Soundslike drain pump running continuously and unable to program my ESL43020
4 Suggested Answers
  • 4 Answers
SOURCE: drain pump continuously runs when
Our AEG did this (but it did display an errorcode). It simply meant that there was a water on the bottom of the machine. I found this out by tilting the machine so the water leaked out and than the machine ran normally for the next two washes. Then the same problem occured so there had to be a leak somewhere. I opened the machine up and found one of the hoses was blocked causing an overflow.
Hopes this helps you to pinpoint the problem.
Posted on Apr 25, 2008
  • 725 Answers
SOURCE: Bosch SHX46A02UC-21
float switch is in the flood position and the drain pump is running.. there is water under the dishwasher or that switch is stuck up..
Posted on Aug 21, 2008
  • 258 Answers
SOURCE: Electrolux ESL43020 fills with water then drains out and keeps draining
Faulty main board or sensor.
Posted on Nov 03, 2015
Neff dishwasher pump continues to run after cycle finished
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. Also after the program is completing to the final stage the drain vavle/pump must work and cut off If this does not happen then the voltage at the inlet valve/drain pump must be checked or the fault relates to the controller. This means the controller is a suspect.
Jul 26, 2011 | Neff Dishwashers
Washer won't drain or spin
your not going to like me? its the programer playing up,,,pricy part too?
see i was right,,,you hate me now!
Jun 08, 2010 | Frigidaire FTF2140E King-Size ENERGY STAR
Bosch SGS5332GB dishwasher. drain pump runs all the time
There is a float under the machine that tells the pump to shut off. If the float is stuck or bad, the machine will keep draining. I am including a web site that might help. Bosch Dishwasher That Will Not Stop Draining Hunker
Nov 06, 2017 | Bosch Dishwashers
What is causing the drain pump to continue running
C1 - Partially Blocked Drain - This error will occur when dishwasher was unable to pump out water in less than 95 seconds. Check drain line for debris and blockage. If clear, check for a restricted drain valve in the pump. Check the pressure sensor for correct operation as it sounds like it may be defective and thinks that the machine is still full of water after it has emptied.
Oct 30, 2009 | Dishwashers
Whirlpool duet washer will not spin. pump drains well. low humming noise.
"low humming noise??" soundslike the pump trying to pump, did you try removing the lower acess panel and physically cleanout the drain pump filter?? sondsas if its still trying to empty water
Mar 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F02 error on Kenmore front load, followed solution, problem still exist, What next?
cant see what you tried to repair problem (dont see original post) but F02 is a long drain time. or innaddaquate drain. usually from a clogged, drain pump/button trap. ill assume you were told to remove the lower access panel, gain acess to the drain pump assy, clean the "button trap" of foreign derbis. if thats been done and your still having draining issues iehter theres something i nthe drain hose, or perhaps the drain pump impeller has been damaged preventing proper flow of water.
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Drum not filling up with water, it's draining straight out.
That means that the drain pump is always on.
That can happen because of a faulty or stuck water level switch (the one with floating sensor), because of a faulty drain pump solenoid, or because of a faulty pump.
Oct 24, 2008 | Washing Machines
Bosch SHX46A02UC-21
Aug 19, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Frontload washer
you have a plugged drain pump.. remove the back .remove drain hoses remove drain pump and check for something in the pump... you may find coins or bra wires... hope it helps
Aug 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
