Question about Car Audio & Video
AVH 2600BT Keeps going into auto connection failed.
My pioneer avh-x3500bhs keeps resetting itself
Mine does the same thing, its not a wiring issue as I put a different Pioneer Head Unit in its place and the problem went away. I put it back and the problem returned
Jan 16, 2014 | Pioneer AVH-P4000DVD Monitor
AVH-p4450bt can't connect to bluetooth saying Error-10 help!!! :(
my avh p 4450 radio shows error10 don't want to pair up how do I reset radio I did plug it out already and theres no reset button on radio thanx
Feb 02, 2013 | Pioneer Avh-p4450bt 7" Bluetooth Gps...
How to bypass pioneer avh-p5700dvd
The recent pioneer DVD devices structures setup is achievable by inspecting the vehicles default wiring kits to determine the most compatible medium. The prior wires in the vehicle stereo appear mutated with attempt to extract and replace with new DVD stereo. Inspect the mutilated wires to determine the kit harness that allows connecting the new device on one end while binding to the electrical cables extended surfaces. The new stereo player makes possible connection of a multipurpose harness that solves the problems that may be thought to require bypass. Once the appropriate connection kit harnesses are acquire, the wiring should provide connectivity to speakers, tweeters, woofers and several devices as amplifiers also necessary predicted during installation else missing audio may be detected after. Refer to auto installations experts to acquire the complementary parts to attain the installations.
Feb 05, 2011 | Pioneer AVH-P5700DVD Car DVD Player
Pioneer AVH P6500DVD Tuner Failed
sounds like the antena plug on the back of the unit came out pull out an check
Jul 15, 2010 | Pioneer AVH-P6500DVD Car DVD Player
I need a pioneer avh-5700dvd diagram for the wiring harness.i need to know where the wires go in to the blue plug
the blue wire is for hands free mobile connection, you do not need to wire this up unless you want hands free
Jan 29, 2010 | Pioneer AVH-P5700DVD Car DVD Player
I have no wiring diagram to wire it in my car
easiest way I know of solving this is get a wiring harness for the make and model of vehicle from the auto store. (walmart also sells the harness located by the automotive radios ) connect the radio harness to the wiring harness per the instructions and you should be good to go.
Jan 10, 2010 | Pioneer AVH-P6500DVD Car DVD Player
Bypass ebrake with relay on a pioneer avh-p5700
Go to any auto parts store and purchase a four wire relay and wire it up as follows: The relay will have numbers written on the bottom for each pin. The wire from the parking brake from the H/U to 87. Ground to 85 and 30. Remote from the H/U to 86. This will give you an automatic bypass to the DVD lockout. If you want to just put a switch to do this manually you can also. Go to Radio Shack and buy a momentary push button switch, part number 275-1548. Take the green wire coming out of the unit. Strip the wire, and attach it to one of of the pins on the relay switch. It doesn't matter which one. Buy a standard 16 gauge wire from Radio Shack and connect it to the other pin on the switch, then connect the other end of it to a grounded connection on your vehicle. Now, when you play a DVD, the warning screen will come on. Just press the button on the switch and it will go away, since it tricks the receiver into thinking you have engaged the parking brake. Like someone said before, it is illegal in just about all states to have a dvd or other video playing if the driver can see it and the car is moving. This method is used because the lockout not only keeps you from seeing videos but also locks out some features which many feel have nothing to do with safety and they need it.
Mar 24, 2009 | Pioneer AVH-P4900 Car Video Player
Car Audio & Video Logo
56 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
