Question about Vacuums
My seal a meal won't seal the bags. I have tried using premade bags and hand cut bags. It sucks the air out but will not heat up to seal.
  • 16,210 Answers
There is either a blown fuse in the heater circuit or a bad heater filament, you can take it apart to see but there is no diagram or parts list on something like this, replace it.
Posted on Dec 09, 2016
The cleaner sucks very poorly. The motor sounds fine, it blows well and there is no obstruction.
If it blows, then it should suck equally unless there is leakage on the intake (suck) side meaning something inside disconnected or cracked, letting air in from other directions. I do not know the vacuum you speak of; upright (which has a short hose often clogged by itself) or canister which might also have a leaky seal at the bag door.
Sep 26, 2015 | Vacuums
Foodsaver V3460 vacuum runs and sounds like it has reached the end of the cycle then seals bag.
then you do not have the bag in proper place in the sealer , mine has never failed .
Aug 05, 2015 | FoodSaver V3460 Vertical Vacuum Sealer,...
Hoover not sucking
Remove all filters and try the suction on your hand, NOT THE FLOOR!
Filters are vital to keeping the motor working.
Most vacuum sucking probs are a result of a clogged filter or filters. Sometimes, hoses also. Or a full bag.
Remove all filters, clean them thoroughly, check hose for obstruction.
Use another vacuum to remove dust/dirt (or an air compressor) from the dirty filters.
That's first step.
Feb 26, 2015 | Hoover Vacuums
I purchased a Seal-A-Meal roll to make my own bags but can't figure out how to use it. I have a model VS108. Is it possible to seal without vacuuming?
On most models of vacuum sealing systems, you cut off the roll the size of bag you need. Slip one open end of the bag just on top of the heating element over it about 1/8-1/4" and press down the lid to seal the bottom of the bag. Fill the bag and then place the open end far enough into the vacuum cavity over the heating element and close the lid and press down and hold until the cycle finishes. If you don't want a vacuum, just put enough bag material to cover the heating element but not into the vacuum cavity. Hope this helps
Jan 03, 2011 | Vacuums
It just keeps saying that my bag is full and cutting out, bag not full and have tried changing it anyway, but still cutting out
I would check the air filter. It sounds like it's over heating and shutting off because it doesn't have good airflow.
Jim
Oct 05, 2010 | Sebo X4 Bagged Upright Vacuum
No vacumm pressure. the passages are clear and the motor runs but there is very little suction.
if you are certain no blockages ? and the dust collector is clear/clean ? have you checked that the outlet filter which is located inside dust compartment is clean/clear this is usually a gauze filter its purpose is - as vac works and draws dust into collector the air that is sucked up thro vac builds up in collector chamber or bag on most vacs? and so for vac to maintain suction the air has to be able to escape to atmosphere/room without dust which is left insude chamber/bag if fitted and so air escapes via the gauze vent as prev mentioned ? however if gauze filter is not clear to vent then vacuuum is restricted due to air drawn being unable to expel sometimes on vacs they will eventually cut off due to o/heat but will operate when cooled so may i suggest checking the above possibility ?
Dec 13, 2009 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
My Oreck XL is very dirty inside on fan and the motor runs very loud. It is not clogged.
These units are called dirty air units because the dirt literraly runs thru the fan attached to the motor and is blown into the bag. Most newer vacuums are called clean air because the filter bag is in the path, and the dirt is sucked into the bag, never reaches the fan or motor.
I'd say if it is that dirty, may be a fire hazard, and you may have worn out the seals on the part down at base that pivots to a point that replacement is necessary.
(I'd blow out the dust and keep using if it was me, and then check again in a few weeks, before I replaced. But I like living dangerous.)
Jun 22, 2009 | Oreck XL21 Bagged Upright Vacuum
Seal-a-meal won't seal
Take apart and see if wires are connected That is what was wrong w/ mine. Soldered wire now works fine.
Mar 30, 2008 | Vacuums
Dirt devil mvp not sucking
Could be bad filters, is there suction at the end of the hose. That will tell you which direction to start looking. If no suction at hose end, then filters could be the problem. If you have suction, then the problem is down lower, dirt inlet is clogged, if belt has never been changed, then I am sure it has stretch to the point that under load it doesn't turn like it should. Could even be that although the motor is running, it may be running at a slower speed, in which case it would have to be replaced.
Oct 14, 2007 | Dirt Devil 12 Amp HEPA Filter Vacuum...
My dirt devil vacuum won't suck up anything and its brand new!!
Take the vac bag off and turn on the vac , it should blow air out, if not unclogg the hose where the bag connects, also when you check the roller and belt, unclog the flex hose(located inside base near roller assembly) that sucks up the dirt. As long as the motor works fine the rest is just maint.
Mar 30, 2007 | Dirt Devil M085805 Upright Vacuum
Vacuums Logo
50 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
