Question about Alpine Car Audio & Video
Alpine cda-9887 can i run the internal amp for my front and rear speakers and a external amp for my subs?
4 Suggested Answers
  • 10 Answers
SOURCE: no sound to the in car speakers from my alpine cda-9827 cd player
What kind of car did you install this in? Did it have a factory radio in it? If I had to take a guess I would think that there is a factory amp that you may have hooked the blue wire from the alpine deck to. If this is the case when you switch to CD the alpine deck turns off the power to the power antenna lead(blue wire) and thus your factory amp. If this is the case hook the factory amp turn on to the blue and white wire and you should be good to go.
Posted on Sep 03, 2007
SOURCE: alpine cda-9887
buy this
http://www.partstore.com/Part/Alpine+Electronics+Inc/Alpine/3608479Z01/New.aspx?ModelMfgName=Alpine+Electronics+Inc&ModelBrandName=Alpine&ModelNumber=CDA9887
problem fixed
Posted on Nov 20, 2008
  • 1833 Answers
SOURCE: Alpine CDA-9815 Can I use the
There is mode called "PWR-IC OFF". If you set this mode in the CD player then the internal amplifier will shut off. But internal pre-amplifier will remain on. Then you can connect the same speaker outputs to an external amplifier.
But it may not be possible to shut off internal amplifier for the front only. Either you can shut off for all OR for none. There is no way to shut off half because there is only one power IC for all the outputs.
Posted on Feb 24, 2011
I have a cda. 9887. It powers on but gets no sound from any of the speaker wires. What could be wrong. What can I try.
Most Alpine CDA units come with an option to turn on/off the internal amplifier in order to give you better sound when connecting an external amplifier. Try turning on IC
Aug 15, 2011 | Alpine CDA-9887 CD Player
Alpine 9887 no incoming power supply. Incoming vcc checked ok at conector level, 10 amp fuse block not blown
did you check power at both the red and yellow wires? also, make sure you have a good ground.
Sep 10, 2010 | Alpine CDA-9887 CD Player
Speakers dont work with CD, but work with radio.
I just had this problem with my e34 bimmer, just connect the blue wire to with the red wire (apparently the 9887 shuts off the antenna when the radio is off). so in my case, bmw thought it was a good idea to wire the two together, which means you go to CD and the Deck shuts off the amp, killing the speakers.
Nov 15, 2009 | Alpine CDA-9887 CD Player
Alpine cda-9811 is not accepting amp as external amplifier?
The signal should go from the head unit to the amp to the subs. Someone must not have wired the subs correctly through the amp, or amp to the cd player..
Jul 08, 2008 | Alpine CDA-9811 CD Player
Hooking up a subwoofer
If your head unit has speaker outputs, and RCA outputs, it should be able to use them at the same time. Turing off th internal amp is just to save power and heat if you aren't using it.
May 23, 2008 | Alpine CDA-9883 CD Player
How to wire a stereo system
Connect the 2 gage to the battery thru at least s 50 amp fuse, then connect the capacitor in line before the amps. Then run the 2 gage to a connector/splitter block and run 4 gage leads to each amp. You also will need at least 4 gage ground leads from each amp to a body grounded bolt or screw. You need to run a quality set of speaker leads from the head unit to the amps. The speakers will need separate leads from the amp to each speaker.You will need to try some different combinations to get the sound and bass you want. You want to be able to fade from front to rear and control everything thru the head unit.
Use a hole saw to cut a 2 to 3 inch diameter hole in the side of the speaker box for a port to get a better punch from the sub.
Hope this helps some....
Nov 03, 2007 | Alpine CDA-7863 CD Player
No sound to the in car speakers from my alpine cda-9827 cd player
Sep 02, 2007 | Alpine CDA-9827 CD Player
Car Audio & Video Logo
41 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
