Question about Food Processors
I need the bowl for the D5FP1food processor. The motor is good. Is it still available
In need of Bowl and blade
GENERAL ELECTRIC FOOD PROCESSOR MODEL 106622F WORK BOWL
I was able to locate a bowl for the 106622F processor on E -Bay. You may be able to find a blade on E-Bay. From what I gather, there is no source for replacement parts, other than used parts. I hope this helps ! Good Luck....
Mar 31, 2014 | GE 106622F Food Processor
Need bowl of Braun food processor 4262
http://abtecparts.com/braunfoodproc.htm
I need a lid for mine here in Bristol RI but I did see that the bowl was still available. If the site I sent doesnt have the one you need try a google search (Braun 4262 ) and there were a few sites that had the mix bowl but no lid
May 30, 2009 | Braun UK-250 Food Processor
Need a bowl for breville food processor super wizz FP-2A. Do you know where I can purchase one in Australia
Sadly the FP2A no longer has ANY new spare parts available in Australia.
The only option you have is to keep an eye out at thrift stores e.g. Vinnies, Salvos, or check out Garage Sales, as people may still have the bowls etc but have done away with the machine.
It's a shame, it's a good model!
Apr 03, 2009 | Food Processors
Motor works but will not turn on
You can test the motor by plugging the food processor in, pressing the on switch and using a pen to press the dark grey or black button on top of the base of the food processor. As long as it spins, the motor is definitely good. Next, unplug the food processor. For the food processor to work, you need to have the work bowl, lid, and pusher sleeve all inserted - if one part of the work bowl is not attached, then the food processor will not spin the blade. Once all three pieces have been inserted, plug it in and turn it on. If the blade is still not spinning, then there is a problem with the element that runs from the back of the pusher sleeve down through the work bowl that triggers the motor button. In that event, you can go to Cuisinart's website and order a new bowl, lid, and/or pusher sleeve - if you see any obvious damage to one part, you can order just that one part. If it is not apparent which part is damaged, order the whole work bowl. The work bowl parts are expensive, so I would just write down the part numbers from Cuisinart's website and find them cheaper elsewhere. There is also a video on the website that shows you how to use the food processors - the first part of the video describes work bowl asssembly. Once you get this food processor working, it is going to last forever. Have fun!
-Tha Mp3 Doctor
Jan 01, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Motor won't turn on
You can test the motor by plugging the food processor in, pressing the on switch and using a pen to press the dark grey or black button on top of the base of the food processor. As long as it spins, the motor is definitely good. Next, unplug the food processor. For the food processor to work, you need to have the work bowl, lid, and pusher sleeve all inserted - if one part of the work bowl is not attached, then the food processor will not spin the blade. Once all three pieces have been inserted, plug it in and turn it on. If the blade is still not spinning, then there is a problem with the element that runs from the back of the pusher sleeve down through the work bowl that triggers the motor button. In that event, you can go to Cuisinart's website and order a new bowl, lid, and/or pusher sleeve - if you see any obvious damage to one part, you can order just that one part. If it is not apparent which part is damaged, order the whole work bowl. Make sure you enter your exact model# at Cuisinart's website, because a DLC-7 is not the same as a DLC-7E or 7P, for instance. The work bowl parts are expensive, so I would just write down the part numbers from Cuisinart's website and find them cheaper elsewhere. There is also a video on the website that shows you how to use the food processors - the first part of the video describes work bowl assembly. Once you get this food processor working, it is going to last forever. Have fun!
-Tha Mp3 Doctor
Nov 27, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
My food processor turn on button won't work.
Cuisinart Food Processors – Motor Test
First, do a motor test by removing the work bowl completely and using a pen to press in the grey button on top of the base (with the food processor turned on of course), toward the back. If the processor spins, the motor is still good. At that point, I would inspect the work bowl pieces, lid, pusher assembly, etc for cracks/damage. If all appears well, insert ALL the pieces back into place and try again. If even one piece is out of place, the processor will not spin.
If it no longer spins, the motor has a problem.
-Tha Mp3 Doctor
Nov 25, 2008 | Cuisinart DLC-5 Food Processor
My brand new Cuisinart 14 cup food processor won't turn on. All the components are locked in place and it's plugged in. Help
-Tha Mp3 Doctor
Nov 23, 2008 | Cuisinart DLC-5 Food Processor
I can't get my food processor (DLC-2007N) to start. It looks like everything is locked in place, and the light goes on, but the motor won't start.
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve.
Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good.
Put the work bowl on first, with the handle facing the front of the food processor.
Put the lid on, with the lid lined up with the handle of the work bowl.
Put the pusher sleeve in the lid, with the metal piece facing the front of the processor.
Your processor should now turn on.
If it doesn't call Cuisinart and see if you are still in-warranty (3-year warranty).
-Tha Mp3 Doctor (also loves Cuisinart)
Aug 31, 2008 | Cuisinart DLC-2007 7 Cups Food Processor
The cuisinart food processor doesn't work.
-Tha Mp3 Doctor
Aug 26, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
Appears to be locked but won't turn on
Instructions only apply to Cuisinart DLC-2011 series:
Remove the work bowl and all other parts completely from base.
Plug the base in, and turn it on.
Use a pen to press in the dark grey or black button on top of the base.
If you hear a spinning or other noise, the motor is still good.
Now that you have verified that the motor is good:
Put each work bowl piece on one at a time - if you don't out it on one at a time, it will not lock in properly.
Put work bowl on with work bowl handle facing front, make sure bowl locks.
Put lid on with lid lined up with work bowl handle.
Put pusher sleeve into lid's feed tube, with metal element facing the front of the food processor.
You should now be good to go.
-Tha Mp3 Doctor
Apr 16, 2008 | Cuisinart DLC-2011 PowerPrep Plus Food...
Food Processors Logo
60 people viewed this question
Top Food Processors Experts
eyecam
Are you a Food Processor Expert? Answer questions, earn points and help others
