Question about Juki Sewing Machines
How do I remove the main case of a juki machine? I have thread wound around the knob & it won't move.
  • Shirley Neibarger Jan 03, 2017
    Hi Ron Hesketh, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • Ron Hesketh
    Ron Hesketh Jan 03, 2017
    It is no longer necessary. The machine is fixed. I should have posted it before. Thanks for responding.
5 Suggested Answers
RickE1
  • 202 Answers
SOURCE: Thread wound around disc of take-up lever on bernina 1008
Hi, there is no top cover on this machine. First the side cover has to come off then the back cover. Under the back cover there is a rigidity plate with many screws that has to come off and then you might be able to get at the take up lever mechanism. I'm not saying you can't do this but it might just be the time to have a tech go in and service this machine completely.
The thread must have slipped out of the end of the takeup lever and wound in the mechanism. It happens.
If you feel you want to do this yourself feel free to contact me and I can walk you through getting the covers off.
Possibly you can get a tweezers or needlenose pliers in through the front slot, grasp the thread and turn the handwheel bit by bit and see if it will unwind as you pull it out.
callnrick@yahoo.com
Posted on Feb 28, 2009
Mongo32
  • 111 Answers
SOURCE: Sewing machine will not pick up bobbin thread.
needle's in backwards
Posted on Jun 11, 2009
  • 1116 Answers
SOURCE: Thread wound around the knob to the right of the
Take it to the dealer. If you try this yourself you could cause more damage.
Posted on Feb 19, 2010
  • 1564 Answers
SOURCE: thread caught behind the bobbin case holder
Take off the presser foot
take off the needle plate
take off the bobbin plate
take out the needle,
clip bobbin free,
Examine the bobbin carrier on how it fits into place. (important)
Lift out the bobbin carrier.
Each machine is a little different. You may want to take pictures as you do each step for later reference. Use something like an old egg carton or a muffin tin to keep your parts from rolling around or getting knocked off an lost.
Have fun.
Posted on Nov 06, 2012
My Janome Memory Craft 3600 is locking up and it seems like the main shaft is freezing. Can it be fixed to stop locking up?
check around the bobbin carrier area for fluff and tangled bits of thread
they get tight as they are wound around the shaft and jam between the moving bits acting like a brake
remove all threads and clean and lubricate the area
Jan 04, 2017 | Janome Sewing Machines
Juki dnu-1541 S hard to turn
indicates needle thread tension not tight enough
the jamming may be from thread and fluff wound tight around the bobbin shaft an locking it up
remove any threads and other material from the bobbin shaft and bushes
take it in for a service
Nov 19, 2016 | Juki Sewing Machines
I just brought home a Juki 8700. The needle went down and now I can't get it basck up. There is thread stuck in the bobbin. How do I get the bobbin casing off
Cut the thread above the needle eye and rock the handwheel back and forth sharply to cut the thread with the sewing hook. If that doesn't work pretty promptly, undo the needle clamp and turn the handwheel, which should raise the needle bar. Then get into the bobbin case area and try to remove the bobbin case, cutting any threads you can. Keep rocking the handwheel and trying to pull out the needle (pliers help!), and eventually everything will loosen up.
Next, clean and lubricate the area under the needle plate and the shuttle, and reassemble. Put in a brand new needle, right way around and fully up in the machine. Load the bobbin case with a well-wound bobbin, and rethread the top of the machine and you should be good to go.
Jan 28, 2014 | Juki DDL-8700
After winding a bobbin on my Juki TS2010Q and releasing the winding lever, my machine will not run, Up/Down needle or cut. The electronic buzz indicates that it is trying but nothing happens.
Have you tried pulling gently on the thread coming up from the bobbin? If this doesn't give, the thread may be tangled around the mechanism (under the machine, where the bobbin fits). Open that section and you should see if there is excess thread wound around. Clear this, and when you put the machine back in place, gently hold the bobbin thread to assist in not having loose thread to tangle again. This sounds like my machine sounds when that happens to mine so I hope this fixes it.
Jan 20, 2014 | Juki Sewing Machines
How do i use jean thread on my juki industrial sewing machine
are you using a denim needle for sewing jeans?
where is the thread getting caught up at?
make sure the bobbin is turned the right direction in the bobbin case
Feb 13, 2013 | Juki Sewing Machines
Juki, DNU-1541S: thread was not picking up the bobbin thread. The hook shaft is not moving... After trying to move the needle in a reverse motion... Now the hand wheel will not move it is frozen in place.
You've got something binding in the bobbin area. Open up the entire bobbin/feed dog area plates so you can really see. Get your magnifying glass out and really examine the area for threads wound around things. DO NOT unscrew anything if you can help it. If you unscrew the wrong thing you can knock it completely out of time. (which may be why couldn't get the bobbin thread up anyway.)
If all this is intimidating to you... take it for repair.
Sep 09, 2012 | Juki DNU-1541 Mechanical Sewing Machine
I have a juki tl98q sewing machine for my mid arm. The bottom thread keeps bunching up and I cannot sew anymore. What can I do to fix this? Do you have a diagram to thread the bottom bobbin and the top of...
The threading diagrams are available in the manual which is available from Juki on the TL-98Q product page: http://www.juki.co.jp/household_en/pism/tl98q.html . The direct link to the manual is http://www.juki.co.jp/household_en/pism/img/tl98q/download/98qim.pdf . See pages 14-18 (pages 16-21 of the PDF).
There are a couple of things I recommend that you check. First, make sure that the bobbin is evenly wound. This is a function of the bobbin winder tension; see the manual (page 15) for that adjustment. Next, check if the bobbin case tension is correct. Place the bobbin in the bobbin case and dangle the unit from the thread. Try to shake the bobbin case up and down, sort of like a yo-yo. The thread should advance by a bit. If the thread length doesn't change, loosen the set screw on the side of the bobbin case a small amount. If you get a really long tail of thread, tighten the set screw. See page 21 of the manual.
Next check for any loose threads and dirt in the housing around the bobbin case. Depending on the length of time that you have been using the needle, replace the needle.
I hope this helps.
Sep 28, 2017 | Juki TL-98Q
My machine is starting to work much louder than usual. The oil is fine and I checked everything that I could but its just really loud. How do I fix it.
hi there
1 - remove the belt and turn handwheel by hand is it easy move or no? if no means machine jamed and check one by one
- loose screw for needl bar and move handwheel by hand if still jamed.
- remove the finger guide for bobin case maybe some thread insaid hook and move by hand if relase means thread insaid remov it and re assembly again. if not
- there is jamed in upper main shaft at accentric or bushing ( deffecult problem ) need experiance mechanic.
with my best regards
ashraf abozid
aabozid@hotmail.com
Nov 28, 2010 | Juki DDL-8700
How do i fix the tension? i've been playing with the knobs for hours, but the threads are still too loose on the fabric.
Try decreasing your stitch width and this should help. Put your tension dials on 4. Also make sure when you thread your machine your presser foot lever is up to allow you to get your threads through your tension discs properly. To test the tension (usually set at 4 on all 4 knobs) when you thread around the knobs pull the thread on both ends like you're using dental floss around the discs under the knobs so you can feel the pull (tension) on the thread. Let me know if this works for you.
Aug 22, 2010 | Juki MO-654DE Mechanical Sewing Machine
Sewing Machines Logo
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
