Question about Garden
What is required to winterize my yard sprinkler system.? WILL MY PIPES BURST IF SYSTEM IS SHUT DOWN..??
  • Garden Master
  • 16,803 Answers
That depends on what was installed. Some systems have a drain at the end of each circuit or zone. When there is no water pressure, the drain opens and lets the water in each line run out. If you have this then you only need to make sure that the main line supplying the water to the valve manifold is drained. If you are not sure, then you need to hook a large compressor to the system and blow the whole thing out. Usually there is a connection at the vacuum breaker that you hook an air hose to, shut off the water inside the house and then turn on the compressor, when it builds up enough pressure you turn each circuit or zone on and let the air drive the water out. When the zone is done, you move to the next one.
Posted on Dec 09, 2016
Toro lawn sprinkler system, shut water off went to winterize system hooked compressor to blow out plug turned on first zone, water blew out everything good, went to blow out 4 other zones and nothing
I may suggest your distributor was set to the first zone.
Therefore, neither water nor compressed air will "flow" in any zone except that one.
See if turning on the electric and setting a different zone will accomplish your desired result.
God bless your efforts.
Nov 11, 2016 | Garden
Why does my pump loose pressure
Sounds like your not using enough water, and or your pipes to sprinkler is to to small, causing pump to build up to cut off head. I cant lay my hands on a performance chart for your pump, but 60 psi cut off and 20 on sounds about right. Try running another tap when your sprinkler is running, and see if this keeps your pump running
Mar 25, 2015 | Utilitech 1-HP Cast Iron Convertible Jet...
How do I winterize my sprinkler system
Turn off the water supply to the sprinklers system.
Connect a compressor to the system and blow out the individual zones, one at a time.
You can have this done for you for about $75.00 if you are without a compressor or are unsure of the procedure.
Doing it incorrectly will destroy the underground pipes as the water will crack the pipes.
Nov 15, 2014 | Garden
The sprinkler system is shut off but there is still little water coming out of the sprinkler head. What is the cause of this problem?
Water will continue to run back down the hills to the lowest Heads and Some water will come out.It will stop once the water in the lines has Drained out.
Oct 02, 2014 | Garden
Water pipes frozen central heating still going am afraid when thaw comes that pipes will burst
Look it is not when thawing that they burst, if they were going to burst they would have done that already. The pipes burst when they freeze and the water expands, it just so happens you do not find that until you defrost the pipes and the water can flow. You really need to visually inspect all of your piping while it is defrosting and then isolate the leak for repair. If they were going to break they already did. Good luck and I am praying for you!!
Dec 26, 2010 | Desa International CBN30T Central Heating...
Dewinterize sprinkler system
On most sprinler systems all you need to do is turn the water back on and turn the timer on.Most are just blown out with air to winterize
Pls rate the answer
Apr 14, 2009 | Garden
Brass Champion Sprinkler Valve
The lowest sprinkler head usually leaks until all the water is out of the system. The valve that controls the sprinkler system has a vaccum breaker valve on it. When there is no pressure from the water main the vaccum valve opens allowing the sprinklers to leak water so the house water won't get contaminated from the grass and dirt in your yard.
Jul 27, 2008 | Electrical Supplies
Garden Logo
67 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
