Question about Ovens
My top oven not turning on no power light no grill no nothing. Bottom oven works fine no probs..
Gorenje bd 2116 ax is the oven make double built in..
Amigaman
  • 248 Answers
SOURCE: Kenmore 47779 double oven; lower oven doesn't work after self clean
Sounds like a thermal overload has opened up during clean. It may be mounted on the back.
Posted on Nov 04, 2007
SOURCE: bottom oven of dacor double oven
I found the lower circuit breaker had been tripped. That didn't fix the problem but upon further inspection whoever had worked on the unit years ago had dropped a screwdriver that had lodged between the oven wall and the rear casing and shorted out the lower heating element. I removed the screwdriver and oven works fine now. I don't think that will solve the cmmclow problem but maybee the curcuit breaker is tripped.
Posted on Mar 12, 2008
  • 1214 Answers
SOURCE: bottom oven not working
A tripped breaker or blown fuse on an electric oven or cook-top, combined with an element that has stopped working, is usually a sign of a shorted, then blown (if the fuse or breaker no longer fail) element.
If you know how to use an ohmeter, you can pull the element, disconnect the wires from each end, then measure the resistance between each end of the element, and each element to the outer sheath.
A good element has just a few ohms of resistance between the wire connection points, and infinite resistance from the wire connection points to the outer sheath. Any readings other than that means the element is bad and need's to be replaced.
Posted on Jan 14, 2009
SOURCE: Hotpoint BU62 double oven, no grill functioning
keep turning the oven/grill selector past the temperature settings, it feels like it won't go any further but it does!
Posted on Feb 07, 2010
apart4u
  • 213 Answers
SOURCE: Zanussi ZDQ 595 fan oven not heating
Here is a free video to help you with your cooker fan motor problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feedback please
For all your parts visit our site http://www.apart4u.co.uk
Posted on May 27, 2010
Hi I have a 720GRa rotostar double oven and grill when I turn the top oven/grill knob it turns but nothing works eg lights on the front the fan or the ignition but the oven works fine it worked this...
I suggest that if you have more than one knob of the same type, these knobs are usually removable by pulling straight out. Pull the knobs out and compare the inside. I would not be surprised if a metal insert is missing or the inside is stripped. Hope this suggestion is helpful.
Nov 20, 2014 | Ovens
Replaced EOU43002X element, clock/timer now dead
Make sure there is power to the timer. Should be a fuse somewhere.
Mar 19, 2014 | Electrolux Ovens
Both lights on the top oven work when using it as an oven but when using it as a grill, they don't! There doesn't appear to be any other fault as the oven and grill still work fine. Any thoughts...
The unit is working as it should. The top oven lights will only come on when the top oven control knob is turned on. The grill control does NOT turn the lights on. If you want to see what you are grilling, then you should turn the top oven control on to its first position. This works even if the grill is operating.
May 10, 2011 | Stoves 720EF Electric Double Oven
Hi Guys I have a Stoves 720EF Double Oven and Grill. Whilst halfway through cooking some sausages on the grill this evening, the grill suddenly stopped working (plus the LED for the grill knob showing...
If the element and the indicator light both stopped working this suggests a problem with the power supply for the grill control. Either the grill control has no power going to it or it is faulty and requires replacement. If you are not sure what you are doing you'd better get a tech. to look at it, it can be fairly complicated for the untrained person.
Feb 24, 2011 | Stoves 720EF Electric Double Oven
Stoves 720 EF Electric Double Oven Model No 059040415 -when you turn the grill knob there is no light and it doesn't do anything at all - the grill is not working. However, the element must be working as...
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
So if you have done all that and it still doesn't work, then the micro-switch could be faulty.
Best of luck
Nov 23, 2010 | Stoves 720EF Electric Double Oven
How do i work the grill?
Nov 21, 2010 | Stoves 720EF Electric Double Oven
F1 display and beeping
F1 Power to element relay energized during time of day display.
1. Wiring harness shorted.
2. Or change power relay board (PRB).
Note: for double ovens, change second oven board.
Jul 27, 2009 | Jenn-Air JJW8230D Electric Double Oven
Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Nov 12, 2008 | AEG D2100-4 Electric Double Oven
Hotpoint double oven
Top oven works bottom oven fan works but bottom oven does not work and cannot get rid of auto signal
Jul 22, 2008 | Hotpoint UY46 Style Line Stainless Steel...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
