer
Toto flapper seems ok but toilet keeps slow trickle into the bowl
The water inlet valve should close completely and stop water from coming into the tank before the water level reaches the "small tube." (This is the overflow tube.)
There may be an o-ring or rubber gasket inside the valve that can be replaced. If not, you would have to replace the water inlet valve.
Oct 16, 2009 | Home
Water keeps filling up washer
u have a bad water valve. thats the plastic piece behind the washer that the hoses hook upto. part roughly 39.99-89.99 labor 75-125.00 depending on were u live and who u use. if you decide to do it yourself i would say a 5 on a scale of 1-10 . turn water supply off, remove both hose.turn off power remove top panel 2screws in back and push panel back and off. remo 2 screws that hold water valve in place. remove wires from pld valve too new one. reassemble . hope this helps.
Oct 07, 2009 | Kenmore Elite 45986 Front Load Washer
Washer fills with cold water but does not stop filling
OR
Sep 15, 2009 | Maytag LSE7806A Top Load Stacked...
Water keeps filling and doesnt go to next cycle
Sep 03, 2009 | Washing Machines
When you turn it on keeps filling water and it over flows , second problem some times when it runs it keeps running to all the cycles never stops tell you manually stop it
Find the tube from the tub to the water level switch. Remove the tube from the switch and blow the sand and stuff out the line. Pump out any water in the washer and restart. 6b0c2cb.jpg
May 16, 2009 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
