Question about Cell Phones
Can we roll over our minutes from old phone to a new phone?
I have an old AudioBox cellular phone in my Rolls Royce and I wanted to find out if I could hook up a cellular service to it and how to do it
Likely as not its the old system and not the digital one we use now. You could however get an enterprising person at your local car phone installer shop to make a new one look like an old one if you get my drift?
Jan 05, 2015 | Cars & Trucks
I have an old Sharp EL-1701C calculator and for some reason can not feed a new roll of paper into the unit? Batteries are new and the feed option works well, just doesn't grab the paper roll to start?
you may need to cut the corners off a little bit on the start of the new roll and feed the paper in while advancing with the calculator advance control/button
Dec 10, 2014 | Sharp EL-1701C Calculator
Why did I not get all my minutes transferred?
get back onto the company and ask them
not a problem that fixya site can advise on
Feb 27, 2018 | Cell Phones
My lg tracfone reads unregistered sim.It has always worked until I was not using it for about a wk.
Tracfone deletes SIM cards and the associated phone number from their registration database if the available airtime minutes goes to zero. Try buying minutes for the phone. (If you wait too long (~2 months), Tracfone may not be able to re-register the SIM card. In that case, you'll need a new SIM card.)
Do you remember when your minutes were due to expire? (Remember Tracfone doesn't do roll-overs of minutes.)
I hope this helps.
Mar 18, 2013 | LG 500g TracFone
Which ink cartrage fits Brother Fax 770?
PC301 is the complete replacement cartridge. Lift out the old, drop in the new.
PC302 is a box of two refill rolls to fit into the PC301. Lift out the old, lay it upside down on the table, flip a few small latches to open both sides of the cartridge. Look carefully at how the old rolls are placed in there. Lift them out and put in the new rolls the same way, except that, of course, the full roll will be on the opposite side. Snap it closed, drop it into the machine and close it up.
Save the second roll for later.
May 21, 2012 | Brother IntelliFAX 770 Plain Paper Thermal...
Porting your old number over to a new phone and carrier will have nothing to do with the phone shutting off every few minutes. The phone should turn on and stay on weather active on a network or not. Your phone may have a problem. Which Samsung phone did you get? One of the sliders or the new touch screen? Use the new phone, dial 611, this will connect you to straightalks support, tell them about the problem and let them talk you through the new phones setup. Hope this helps Fix Ya up.
Jul 31, 2011 | Samsung Cell Phones
Hello. Can I make the Extension Numbers stay with the phone jack instead of the phone? For example I got a new phone and moved the old one to another office and it still wants to keep the old extension...
Of course it's possible, however, you need to turn off Auto Set Relocation. I'm not sure if it's an Administrator or only an Installer function.
There is a trick....and I've never tried it because I HATE ASR, if you unplug the old phone, move it to the original location, and wait at least 5 minutes, then unplug it from the original location and plug in the NEW phone before you plug in the phone you just unplugged, the new phone will become the old extension and your original phone will be unprogrammed. It also says you have to wait at least one minute before you can change the DN of a new phone, but that requires INSTALLER access.
Like I said......
Jun 14, 2011 | NorStar Meridian M7310 Phone
How do I replace the brush roll on my oreck xl??
Turn the vacume upside down. Remove the 5 screws on the bottom plate. 3 are near the brush roll, and 2 are near the back. Remove the bottom plate. take the belt off the motor end. pull up on both ends of the brush roll. Put new brush roll on making sure that you put both ends to the new position, not old. ( it is marked on one end, and there are marks on the side that goes up so the can match.)(If putting back the old brush roll you can switch to the old position. After a year or two you can switch the new brush roll to the old position.) Put the bels back on the motor shaft and then stretch and start the belt on the brush roll and rotate the brushroll by hand untill the belt is all the way on.
put the bottom plate back on and tighten the 5 bottom screws.
Apr 21, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Dometic Caravan Fridge 7271
Your refrigerant may have completely separated in the system. Shut of the gas, disconnect the electrical and remove refrigerator from the coach or if you have sufficient room inside set it on a clean area. This operation is what is called burping the system.
1. From the base roll it onto the door and wait five minutes.
2. roll it onto the top and wait five minutes.
3. Roll it on the back and wait five minutes.
4. Return it to the base and wait five minutes.
Reinstall it or test it on electrical. It should show signs of cooling in about 30 minutes in the freezer compartment if the system is not plugged in the boiler.
May 26, 2008 | Dometic Refrigerators
Cell Phones Logo
23 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
