Question about Water Heaters
No electricity going to heater - Water Heaters
  • Water Heaters Master
  • 17,155 Answers
If you are saying that you have no supply to a water heater and it is electric, then you need to first check the circuit breaker panel. Water heaters are 220 volts, there should be a double breaker in the panel that is labeled for the water heater, if so make sure it is not off or tripped.
Posted on Dec 09, 2016
How do I change a r.v propane water heater to a 55 gal electric appartment size water heater
Changing out the water isn't difficult, but an electric heater needs a lot of electricity. Doing the wiring is going to be the hard part.
The plumbing is easy. Cold water in, hot water out. Two connections. Cap the propane connection.....
Oct 09, 2015 | Water Water Heaters
Called and was told to change lower thermostat but yet again I had to go push red reset button on top panel to get it back on to get hot water. what should I do now?
You have electric water heater.
You have top and bottom panel, so water heater is 240Volt.
No hot water because ECO reset button tripped.
Water heater works correctly when reset button is reset, so electric power and circuit breaker are good. Water heater wiring is probably good.
Problem is most likely bad thermostat.
I usually replace both upper and lower thermostats.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
If problems continue after replacing thermostats, then test and replace elements.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
Aug 05, 2011 | RELIANCE ELECTRIC WATER HEATER
I have a Rheem Electric water heater Model#71-52DB. It has no power and not heating when it does have power.
You need to troubleshoot water heater and electric going to water heater.
Troubleshoot takes about 45 minutes.
Typical electric water heater tank is fully repairable by homeowner using generic parts from home center or hardware.
Links below walk you through the steps:
http://waterheatertimer.org/Test-electricity-to-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Buy $5 multimeter from Lowes or Home Depot or Ace:
Install battery in multimeter.
When testing voltage, rotate multimeter dial to 240 or 250 or 277 VAC.
When testing continuity or elements, rotate multimeter dial to ohms (upside down horseshoe symbol is ohms)
Image of Multimeter
Jan 12, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have a model 71-408 B which just stop heating
If I understand correctly, you have electric water heater.
Heater suddenly stopped heating.
Four things cause sudden loss of water heater.
1) Reset button located under the top cover is tripped > turn off power, remove cover, press reset button > if reset keeps tripping, go to the troubleshooting link shown below.
2) Electric power to heater is interrupted > check circuit breaker > test for voltage > look for loose wire on breaker
3) Upper element burned out > test and replace element
4) Upper thermostat bad > replace upper thermostat
Reset button is best suspect.
Here is a link for complete troubleshoot and homeowner repair of electric water heater:
Nov 19, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Water heater replacement
Direct vent water heater is your best option with gas - may be best to stay with electric - today's electrics are more efficient.
Mar 10, 2009 | Water Heaters
Water Heaters Logo
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
