Question about Zenith Televison & Video
I have a Zenith Z50PT320 plasma tv. After a few minutes the picture turns very posterized and flickers. Should I replace the Main Logic CNTRL T-Con board?
When I turn on the picture is fine. After a few minutes the picture appears posterized (loses its color range) and begins to flicker.
  • yadayada
    yadayada Dec 09, 2016
    post·er·ize
    verb
    Past tense: posterized; past participle: posterized
    Print or display (a photograph or other image) using only a small number of different tones.
  • David Stonionis
    David Stonionis Dec 10, 2016
    exactly
    Top Expert:
  • Zenith Master
  • 75,462 Answers
There is no T'Con board to Plasma TVs. Flickering can be of many reasons. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Posted on Dec 10, 2016
premtech
  • 934 Answers
SOURCE: Red noise or flicker on bottom half a plasma screen
The old saying that a pictures is worth a thousand words could have been looking at this one... If the lower screen had been streaked in B&W or bands ran completely through the picture Old Drummer I would suspect the logic board also but that's lower y-board failure.
Bill
Posted on Nov 15, 2007
  • 50 Answers
SOURCE: Black screen on Zenith plasma tv's
Hello, My name is Dave and I can help you fix your Plasma TV. Give me a call. Feel free to give me a call @ 1-503-432-9904 or message me at pleasefixitdave@yahoo.com
Thank you!
Dave,
Posted on Jan 29, 2009
rylee_smith
  • 8619 Answers
SOURCE: model #50PC1DRA no picture but
Hi
Thanks for using FixYa. As you have already replaced the Z-sus and the main logic board then the issue seems to be with the Y-main and/or Y-sus board. You’ll need to take the back off and check for any blown/bulged capacitors that might have gone bad and causing this issue. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 02, 2010
SOURCE: My VP504fhdtv10a vizio plasma TV when connect
Logic Control D Board got nothing to do with this problem. This is your main power supply gone bad(usually not the sub power supply). I just repaired my VIZIO by replacing main power supply. Just remove back cover and your board will be right in the middle of the screen. Just get board part/serial # and google it. My best price was through eBay(around $100). Everything is fine now.
Posted on Feb 07, 2011
eagle338
  • 4889 Answers
SOURCE: Maxent MX42X3 42" plasma Monitor..
Are you sure that its the main A/Vboard coz it sounds like the main power supply issue to me. Anyways the mainboard is the large board usually located at the center of the tv. If you can remove the back cover of the tv and get me a high res picture of the tv I can mark the board for you.
Posted on Jun 03, 2011
Zenith 50" plasma TV model Z50PT320 has no picture no sound just flicker screen with lot s of fuzzz
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary
Feb 12, 2017 | Zenith Televison & Video
Hi!
as i see your picture maybe that is lack of vertical sync or vertical ramp... can you send me the service manual then i diagnose this problem. send me at gmf_likha@yahoo.com
Nov 08, 2007 | Televison & Video
Samsung has standby light, it blinks tone sounds no green light. Replaced t-con, power supply and control boards.
Hi Patrick,
have a close look at your LVDS cable and screen ribbons for signs of failure or heat damage, and you could try to pull a picture from an AV output in various formats to see if it's the screen itself is failing in some way,
regards
George
Jun 29, 2016 | Samsung UN60D6000 60 Inch 1080p Smart TV...
What does is mean when black flickering lines from top to bottom of screen appear when i first turn my samsung 50' model un50f5500 HD plasma tv on but goes away after a few minutes
It sounds like either your main board or logic board is going out.
You might want to check the capacitors on your power supply also. If they are swollen they will need to be replaced. Swollen caps can cause video distortion until they build up a good charge. Good luck to you.
Apr 12, 2016 | Samsung Televison & Video
What board do I need to change on zenith plasma tv / z50pt320-uc it has odd bright colors and ghost image
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 24, 2014 | Zenith Televison & Video
Has zenith tv have focus control
Flat panel TVs have no focus control, as in the CRT TVs. Electro help
Sep 06, 2014 | Zenith " 50"" Class - Plasma - 720p -...
Lg 47lv355u tv
Ok t-con board is connected to main board which is giving signal and logic supply.. If the main board failed or giving a over voltage to the t-con it possibly your T-con gone out (new) again.
To isolate the problem try to replace the main board.
Dec 05, 2012 | Televison & Video
I have no sound from Xbox HDMI connection.
you likely connected it with one or both units involved on and HDMI does not like that--prone to all sorts of audio issues.
If in doubt unplug the units and wait and plug back up making the connections first.
Jun 07, 2012 | Zenith " 50"" Class - Plasma - 720p -...
Half of my screen will turn in to vertical colored stripes
T-con board. Check lvds cable for tight connection.
Sep 15, 2009 | LG 42LC2D 42 in. LCD HDTV
Colored wavy lines on screen
This is a Logic board problem, not so easy to replace in Hitachi but well worth the repair if I had your zip code I could recommend a person or three. But the problem is a problem in the logic board and will beed replacement, Thanks for using Fixya.com
May 14, 2009 | Hitachi P42H401 42 in. Plasma HDTV
Televison & Video Logo
75 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
