I would like to rectify my safe link - Computers & Internet
1999 Yamaha XVS 1100 Custom. rectifier blew out. Need rectifier and wiring harness as the connection melted at the rectifier connection. Harness is discontinued by mfg.
Hi, Rick you may have to fabricate your own sub wiring harness to the rectifier for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
XVS1100 Voltage Regulator Problems
Amazon com Ricks Motorsport Electric Rectifier Regulator Wiring Harness...
Yamaha XVS1100 Service Manual
OEM parts for Yamaha
YAMAHA XVS1100 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 06, 2017 | 1999 Yamaha XVS 1100 Dragstar
I have a troy bilt 10hp 26" snow blower and my problem is I keep blowing light bulbs . I've looked at the wiring diagram and would like to know where you find the Dioder/Rectifier at? Please help.
The rectifier should be on the engine either on the recoil housing or just beneath it. You should be able to follow the wiring back from the lighting system to get you close to it. Be safe and good luck!
Feb 05, 2015 | Garden
Recharged tablet and now in safe mode. How do I rectify this. Cheers
Let it run in safe mode and then shut down. Hopefully any damaged files will have been rebuilt.
Oct 28, 2013 | Tablets & eReaders
Sometimes its running about 12 volts an then it will drop to 10 then i'm stranded! its a new batterie should i ck all my grounds?
You didn't mention the year of the bike. 12V means your battery isn't charging. If you have a regulator check the voltage at the gen terminal. If it is more than 12V, the regulator is bad. If you have a bike that's equipped with an alternator, check the voltage coming out from the rectifier (DCVolts) and the voltage (AC volts) going into the rectifier. You should have more than 12V coming out and somewhere around 14VAC going into the rectifier. Good luck and safe riding.
Jun 28, 2011 | Harley Davidson FLHT Electra Glide...
Replace regulator/rectifier with a different brand?
Not always necessary to change the regulator/rectifier. Check all connections to make sure they are clean, use a good contact cleaner and finish off with dielectric grease on your electrical connections.
When some bikes get a few years on them the connections get dirty. Check to see if there are any burned or discolored wires anywhere around the regulator. The FIX on some bikes is to cut the connector completely out and solder the wires together and either seal them with heat shrink of a good electrical tape. Loose or bad connections get hot. As long as the regulator and rectifier are working there is no need to replace them if the connections are good.
Ride Safely, Ed
Apr 08, 2010 | 2005 Kymco Zing 125
Password locked can't get in
YOU SHOULD BE ABLE TO START UR UNIT IN SAFE MODE U NEED TO TURN IT OFF THEN START IT UP WHILE PRESSING ON NOT SURE IF ITS F8 OR F12 BUT WHEN IT COMES UP SELECT SAFE MODE U SHOULD BE ABLE TO GO INTO UR UNIT UNDER ADMINISTRATOR GO TO THE USER ACCOUNTS IN CONTROL PANEL THEN JUST SELECT THE ACOUNT WITH THE PASSWORD AND DELETE IT AND THE RESTART UR UNIT AND U SHOULD BE DONE
LET ME KNOW HOW IT GOES
PS SORRY ABOUT THE CAPS DIDNT REALIZE TILL KNOW JUST DON'T WANT TO TYPE ALL AGAIN
Jun 01, 2009 | Dell Inspiron 1100 Notebook
Computers & Internet Logo
149 people viewed this question
David Payne
David Payne
