Question about Panasonic Televison & Video
I don't have original remote for my Panasonic tv. The message came up and I replaced Lamp. Message stil comes up and how can I reset without original timer?
    Top Expert:
  • Panasonic Master
  • 80,383 Answers
You need the remote you can most likely get a factory remote here: 1 800 Remotes
Posted on Dec 09, 2016
  • 547 Answers
SOURCE: The person I purchased this t.v from is saying the
The projector unit keeps an internal timer to warn you when a lamp is near the end of its life. This timer doesn't automatically reset - you have to use the on-screen menu to reset it.
Her story sounds perfectly legit, you just need to perform the timer reset (or have her do it with you/for you) and you should be all set.
Posted on Sep 21, 2009
Testimonial: "Thanx A million!I never even knew this site existed. Im so happy to finally get some helpful information!!!!!!"
  • 81 Answers
SOURCE: resetting lamp hour meter on panasonic tv
press volume down on tv and pip or split on remote
Posted on Nov 19, 2009
asnowman
  • 788 Answers
SOURCE: How do you reset the lamp clock on model number
According to the lamp manual you just need to power the set on with the remote and then press (and hold) the Vol - button on the front of the set, While holding the Vol- button on the front of the set press and hold the PIP button on the remote. HOLD both for more than 5 seconds or until the lamp timer has been reset to 0 appears on the screen.
I hope this information allows you to resolve this issue.
If you need further assistance or if this did not help you please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Posted on Nov 28, 2009
welcomejee
  • 10594 Answers
SOURCE: I have a large screen panasonic tv. The lamp
Turn On tv.
Press and hold Volume Down button on TV Front and PIP/ SPLIT button on Remote at same time for 6 Seconds to reset Lamp Timer and tv will show you timer reset message screen.
Hope this info will help you.
Thanks.
Posted on Mar 31, 2010
asnowman
  • 788 Answers
SOURCE: My TV model is Panasonic: PT-52LCX15. I have a
Here is a link to replacing the lamp and the instructions for resetting the timer.
I hope that this helps you.
asnowman
http://911phone.net/Panasonic_TY-LA1000_Instruction_Manual%5B2%5D.pdf
Posted on Jun 21, 2010
How to reset the lamp meter on a panasonic pt-52lcx16
Panasonic Projection TV Lamp Timer Reset
Your lamp will probably last a lot longer than the TV thinks it should. This procedure will reset the lamp timer so you don't have to look at that annoying message every time you turn your tv on. Remember that the "lamp" indicator light on the lower left of the set will stay on until the lamp is actually replaced. I had to buy a replacement lamp to get this information, could not find it anywhere for these model numbers.
Press the volume down button on the projection display and hold down the zero button on the remote control at the same time for more than 5 seconds. When the reset procedure is complete, a message will display that the lamp timer was reset to zero.
This procedure will work for Panasonic models: PT-52LCX66 , PT-56LCX66 , PT-61LCX66 , PT-52LCX16 , PT-56LCX16 , PT-61LCX16
Jul 20, 2014 | Panasonic Pt-52lcx16-b Replacement Rear...
How to reset the meter on a panasonic pt-52lcx16
Panasonic Projection TV Lamp Timer Reset r
How do you reset the lamp clock on Panasonic model number PT-61LCX35 without an original remote?
We regret to inform you the original remote is necessary to reset the lamp hour meter. We recommend you use the below link to obtain the correct remote control for the TV. The remote part number is EUR7627Z70.
Parts Ordering
Mar 17, 2014 | Panasonic Televison & Video
Does the panasonic PT-52LCX66 have a reset switch or anything for after replacing the lamp assembly?
The reset directions should be included with the replacement lamp. If the sheet is missing, you can get a copy here: http://images.panasonic.com/static/Content/productsupport/TYLA1001.pdf .
Plug in the TV and turn it on. Press and hold the Vol - button on the front of the TV then press and hold the zero ( 0 ) button on the remote for more than 5 seconds. You will see a Lamp Reset message on the TV when you are finished.
I hope this helps.
(if you do not have the original remote, you will need a replacement remote. One substitute remote is available here: http://remotes.com/store/panasonic/eur7613zh0.html .)
Jun 20, 2011 | Panasonic PT-52LCX66 Projection Television
Turn On tv.
Thanks.
Mar 31, 2010 | Panasonic PT-50LC13 50" Rear Projection...
How do I reset Lamp in PT40LC12 with out a remote
After turning on the TV and viewing the message to "reset the lamp" I became frustrated and attempted to shut the TV off by pushing the power button. A message popped up saying "Do you want turn the TV off Yes / no.
I toggled down using the volume/Channel button on the tv to say no. The next thing i know...The TV picture came on and the la,p was reset!!! I really don not know how this happened! but it worked! Thanks for your assistance. Now, i can program a remote!
Oct 23, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Turn on tv get error message Lamp needs to be replaced and the Lamp Hour meter needs to be reset. I still have picture how do I reset this error message
Howdy,
To reset your Panasonic Lamp Time:
ø Press and hold these buttons for (at least) 5 seconds:
ø Volume Down button (on TV Panel).
ø AND ACTION Button (on remote).
As the remote gets older the ACTION button may not respond unless you press the button dead center and not at an angle.
Thanks for using FIXYA, BIG IRISH.
Mar 25, 2009 | Panasonic PT-44LCX65 Television
Lamp Hour Meter
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Lamp hour reset to many popular projection TVs are given.
Mar 03, 2017 | Televison & Video
Projection lamp timer reset
I need help resetting the lamp timer. Is there a way to reset the timer w/o the remote? We bought this tv as a floor model 4 yrs ago and they didn't have the actual remote that came with it, so they gave us another remote that works. We replaced the lamp but we keep getting the message that the lamp needs to be replaced and the timer reset. Plus the red lamp indicator is still on. We even used a friend's remote (he has the exact same tv) and it still will not reset the timer.
Jul 19, 2008 | Panasonic PT-44LCX65 Television
Lamp Hour Meter
This proceedure should work for your model to reset the lamp meter.
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Mar 29, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Televison & Video Logo
120 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
